RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-05-2010, 09:19 PM   #681
Originally Posted by goransons View Post
Thanks, I read one thread that talked about doing it but haven't seen anyone who has yet (but am interested to know how). I found this awhile back, but worry it would leave poor qality edge since no doubt cuts with this would be up against a wall etc.
vct tile cutter: ROBERTS
If there were a special blade to cut with a table saw or tile saw a fence could create a pretty square tile too, and maybe a clean edge?
Here's another thread that mentions it, and Shari, TomW, and others discuss ways you might go about doing it.
http://www.airforums.com/forums/f461...ile-46017.html
But I still recall seeing a thread where someone actually DID it, talked about how they did it, and showed results, as you requested.
For what it's worth, from my personal experience with VCT, it cuts like butter when warmed up. This worked fine for me as the vast majority of my cuts were on outside corners that are hidden by furniture. BUT, it also gets a bit "gooey" and wouldn't necessarily cut clean and straight when warm. Clean straight cuts are essential for the "field tile" that will make up the highly visible middle of your pattern.
My worries with a chop-saw/miter saw, or a table saw, is that the VCT might crumble or chip. You might be able to warm them up SLIGHTLY, and then cut them using a jig on a chop-saw or the fence of your table saw. This would be sort of a hybrid solution that might get them JUST warm enough to cut without chipping/crumbling, but not so gooey that the edges curl or warp away from true as you cut. Did that make any sense at all?
One suggestion would be to buy a handful of the really cheap VCT they sell individually (rather than in minimum order quantity of a full box) at the big box stores, and experiment with various cutting methods. Then, when you're comfortable with a particular method, buy your final boxes of product and cut away.
And I'll keep looking for the thread I think I've seen before.
Old 02-05-2010, 09:23 PM   #682
65CV's Avatar
Western , Massachusetts
Table Saw
Scott -
I happen to have a Freud non-ferrous metal blade (72 teeth, 10") in the table saw right now and a leftover piece of vinyl tile.
Just made a 12" cut -- cut was very nice, but there is no chamfer left like the other 3 sides. There was a fair amount of fuzz on the bottom where the paper is, but cleaned up well.
Looks like you can make good, square cuts, but you probably have to cut all 4 sides or the shadows between tiles won't look right.
John
65CV is offline   Reply With Quote
Old 02-05-2010, 09:23 PM   #683
flyrc's Avatar
1960 24' Tradewind
1960 24' Tradewind
Yakima , Washington
9x9 tiles
Scott get me a tile and I'll see how well the router mill cuts it.
H
Wally H.
Parts needed
1962 Street side corner tub
range or parts
Dometic 50 or parts
flyrc is offline   Reply With Quote
Old 02-05-2010, 09:29 PM   #684
Originally Posted by 65CV View Post
Scott -
John
This is good information, John, especially if VCT cuts the same way. The VCT shouldn't have any chamfer on any sides, they are all completely square, so any square cut should work.
Another nice thing about VCT is that the color runs all the way through, so even if the edges show a tiny bit of "reveal" it should blend in pretty well.
Scott- I'd say it's definitely worth buying some cheap individual VCT at your nearest box store and performing some tests.
Old 02-05-2010, 10:02 PM   #685
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Thanks John, are you cutting peel-n-stick or the 1/8 commercial style stuff? I was worried the blade might melt the tile, but maybe it produces just enough heat to help smooth the cut? Wally CNC is another great idea, although I'd need several hundred, would he be up for that?
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 02-05-2010, 10:17 PM   #686
65CV's Avatar
Peel n Stick
Scott -
It was the peel-n-stick, something like Crystal, but spelled wrong. It is some older stuff from Lowe's.
It was in the basement of an older house in Connecticut, so it was lucky if it's 60 degrees down there.
Remember that there's quite a number of teeth on that blade. I'll bet that helps keep the temp down. And, as the old saying goes, "it's all about speed and feed".
John
Old 02-06-2010, 09:14 AM   #687
soldiermedic's Avatar
Florissant , USA
Great work Scott!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-06-2010, 07:41 PM   #688
tallytwo1994's Avatar
tallahassee , Florida
Scott,
See if you can find an OLD paper cutter. That痴 what I致e used to cut Armstrong VCT tiles. The blade must be very sharp but it will leave a nice clean-cut edge. Honestly I haven稚 cut any down to 9 inches before, but have often thought it would work fine.
Carol
tallytwo1994 is offline   Reply With Quote
Old 02-06-2010, 07:52 PM   #689
goransons's Avatar
1963 22' Safari
I have a heavy duty paper cutter we purchased for installing a tin ceiling, I'll have to see how it would work. Did you heat your tiles before cutting?
Scott & Megan
Old 02-07-2010, 11:23 PM   #690
SCott,
We didn't heat the tile but my husband removed the blade and sharpened it really well. My cutter is from the 60's: very heavy with a huge blade and no guard.
Carol
Old 02-08-2010, 12:38 AM   #691
If you are cutting a lot of pieces the same size you might try stacking them and clamping them together with a sacrificial board on the top and bottom, and then cutting through the stack. A medium number of saw teeth is better than too many. More teeth equals more heat. I would use a 40 tooth skilsaw blade. Paper cutters tend to push the material away as you cut unless they are very high quality.
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-08-2010, 12:57 AM   #692
Bo&Susan's Avatar
Daleville , Alabama
Great job, looks real good. I have been reading your thread from the start tonight and we found a piece in a closet that we had no idea where it went, just checked and its an aluminun guard for the back window. Thanks another mystery solved. Susan
Bo&Susan is offline   Reply With Quote
Old 02-09-2010, 05:06 PM   #693
goransons's Avatar
1963 22' Safari
touch ups
prepped a few areas today that need some touch up. Will hopefully spray those areas after work tomorrow.
I also have finished stripping and repainting the front sconces and bathroom light so those can be reinstalled and I can finally work in the evenings.
ID:	95916   Click image for larger version
Scott & Megan
Old 02-10-2010, 07:15 AM   #694
Those look good Scott, I've been debating whether to re-use those front fixtures, or do something else. When you stripped them, what did they look like? I don't suppose they're aluminum are they?
Old 02-10-2010, 08:01 AM   #695
goransons's Avatar
1963 22' Safari
The center (round) light fixture on the ceiling is aluminum and looks awesome stripped, but the sconces are stamped steel, and so are the metal box lights from the bathroom, kitchen, and goucho areas. When I stripped them, they looked horrible, even after stripper, sanding and wire wheel I still had a lot of work to do to get them clean (all those little holes). They had been rolled with latex so many times those little holes were pretty much caked closed with paint.
Scott & Megan
Old 02-10-2010, 08:33 AM   #696
Yes indeed, I love the aluminum ceiling fixtures, they look fantastic stripped and polished!
I suspected the front sconces weren't aluminum, since mine are showing many spots of rust-- that is, wherever the rust can make it through the 7 or 8 layers of caked-on latex house paint. Like yours, some of the holes are completely clogged.
I'm debating stripping them and then painting them back to an aluminum color, or simply replacing them with something else. I'd keep the look modern, but go with something a little less likely to corrode over time.
Old 03-06-2010, 08:07 PM   #697
goransons's Avatar
1963 22' Safari
No photos to share today but finally mother nature cooperated with my work schedule and I was able to make the final coat on the zolatone, it looks great. Tomorrow I'll finish cleaning up the tape etc and then its on to flooring
Scott & Megan
Old 03-09-2010, 07:28 PM   #698
goransons's Avatar
1963 22' Safari
Some progress
I'll confess I've started reinstalling some items, not as airstream work, but simply trying to get my work bench accessible.
I did get the front sconces, minus the difuser material installed a week or so ago, but once the zolatone finished drying in the back, the center light (courtesy of Aluminutz) has been installed, and so has the bathroom mirror and light. If we have another good weekend of weather the tub will get its recoat and final install, and so will the black tank. Things are moving along nicely.
Now that I have a work bench, during our nasty weather days I can start redoing window screens to get those reinstalled and out of the way as well.
ID:	97806   Click image for larger version
ID:	97808   Click image for larger version
Scott & Megan
Old 03-10-2010, 07:16 PM   #699
goransons's Avatar
1963 22' Safari
Did some more cleaning on the back, again finishing up some projects and bolting on parts.
Polished the rest of the rear panel, at least through the F, the rest of the polishing will come when the rest of the trailer is done, but cleaning and sealing as I go. Also can see the used license plate bracket that Wally found and had chromed for me (they only charged $15.00 to chrome it). License plate is off for restoration, but reflectors are back on. Some fine polishing (again I'm not going for super mirror shine, trailer is too pitted) but trying to unify the new and old metal and clean a lot of sap and other crud off the shell as I go.
Next on the back I need to cut a replacement bumper cover, and finish the paint on the frame and back bumper, and then going to paint the "We have also visted Iraq" back on between the rear reflectors. Also waiting for VTS to get those lenses for the tail lights back in stock to replace those.
ID:	97883   Click image for larger version
Scott & Megan
Old 03-11-2010, 05:43 PM   #700
goransons's Avatar
1963 22' Safari
Before I start shopping for something close I thought I'd ask if anyone had a few of these laying around. Both in bad shape finish wise, and both were glued in place because screws had sheered off at some point.
Scott & Megan
1963, caravan, restoration, safari
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 1 02-09-2020 08:28 AM
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 06:55 PM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 09:31 AM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 12:30 PM
