Old 05-12-2017, 08:15 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Bambi II black tank leaking
I have the pie shaped fiberglass black tank in my 1964 Bambi. All looked good when re-gelling the fiberglass. Adapter made for Valterra dump valve. Installed and plumbed. Today I added 5 gallons of fresh water. I thought all was good- then noticed a drip underneath (almost OK when it is fresh water!!)
Initially thought it was where the plastic adapter attached to the tank, but it appears the fiberglass around the original cast-in brass thread plate was wet...so I think it must have a leak in the actual fiberglass around that fitting.
There is some small cracking inside the tank as seen in the one photo. Underside, all looks solid.
Can the inside of a fiberglass tank be sealed? How would one go about that? If this is not an option, I guess we will finish out this camping season with the port-a-potty and have a stainless tank fabricated next year.
Thanks for any insight!!
Ben
ID:	285403   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
1971 Airstream leaking blue liquid from black tank svachon Waste Systems, Tanks & Totes 3 09-19-2012 12:02 AM
Black tank leaking bimpy Waste Systems, Tanks & Totes 1 08-13-2009 01:24 AM
Leaking Black Water Tank ssolid Waste Systems, Tanks & Totes 6 04-10-2009 07:26 PM
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
