Old 01-08-2021, 01:29 PM   #21
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by PA BAMBI II View Post
How do you deal with the set screw? <snip> I am guessing I need to completely remove the eyebrow to get the set screws out and reattach after rebuilding?
Yep, that's what we did on our Safari. Not hard to drill-out/replace rivets holding the eyebrow in place - we used Olympics since the eyebrows are non structural. Be sure to put a dollop of sealant on each rivet stem when putting new ones in tough so they don't leak.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-08-2021, 01:41 PM   #22
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Shari your window documenting helped a lot. When you said eight hours of window I knew what I was in for.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 03-13-2021, 01:18 PM   #23
1962 28' Ambassador
Mesa , Arizona
Hettie is flying high these days!
She is getting her new axels and the shop we use puts the trailers up on racks. It is also great way to get photographs from underneath.
Images are the new axles, (ordered through Colin Hyde) and shocks.Click image for larger version
ID:	390638Click image for larger version
ID:	390639Click image for larger version
ID:	390641Click image for larger version
Hittenstiehl
Old 03-31-2021, 10:20 PM   #24
1962 28' Ambassador
Mesa , Arizona
Home from getting the new axels.
Sitting 2 plus inches higher and more level with a new receiver flipped. Click image for larger version
Hittenstiehl
Old 04-02-2021, 08:59 AM   #25
redthies's Avatar
1963 19' Globetrotter
1967 17' Caravel
1974 29' Ambassador
Whiterock , British Columbia
The new ride height looks good. What weight capacity is the new axle? 4500?
redthies is offline   Reply With Quote
Old 04-02-2021, 09:16 AM   #26
1962 28' Ambassador
Mesa , Arizona
Red you are correct!
Dexter axels, assembled with 12” brakes, 4500# axle load rating, torsion arms down angle 22.5 degrees, “EZ Lube” spindles, (grease wheel bearings without removing wheels). Mounting bolts and lug nuts are included.
Hittenstiehl
Old 04-02-2021, 07:14 PM   #27
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Hittenstiehl from Arizona. Unfortunately for you, I stumbled on to your Globe Trotter thread. I'll try not to be too annoying. It is neat for me to see the layout differences and construction differences between your 61 and our 69 21'.
Axles. Your new axles are almost exactly like our new axle sitting on the floor in my shop. 4500lbs series #11 axle with 12" drums, hi profile brackets, ez lube, shock mounts, and the like. We did order the 32 degree start angle for more lift handy here in Colorado for boondocking and the like. We may get 4" more ground clearance.
What is a "receiver flipped" that helped level the trailer?
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
dbj216 is online now   Reply With Quote
Old 04-02-2021, 08:07 PM   #28
1962 28' Ambassador
Mesa , Arizona
I've seen yours also! We agree the differences are neat.
It is even interesting to see the differences between Jackson Center Ohio and Santa Fe Springs California. From what we have read they could even make a change mid-year if they ran out of a product or realizef something could be done better. So within a year, make and model there can be some interesting changes.
The receiver thing that goes into the back of the truck can be flipped over sometimes depending on how it's manufactured. So they took the ball off flip the receiver over remounted everything thereby allowing the ball to sit slightly higher therefore allowing the trailer to be a little bit more level.
Hittenstiehl
Old 04-03-2021, 06:29 PM   #29
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks Hittenstiehl: I had another senior moment. I read "receiver" to be the coupler on the A frame. I call the "draw bar" in the receiver of the tow vehicle hitch the "ball mount". I need to learn hitch terminology.
I imagine we will have to do significant adjustments to the old Reese dual cam hitch for the Globe Trotter. We have the hitch head quite low on the shank now, but we have bolt holes that will allow us to raise the ball maybe 3", and maybe that is enough. Otherwise, we may have to get a new shank that allows a higher ball height.
David
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
I want "Today's Posts" when I'm "logged in"! 66Overlander Forum Admin, News and Member Account Info 10 06-08-2004 07:32 AM
To "file" or Not to" file" Raptorrider2001 Our Community 3 04-14-2003 08:20 PM
