Old 04-01-2020, 05:24 PM   #1
1988 32' Excella
1987 34.5' Airstream 345
Livingston , Texas
‘87 345 with starter issues
Howdy folks -
I have a 1987 345 that has been a dream except for one ongoing issue...
I CANT keep a starter in the damn thing.
I’d say in the last 30-40 starts I’ve burned through about 3 starters.
And now, I’m having this issue where I’m getting power to instrument cluster, but the starter doesn’t even begin to engage. As in I don’t even hear it click, things just buzz when I turn to ignition.
These starters are brand spanking new, not rebuilt. They have lifetime warranties, so I just keep trading them around, but something else is wrong.
I’m currently dead in the water at a campground until I can figure this one out. I’m planning to change my starter over in a few days to see if that fixes it, but still, I’ve gotta figure out why these keep going - this isn’t sustainable!
Anyone experienced this before? What advice might you have for a newbie like me?
345 MoHo is offline   Reply With Quote
Old 04-01-2020, 05:40 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Check your ground, if the ground is OK work your way backwards, the starter positive wire. Also check for what voltage you have in the start battery with a multi-meter, then check the voltage at the starter on the large positive wire. They should be within 1/2 of a volt between the 2. Also, you make sure that the transmission is in park or try to start it in neutral.....if it starts in neutral then you have a problem in the steering column. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-01-2020, 05:57 PM   #3
Are you using the OEM style of starter or a high torque mini starter?
The high torque mini starters use less current than the older original style of starter and in general start the engine faster because they spin faster. Even better they are cheaper the the OEM starters.
1975 24' Argosy Motor Home
Old 04-01-2020, 05:58 PM   #4
1988 32' Excella
Livingston , Texas
Thanks Bob.
Tried the neutral fix, but didn’t start. I’ll try the ground test tomorrow. But, I’m going to ask a rookie question...where/how do I check the ground? Is that one of the wires into the starter?
Also, I flipped the switch to start off the house batteries and same issue. We’re plugged into shore power, so would that answer the question regarding power from the start battery?
Thanks again.
Old 04-01-2020, 06:05 PM   #5
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I went through several starters and an ignition switch on our 310 before giving up and taking it to a mechanic. At that point I was starting it with a push button switch and two heavy wires connected directly to the starter terminals. The mechanic found an unexpected and faulty relay in the circuit. It was located in front of the air cleaner.
Waipio Rim is offline   Reply With Quote
Old 04-01-2020, 06:14 PM   #6
Something else just came to mind. I have a Cushman Truckster that I use around the property that has a 22 hp motor with an average size starter. For about 4 years I was replacing the starter and the battery about every 8 to 10 months.
Then one day I took a close look at the battery cable clamps. The looked a little dark where the clamp contacted the battery post. I have one of those tapered reaming tools for battery clamps so I scrapped the inside of the clamps until they were nice and shiney inside.
It's been 3 years now and I haven't had to replace a battery or starter since. I believe the issue with the poor contact between the clamp and the battery post was causing an excessive current draw from the starter.
Anyway, something that might be worth checking.
Good luck!
PS, I think Bob is referring to the battery ground cable. You want a really good connection at the chassis. Which reminds me, there should be at least one ground cable running from the back of one of the engine heads to the chassis, two cables are even better, one from each head.
Something that most people don't think about is the ground grid that is made between the battery, engine and body. What most people don't realize is the chassis is made of up of frame members and rivets. As the rivets corrode the connection between chassis members becomes also corrodes which deteriorates the ground grid.
Old 04-01-2020, 06:49 PM   #7
1988 32' Excella
Livingston , Texas
I’d definitely be game to try it as I think mine is OEM.
Do you have a particular type you’d recommend for an 87 345 with a GM 454?
Old 04-02-2020, 05:00 AM   #8
This High torque mini starter is like the one I bought a on ebay.
I bought one on the recommendation of a forum member. I don't drive mine much and my electrical system is all new but so far no issues.
Old 04-02-2020, 05:41 AM   #9
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
First, no hands on with your exact problem. But something isn't right. I only have two ideas and one has been mentioned but having a guide on how to might be helpful.
I have a magazine that I have managed to save, IMPORT SERVICE Jan 1992 and the article titled Sixteen Minutes. This article uses a DVOM and goes thru with pics step by step what to check and what to expect for starting and charging tests. Including voltage drops.
And to my disappointment after buying a newer clamp on meter finding out that I didn't get the model that measures DC amps which I think would be a good thing.
345MoHo if you'd like a pdf scan send me a PM with your email, I'll send it to you.
Gary
GCinSC2 is offline   Reply With Quote
Old 04-02-2020, 06:35 AM   #10
1986 34.5' Airstream 345
Glencoe , Oklahoma
Good luck!
I had this same issue on a Chevy truck but the corrosion was on the battery cable where it bolted to the starter. It was a cheap cable and it corroded inside the crimped on end. I replaced the end and all was good after that.
JJ1965 is offline   Reply With Quote
Old 04-02-2020, 08:54 AM   #11
That makes sense. High resistance connections play havoc with batteries and components.
Old 04-02-2020, 12:17 PM   #12
Auckland , New Zealand
As others are pointing these machines have bad ground points!
Bkahler described some reasons chasis rivits ect.
So very quick fix get one jumper lead connect directly to the neg terminal on the battery and other end directly to the starter body.
A bad earth will kill your starters.
I have made a permanent fix by attatching a new ground from battery to bolt on bell housing.
Spirilas ellectrical probs rear gas pump ie point to bad earths through the original aged chasis earth points.
Rus
Voltair is offline   Reply With Quote
Old 04-02-2020, 01:15 PM   #13
Termite748's Avatar
1979 28' Airstream Excella 28
Spring valley , Illinois
Maybe starter is binding on flywheel.might need to add shim.
Termite748 is offline   Reply With Quote
Old 04-02-2020, 02:19 PM   #14
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I remember in my mechanicing days that starters use to get killed by engine heat from sustained high loads. Hence, heat shields were added. Make sure yours are still in place even if the starter has been updated.
guskmg
Old 04-04-2020, 08:16 AM   #15
GCinSC2's Avatar
Josh,
Scans sent, check email.
Gary
Old 04-04-2020, 10:56 AM   #16
1988 32' Excella
Livingston , Texas
Thanks so much for all the insightful info here. I'm currently working on checking all electrical points and such. Should know more within a few days (getting a new multi-meter delivered because the one I have is a POS
One question - I'm assuming you put that starter in your Argosy? Is that a GM 454 or something else in there?
Old 04-04-2020, 10:56 AM   #17
1988 32' Excella
Livingston , Texas
Originally Posted by GCinSC2 View Post
Josh,
Gary
Thank you sir!
Old 04-04-2020, 10:57 AM   #18
1988 32' Excella
Livingston , Texas
Thanks y'all for all this helpful insight. I'm currently holed up at a campground and waiting on a few other tools to get delivered. Thankfully, I don't have to move for a bit so will be working on this on and off over the next bit.
I'll be sure to report back on what I figure out and how the fix works out for me.
Old 04-05-2020, 07:02 AM   #19
Yes, 454.
A good multimeter is definitely a must have for one of these rigs.
Mini starters are also known as gear reduction starters.
mini starter threads
another mini starter thread
Old 05-09-2020, 02:06 PM   #20
1988 32' Excella
Livingston , Texas
[UPDATE ON 345 STARTER ISSUE]
Hi again, y'all and sorry for my delayed response on this post. The wife and I enjoyed some quarantine time so I didn't wind up in a rush to get the starter fixed.
At any rate, we decided to roll out of the campground a week ago so I needed to get the starter figured out to move the Motorcoach.
Thanks to all who offered suggestions and guidance. It was super helpful and appreciated. Here's a bit of what I did to figure out the problem:
1.) I grabbed the starter I replaced that I thought was faulty and bench tested it using this video as a guide:
With that test, I was able to get the starter to fire on the bench. This led me to conclude that the starters I was replacing were actually good. The reason we kept replacing them is that new starters seemed to fix the issue. But after it kept happening, that led me to believe that to be a simple coincidence. Perhaps that I had jiggled wires enough in replacing starter to create a momentary connection.
2.) Once I confirmed that my starter was okay, I set about testing power with a test light. While I know I'd need a multimeter to truly see how much power I had going, I wanted to first eliminate a total lack of power at a certain point before going forward.
3.) The test light showed that I had power going to the starter pole and that I could get a ground off the normal starter ground.
4.) I had my wife in the coach turn the key to ignition with my test light on the small nut on the starter that receives the signal from the ignition wire and creates the connection that causes the starter solenoid to act. I tested several times, but could not get the test light to light up when I had it touched to the ignition pole.
5.) Next, I wanted to be sure I had power in my ignition fuse in the glovebox. I put my test light in there and turned it to ignition and WHAMO - it lit right up.
6.) Based on those tests, I concluded that there was a short in the wire from my ignition switch down to the starter.
7.) To temporarily resolve the issue until I could get a more permanent fix, I wired a push-button ignition switch (around $15 at AutoZone) to the starter's ignition pole and up through the doghouse. To power the switch, I wired a flat metal connector to the non-starter end and plugged that directly into an open fuse in my glovebox panel. (I confirmed this panel had power before plugging in).
8.) Once that was all done, I simply turned my key to the on position and then held the starter button.
9.) The starter kicked right over and the engine fired up right away. I've duplicated this several times without fail.
While a temporary solution, this has been an effective way to get on the road for the time being. MoHo is back in storage for a few months and I'll have mechanic do a more proper fix in the meantime.
It was hugely rewarding to diagnose and fix this issue myself - especially after all the trouble we've had. But I couldn't have done it without you folks. Gary - your email of that old magazine was a crucial step by step that helped me eliminate potential factors. @Waipo Rim -- it was your experience hard wiring a switch to your starter that first inspired me to this being a potential solution.
Thanks to all who helped and I hope this thread will once again help others along the way!
345 -454 Starter replacement raveson Classic Motorhomes 4 03-01-2010 10:11 AM
Help - starter solenoid ViewRVs Mechanics Corner - Engines, Transmission & More... 23 02-27-2004 07:58 PM
Portable Jump Starter joshua32064 Batteries, Univolts, Converters & Inverters 6 10-12-2003 12:13 PM
Starter heat problems ALANSD Mechanics Corner - Engines, Transmission & More... 0 02-15-2003 02:51 PM
Ode to a starter ALANSD Mechanics Corner - Engines, Transmission & More... 9 01-07-2003 10:55 AM
