Old 01-13-2019, 09:03 AM   #1
groovzilla's Avatar
1963 19' Globetrotter
Seattle , Washington
My '63 GT Interior Restoration Photos
All,
Started the interior restoration of my 63 GT--->Purchased this past summer and finally digging into it.
It is an international model however a previous owner painted the wood cabinets an ugly while w/dark blue. I had no choice but to re-paint a more appealing color. I pulled the stove/oven and replacing with 2 burner stove top and microwave - also pulled original fridge and furnace/cabinet and made a custom cabinet to fit my new fridge which will either run on 100V or room for ice bucket on bottom shelf for ice to use as cooler for traveling until we are plugged into 110V.
I removed the pull-out front gaucho and installing dinette - I will keep the pull out bed on curbside.
I removed the space confining wall/cabinet blocking the toilet area in the bathroom and replacing with a 45 degree angle wall w/door and shelves above.
I also removed the old hot water tank and will install my excel water on demand water heater inside the redesigned bath cabinet
I got the laminate counter top fitted yesterday and installed the stove top and sink/faucet - Nothing permanently down yet until cabinets are lined up and my new plumbing/propane lines are run.
Here is a before and after of the cabinets/kitchen area. I'll post more photos as I progress.
ID:	331577   Click image for larger version
1968 22' Safari - All Original
groovzilla is offline   Reply With Quote
Old 01-13-2019, 09:35 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Groove, Looks great. That fridge really looks nice. We have a 61 GT. We've also been wondering which goucho to remove. We think it's going to be the side one as the front bed seems a bit larger. Interested to see more pictures as you move forward.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 01-14-2019, 07:43 AM   #3
groovzilla's Avatar
^^Thanks!---> IMO, I think the front gaucho is best removed for dinette as for my height(6'1") is less comfortable due to the more restrictive length as a bed and secondly, sitting at dinette in the very front of trailer feels better overall to me.
Of course when the center bed is pulled out there is less room to get by cabinets but it feels bigger and I will have 4" foam cushions on it for comfort.
Personally I really like a dinette and we like board games, eating and just hanging at a table.
Fellow forum member Seawaatty contacted me and sent photos/measurements of nice dinette he built in front with water tank on the curbside(starboard side). I'll be installing new water tank on the street(port side).
When I construct the dinette I will enclose the front middle side of seating running port to starboard 2" in depth to run the water fill hose and my 12v positive lead for the water pump.
They sell a nice 20 gal fresh water tank on Icondirect.com which is 24"Lx18"W"x12"H and will fit nicely under the port side dinette seat with plenty or room for the 12V pump. Tank comes with water fill fitting and 1/2" fitting at bottom for connecting to plumbing.
**Did run into an issue yesterday - I tested the water drains and waste tank valve and unfortunately the waste valve leaks - I removed the waste holding tank which surprisingly was very clean inside and in excellent condition.
VTS sells an aluminum plate adapter for these Globe Trotter and Caravel tanks so you can use the updated Valterra waste valves - The biggest challenge is when removing the old valve, 3 of the the 4 mounting bolts were frozen and I had to grind off those 3 heads - having the one bolt was very helpful because I was able to dig thru my stainless bolts and fine the same 3/16th's bolt pattern - I very carefully drilled out the very center of the remaining bolts using a small bit and slowly moving to bigger bits - I then used a 1/4" stainless steel bolt with same thread pattern as the old bolt to chase the threads - The brass fitting on the tank makes this easier than if it were steel - All 4 threads are now ready for the new adapter.
I'll post more photos when I install the adapter and new valve.
ID:	331671   Click image for larger version
Name:	waste tank fitting.jpg
Old 03-05-2021, 03:01 PM   #4
Homestead , FL
Do you have pics of the assembly with the new adapter before install?
Hazim is offline   Reply With Quote
Old 11-04-2021, 06:45 PM   #5
groovzilla's Avatar
Sorry it's been so long....
Long time since I have visited Air forums and apologize for not following up.
Here are photos of the adapter install.
**Take note --->I did call VTS as their aluminum adapter mounting holes did not line up with the mounting holes on my original black tank brass mounting plate as seen in photos.
I used my dremmel to chisle out/ enlarge 3 of the 4 mounting holes on the thick aluminum plate. I had to do this in order to get the thick head of the allen bolts to thead properly into the original brass plate.
**Keep in mind there is a collar at the bottom of the aluminum plate that needs to stay in place and not messed with so the head of the allen bolts will have some "meat" to secure the plate.
ID:	407512   Click image for larger version
Name:	6-Bolt shelf.jpg
ID:	407514   Click image for larger version
Old 11-04-2021, 06:54 PM   #6
groovzilla's Avatar
Another update which makes a big difference on the 63 GT was to cut back the closet on a 45 degree angle to give more room for the toilet.'
The original space is too cramped and cutting back the closet only removes a small but of space - I used a cool retro linoleum and aluminum trim to finish off the floor:
Old 11-04-2021, 07:01 PM   #7
groovzilla's Avatar
Another upgrade I added is a Y valve so that I can use the kitchen sink and have the option to have the drain water from kitchen sink drain out to ground using the garden hose attachment on my waste valve to avoid the sink water from filling my black tank.
Since our GT's only have black tank this added feature allows more room in black tank for black water. Can also be dumped directly on grass w/o the garden hose being used.
I redid all the copper plumbing and also added a couple of more drain vaves for the hot and cold water in the closet floor - Floor shown with linoleum covered closet floor cover removed
Name:	water drain valves.jpg
ID:	407518   Click image for larger version
Old 11-04-2021, 07:02 PM   #8
groovzilla's Avatar
I got rid of the non-working Hot Water Tank and added an On-Demand Propane Hot Water Heater in the closet.
Works great and takes "D" Battery for the ignition spark:
Old 11-04-2021, 07:07 PM   #9
groovzilla's Avatar
I removed the Gaucho in front and made a Dinette which is so much nicer. Me/wife love playing board games or having drinks w/friends and sitting at a table.
Last photo shows the complete interior w/Dinette
ID:	407521   Click image for larger version
ID:	407523   Click image for larger version
Old 11-04-2021, 08:02 PM   #10
1962 28' Ambassador
Mesa , Arizona
Nice progress!
Hittenstiehl
Old 09-23-2022, 09:38 AM   #11
redthies's Avatar
1967 17' Caravel
1974 29' Ambassador
Top of the 395 , British Columbia
What brand water heater is that, and do you still like it a year in?
redthies is offline   Reply With Quote
Old 09-23-2022, 11:55 PM   #12
groovzilla's Avatar
It is an Excel Propane water heater - Yes works great.
1967 Caravel One Year Restoration: Photos vonzellen 1966-68 Caravel 40 08-28-2020 02:41 AM
Photos of Safari 1954 restoration safari 1954 1954 - 1959 Safari 81 08-14-2012 06:01 PM
2004 Safari 28' W interior photos idahosafari 2000 - 2004 Safari 8 11-16-2003 01:52 AM
CCD 25' interior photos? darkStar 2002 - 2005 International 18 08-03-2003 08:53 AM
