Old 12-27-2021, 09:43 AM   #1
ezscreener's Avatar
​201​9 Atlas​
Pontiac , Michigan
Atlas Couch Seatbelts?
Happy Holidays! Checking in to hear if anyone has tried or even is possible to install seatbelts in the couch? Thanks!
ezscreener is offline   Reply With Quote
Old 01-03-2022, 11:02 PM   #2
2015 25' Flying Cloud
2018 33' Classic
​2020 Atlas​
Pullman , Washington
Our 2021 Atlas came with two seatbelts for the couch.
WA_Airstream is offline   Reply With Quote
Old 01-15-2022, 08:54 AM   #3
ezscreener's Avatar
​201​9 Atlas​
Pontiac , Michigan
Hmmm. 2019 doesn’t have them. I’d be interested to know how and where the belts are fastened so I could install a couple of sets. Anyone?
Old 02-02-2022, 08:56 AM   #4
​201​9 Atlas​
FOOTHILLS , AB
Look under your couch, all Atlas coaches have seatbelts for the couch.
If they are missing go back to the dealer as they are standard equipment.
Multiple Safety Impact Air Bags STD
Four Seat-Belt Positions STD
Collision Prevention Assist STD
Lane Keeping Assist STD
Rear Camera Assist w/Always-On Viewing & Adjustable Angle STD
Side Camera Assist Integrated in Side Mirrors STD
High Mounted Third Brake Light STD
Advanced Navigation w/RV Specific Warnings & Instructions STD
Rain Sensing Windshield Wipers STD
Smoke, CO2 & LPG Detectors STD
Fire Extinguisher STD
2019 Atlas
Zach05855 is offline   Reply With Quote
Old 02-02-2022, 09:23 AM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Are you the original owner of the Atlas? If not, it's quite possible the PO removed the belts, simply to get them out of the way. it's a *very* common thing to do. If so, the mounting points are still back there under the couch. You just need to source a set of belts and bolt them back in place.
Common thing to do = about to pull some from our new van
Old 04-21-2022, 04:08 PM   #6
Bellevue , Washington
seat belts on couch
Your 2019 Atlas definitely came with Seat Belts. I own the same model and have them. Suggest you extend the footrests and look under the couch. We frequently push the seat belts through the cushins below the couch to get a more comfortable space to lay down on the couch.
If you have passengers in the couch while you drive, I suggest you ask them not to extend the footrests or move the couch while in motion. My daughter did this and she must have pushed the button in the wrong direction because one of the couch motors burned out (stank) and if you can't move your couch, you have no bed! I've sent this suggestion to AS already and told them they should have a manual operation for the couch so you can sleep if this happens.
The system has a fuse under the couch which was also burned out. Not sure how the fuse could be burned out and the motor burned out, but it happened.
I replaced the burned out motor and put in a smaller fuse just to be sure the motor won't burn out again. I carry extra fuses now!
Esfin is offline   Reply With Quote
7 vs. 9 seat Lounge due to 4wd, can seatbelts be added? BenjaminS Airstream Motorhome Forums 0 06-07-2020 02:01 PM
seatbelts????? Isuzusweet Classic Motorhomes 15 09-24-2012 01:41 PM
3-point Seatbelts crazeevw Classic Motorhomes 7 08-21-2011 08:41 AM
Seatbelts in the dinette and couch Boom Sounds Classic Motorhomes 9 04-05-2008 07:30 PM
Seatbelts/ Shoulderbelts Chaplain Kent General Motorhome Topics 5 08-02-2005 05:46 AM
