03-19-2025, 05:00 PM
1964 17' Bambi II
Midlothian
, Virginia
best replacement roof vent
Looking for suggestions for replacing the original roof vent/fan
03-19-2025, 06:41 PM
1964 17' Bambi II
1961 24' Tradewind
Strasburg
, Pennsylvania
Welcome to the club!
I installed a Fan-Tastic vent on my Bambi II and love it! Customer service has become difficult with them, so I opted to install a Maxxair vent on my 1961 TradeWind.
I do like the air movement of the Fan-Tastic fan better.
You can install any standard 14" x 14" roof vent to replace your original.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
03-19-2025, 07:53 PM
1966 22' Safari
Fredericksburg
We have Fan-Tastic in our 66 and MaxxAir in our 55. What I like about the Maxx is you can close the lid and run the blades like a typical ceiling fan. That keeps air moving in the trailer.
03-19-2025, 10:01 PM
1994 25' Excella
Waukesha
, Wisconsin
MaxxAir Deluxe for us - best part is the rain cover is integral into the unit and when the fan is off the whole thing sits close to the roof. There is no need to worry about running it in the rain.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
03-20-2025, 09:05 AM
2010 30' Classic
Warren
, Manitoba
X2 with Richards suggestion. You will have to square the corners on the outside and inside skin, using tin snips, but other than that it should be straight forward! Some people cut wood pieces and put them between the skins to strengthen the mount, but I never have, and I have installed over 20 Maxxair fans for myself and friends. One thing, check to make sure you have clearance behind the opening as the 7500k fans extend about 12 inches behind the opening. They are 23" in length total.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
03-20-2025, 02:02 PM
1994 25' Excella
Waukesha
, Wisconsin
I did this - putting the wood between the inner and outer skins really helped the flange sit tight against the roof and make a good seal.
I switched to the MaxxAir Deluxe on my motorhome and installed them on my Airstream immediately.
Richard
11018
03-20-2025, 02:23 PM
2022 25' Flying Cloud
NCR
, Ontario
I replaced mine with the fantastic fan 6600R
https://www.fantasticvent.net/
there is a upgrade kit on amazon for < $100 to upgrade to this model if you have the basic fan
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
03-21-2025, 11:25 AM
2015 25' Flying Cloud
Schaumburg
I have a 2015 model year 25' with single A/C (dual fans) and I replaced both with MaxxAir model 5100 (manual crank open). Very straightforward, but be careful about the sealant you use, don't just get garden variety silicone caulk at Home Depot. Lot of threads on the forum about what to use, as I recall I used some Dicor, and I also used some SikaFlex 221. I thought the hardest part of the job is having the dexterity and nimbleness to move around on the curved roof without causing any extra damage ... I did not have to do any aluminum cutting/trimming, the original factory opening was good, but I did have to drill a couple holes for the mounting screws to secure the perimeter flange of the new fans.
03-21-2025, 03:20 PM
1988 32' Excella
Robbinsville
, New Jersey
I believe trimming the aluminum is not a thing for trailers that were made in this century. I know it is needed for a 1988.
