Old 01-12-2022, 01:28 PM   #1
Airstream - Other
Topping , Virginia
Airstream Atlas Forum
Just bought an Atlas...2020
And new here...
Is there an Atlas forum?
Need to know best after market tire monitoring system to buy???
dhowell2017 is offline   Reply With Quote
Old 01-13-2022, 05:00 PM   #2
​201​9 Atlas​
FOOTHILLS , AB
I suggest you join the Atlas Facebook group. It is much more active with more members.
As for TPMS.
TST 507 6 Sensor Tire Monitoring System with Color Display - Handles Multiple Trailers
you can find it at Amazon
2019 Atlas
Zach05855 is offline   Reply With Quote
Old 05-30-2022, 08:34 PM   #3
Emm
2021 Atlas
Holladay , Utah
Same issue - Atlas 2021 - Hard to believe there is no TPMS installed.
Thanks for the information on the TST 507 tpms - I will check it out.
Emm is offline   Reply With Quote
Old 06-06-2022, 08:18 PM   #4
Bellevue , Washington
Atlas head bangers
Hi, After hitting my head on the corners of two cabinets multiple times, I have found a very nice solution. The cabinet immediately to the right of the main door had nailed me multiple times and the lower edge of the overhead cabinet going into the driver's cabin from the coach has nailed me several times. Both edges are quite sharp and I have scabs on my head from both.
Bought this item from Amazon for $16 and spent 15 minutes cutting it to size and installing.
Here is what the cabinet edges look like now.
Best $16 I've spent!
Name:	Cabinet Edge 1.jpg
ID:	417059   Click image for larger version
Name:	Cabinet Edge 2.jpg
Esfin is offline   Reply With Quote
Old 06-07-2022, 08:50 AM   #5
​201​9 Atlas​
FOOTHILLS , AB
If you only knew how many times my wife and I have said "%&$#@*&^ EDGES!!!!!"
My wife has a permanent crease in her forehead from the one over the cab.
2019 Atlas
Old 06-07-2022, 10:25 AM   #6
Zach, I too have a 2019 Atlas. Overall, I love it, but am pretty surprised by some of the little things they left out which would be very easy for them to fix. This is definitely one of them! Good luck fixing this.
p.s. I've spent the last 6 months upgrading all sorts of stuff in my Atlas. So if you have any questions, chances are I've dealt with it. Upgraded the batteries to Lithium, added more solar panels, upgraded the solar charge controller, etc. Currently looking for a good solution for the very annoying problem of how long it takes the water to heat up because the on-demand water heater seems to take forever to warm up the water and wastes a gallon of water just to warm up. Will post once I find a good solution.
Good luck
Old 06-07-2022, 11:02 AM   #7
​201​9 Atlas​
FOOTHILLS , AB
Good luck
The only mods so far we have done is to remove the table mounts on the floor and instead use a collapsible aluminum table the easily stores in the outer cabinet.
Looking to upgrade to lithium maybe next year and probably will add a folding aluminum table that attaches to the side wall where the televator is so when we stop for lunch we can fold up the table and sit on the sofa and eat comfortably.
2019 Atlas
Old 06-07-2022, 01:24 PM   #8
Please post photos when you do the tables. I'm very interested in same but want to see what it looks like.
Atlas Owners? or Anyone with Atlas knowledge foleyx4 Airstream Motorhome Forums 15 06-08-2022 02:03 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
