05-03-2003, 05:26 PM
Front Air Shocks blown
Both of the bags are blown on the Classic 345 front shocks or springs. I do not know how much diffence it would make to have them replaced. It rides pretty nice now. I am looking for opinions regarding my options.
05-03-2003, 08:47 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
The front end alignment was done with the air bags at 55 psi.
AIR #13
05-04-2003, 07:18 AM
1966 26' Overlander
Woodstock
You will find they are not too hard to replace, and not very expensive either. There are numerous sites with some do it yourself info on this. Search within this site also and you will find some.
Most wrap the uninflated bag, lube it with soapy water and stuff it in where it goes. If it is manually inflated no compressor is required, unless you want that option.
The ride is way better with the right air pressure.
05-09-2003, 10:06 AM
1977 20' Argosy 20
Charleston
, West Virginia
Re: You will find they are not too hard to replace
Alan,
Have you replaced yours? It is easy in a technical sense but a bear to remove and re-install. Maybe there is some secret that I missed. I tried the Air lift instructions by squishing them and using soapy water. There still must be an easier way. My shoulders were sore for three days.
05-10-2003, 09:41 AM
2004 28' Classic
huntsville
dont take much to make us ole guys sore. there isnt an easy way
just brute force. lol
al
05-10-2003, 01:11 PM
1977 20' Argosy 20
Charleston
, West Virginia
I drove mine today for the first time and it did drive much better. I am glad I replaced them. A definite improvement on a rough road.
05-10-2003, 01:50 PM
So where is a good source for the air bags?
05-10-2003, 02:43 PM
Corona
Any Airstream dealer, if their interested in helping you.
inlandrv.com
05-10-2003, 03:10 PM
2004 28' Classic
huntsville
camping world and they install...lol
al
1977 20' Argosy 20
Charleston
, West Virginia
I bought the Air Lift bags from Camping World. $60 and some change. Installation is another $60 and change if you want.
05-10-2003, 07:53 PM
installing air bags
I found it helpful to pull a vacuum on the bags prior to installing them( I used my ac vacuum pump) it made them easier to put up into that little small hole.It also helps to twist them like wringing a rag out but it still makes your hands sore.
05-11-2003, 11:06 AM
Corona
Fred.
$60.00 each or for a pair?
You didn't say.
inlandrv.com
05-11-2003, 04:11 PM
1977 20' Argosy 20
Charleston
, West Virginia
Camping World has the Air Lift 1000 replacement bags for $62.99 (member price). It is a pair. Item # 4961
The catalog lists installation at $69.00.
12-28-2003, 08:07 PM
I finally installed the front airbags this weekend.
What a job but what an improvement in the ride.
I wish I had a vacuum pump to squish those fellows flat. Seems like there must be a trick to getting the bag small enough to get thru the 2" hole.
I did not realize how much bouncing around I was doing without them.
Any comments on the correct pressure to run?
12-28-2003, 08:24 PM
1977 20' Argosy 20
Charleston
, West Virginia
55 psi at all times.
Camping World also sells an electric pump designed to keep them inflated at 60 psi but it can be adjusted.
Automatic Pressure Maintenance System
12-29-2003, 09:07 AM
Corona
There are 2 different "front air bags" available,
The cheap one can be force into place after a effort, even after it's been evacuated. They run about $65.00 per pair.
The better long lasting bags cost double that, and can only be installed after they have been evacuated, AND, a spring spreader is used.
Air pressure must be 55 psi at all times, no more and no less, as per Airstream engineers. Needless to say, good shocks are important as well, as the air bags do not replace the purpose or function of the front shocks.
12-30-2003, 09:01 PM
I did mine, and what a pain even for a youngster... I would pay to have it done next time. I'm waiting for good weather to do the rear air bags!
Sebastian
12-30-2003, 09:06 PM
Just a member
1978 28' Argosy 28
Lutz
The rears are easy. I did mine and it took me longer to jack and brace the suspension and frame for the R&R than it took to change the bags Since you did the fronts the hard ones are done.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
