04-18-2005, 12:52 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
The bath is out !!
Well I worked on my Caravel all afternoon. I removed the lower section of the fiberglass bath. What a job ! The PO had put expanding foam under the shower pan to hold it up. I guess the fact that there was no real floor left didn't occur to them. Just the top layer of plywood is all that remains in the back of the trailer. I sure hope I can get the enclosure out the door. I am going to have someone else refinish the fiberglass. I just don't have the time to do it. I have pics from todays progress posted in the members photos section. I stopped there. I had to regroup. Now that I am down to removing the rotted floor I have to organize and store everything that came out so I don't have to dig thru everything to put it back in. What came out first goes to the back of the attic and so on. I am wondering how to get my black tank off my shower pan tho. Anyone have any ideas ? The toilet mount that goes on top of the tank was cracked, now it is in 2 pieces. I hope I can get a new one. If I can get it out of the black tank, otherwise it looks like I may be getting a new black tank too. It looks like I may have to cut it off. I sure don't want to buy a tank too. I am nearing the end of the "taking it apart phase". Just a few more steps then it is repair time.
04-18-2005, 06:44 AM
, At Large
Does your black tank sit above or below the floor? If it is above the floor, is it a soft, thick plastic, or a hard (ABS) plastic?
04-18-2005, 09:17 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
It seems like a hard abs plastic. My tank sits on top of the floor. Right under the commode.
04-18-2005, 10:13 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
I do not have a 60's vintage however it sounds like what I found in my '75.
Take a look at my web page and see it this helps??
http://www.balrgn.com/Airstream/airs...oject_2004.htm
(just click on the small pics to see the larger one)
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
2007 GMC Sierra 2500 HD Duramax
WBCCI 1754 - AIR # 6281
www.balrgn.com
07-31-2005, 12:13 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
The bath is back in !!
Yep, the bath is back in. 3 months, 13 days. It was a chore to get it back in since I had done a little re-engineering. But it looks great now. I did scratch it in a couple spots while attaching it. I think I can buff it out, however. I still need to run the sewer lines, finish up the water lines, and attach the toilet. The black tank fit good, if I did it again I would make it 1 inch thinner to make room for the water lines, but other than that my new black tank fits great ! Very happy with it.
I had to finalize this thread. One more hurdle crossed.
It sure came out easier than it went in
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
07-31-2005, 07:43 AM
1967 22' Safari
1960 Caravel
Edmonds
Chris, Your bathroom looks great. I'm convinced that as you remove parts from the inside of the trailer it shrinks just a little bit...
I look forward to seeing the lil trailer all done. Lee
07-31-2005, 02:23 PM
1973 31' Sovereign
Danielsville
Nice Job!
Congrats! Looks really good. Should be downhill from here.
07-31-2005, 03:23 PM
1968 17' Caravel
Battle Ground
Sure is weird to see the bathroom sitting there without any closets or curtain around it. Looks like camping in your trailer might be a little awkward with guests until you get that fixed Good Job, Chris!
Stephanie
08-03-2005, 01:40 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Well the rv store had my flange seal in stock ! Happy day. The commode is mounted and ready to go. The bowl holds water and it flushes great. That 3/4 inch piece of marine ply under the toilet/on top of the black tank worked well to stabilize the fiberglass that the toilet sits on.
Thanks for the positive comments !
Chris
Project 2k5
08-03-2005, 08:30 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
wow, looks great. I just looked at your whole photo album. got a couple of questions:
1: how did you get those large sections of floor in place?
2: you mentioned "apex industries" as the manufacturer of your replacement tank. got a website for them? looks like a pretty decent price for that custom job...alot less than I've seen quoted from others.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
08-03-2005, 08:56 AM
Guest
Nice work. I'm always impressed with someone who takes on such a major restoration. I looked at all of your photos and looks like your making excellent progress. Looking forward to seeing the finished result.
08-04-2005, 01:18 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Thanks for the compliments !
Project 2k5
