Old 08-05-2022, 03:57 PM   #1
1997 30' Limited
1997 31' Land Yacht
Toney , Alabama
Generator was running two (2) AC now One (1) ????
Hello:
Hope everyone is well. I have a 1997 30' Airstream Motorhome Land Yacht Class A. The Generator would run the front AC and the aft birth AC. Yesterday, I had them both running from the Generator for 3 hours. I shut the Generator off and when I turned it back on it would run either the front or the Aft but not both. Has me really stumped. It's a 30 ampere load center, shore power original OEM would run front or rear select by a switch in the settee area. At some point someone wired a second "shore power" where you plug the female of a extension cord to a receptacle and the 30 ampere shore power like you would normally and it enables both AC to run at the same time. Shore power seems fine. AC units work fine. The issue is now I can only run one AC at a time from the Generator and I always could run two. Any insight is greatly appreciated I am well versed in electrical and have ampere probes and fluke DVOM. Also, does anyone know where the "Converter" or "Battery Charger" is (BC as referred in the schematic). It's not under the hood as far as I can tell its not under the rear birth bed its no where's to be found......I love this Airstream and will continue to TLC it. Its not a tripped breaker in the load center and the fuse at the Onan 5 kW is good has me perplexed. Its nothing a 5th can't take care of over the weekend Kidding so Kidding..... Thank you! Maverick
The Maverick is offline   Reply With Quote
Old 08-06-2022, 10:03 AM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Can’t help with the ac mystery, but the converters on my older coaches are both on the floor under kitchen cabinets, near the 12v fuse panel.
Waipio Rim is offline   Reply With Quote
One New GOODYEAR ENDURANCE ST225 /75 R15 117N E1 BSW and three 15 inch rims Two Aluminum and one Steel - Florida grovepark Airstream Classifieds 0 09-22-2021 12:53 PM
Two Airstreams For One Family Rather Than One Large Airstream Peter417 Airstream Lifestyle 22 05-22-2021 06:25 AM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Two plus two cello The Pet Forum 1 09-26-2006 02:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
