Old 11-11-2023, 08:09 PM   #1
1995 30' Limited
1995 31' Land Yacht LE
Parrish , Florida
Fuel tank capacity
How many gallons will my 95 land stream land yacht LE hold?
Dniver0513 is offline   Reply With Quote
Old 11-11-2023, 11:00 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Can't answer your question directly, but keep in mind that the physical capacity of your tank is not the amount you'll be able to pump into it. There is a required dead space in fuel tanks to allow for expansion of the fuel so you don't have leaks.
As an example, my coach had a 120 gal tank but the most that could actually be pumped into it before fuel started coming out the overflow was about 105 gal.
Richard
11018
richard5933 is offline   Reply With Quote
Old 12-09-2023, 10:13 PM   #3
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
Mine is a diesel and hold 90 gallons. You might try to research on the Airstream site for the original sales brochures. Those have specs such as tank sizes and measurements for height and width for your year and model.
On a different note, when the low fuel light comes on the dash, it means I still have 20 gallons of fuel.
Mike1997 is offline   Reply With Quote
Old 12-10-2023, 09:30 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
RE: Fuel Tank Capacity
Greetings Dniver0513!
PDF copies of showroom brochures for the 1995 Airstream Land Yacht Motorhomes can be found at this link, and PDF copies of the Owners' Manual can be found at this link on the Airstream website.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 12-10-2023, 10:43 AM   #5
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
My 92 36' Land Yacht on a P30 chassis can hold 80 gallons.
92landyacht is offline   Reply With Quote
Old 12-17-2023, 08:32 AM   #6
1995 30' Limited
Parrish , Florida
Have you ever changed the fuel pump on your generator ?
What's your preference? Over capacity TV or under capacity? AlinCal Towing, Tow Vehicles & Hitches 135 09-09-2021 07:29 AM
Low Fuel Warning light ON when Fuel Tank is Full, Not Empty??? Michael_Wild Mechanics Corner - Engines, Transmission & More... 1 07-06-2018 12:26 PM
F250 fuel tank capacity mikeinca Tow Vehicles 51 04-02-2018 04:57 PM
F250 Fuel Tank - Add or Replace for more Capacity? Boogieshoes Tow Vehicles 24 09-13-2015 09:07 AM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 08:38 PM
