Old 05-31-2023, 05:52 PM   #1
1965 17' Caravel
Kansas City , Missouri
Hot hot hot
Good afternoon.
I come to you all as an 1965 Caravel owner since 2021.
Not really needing AC until now!
I was unable to get much information from owner I purchased it from in 2021.
Previous owner did all the work I am guessing.
A window unit was placed inside frame of where it appears a cabinet was removed. So it is in this cabinet frame about 2 to 4 inches from ground.
Underneath it is vented but I feel not very well as it can get hot all around the unit and at times blowing warmer air.
But let me tell you, as of now in New Mexico...workcamping and full timing. Its not what I would call exactly comfortable as I'd appreciate.
I am not unrealistic in this heat but I am hopeful that I can get improvement.
Where I am located I am unable to find a good vintage trailer or airstream contact.
If anyone can advise me of a good resource for vintage trailers/airstream near Truth or Consequences New Mexico, I'd be ever so grateful.
I'd like to either get one installed in roof or consider find a portable swamp cooler? For a 30 amp, is that possible?
I am a travel nurse and am going further South end of July but do not plan on living in it in those temps at that time!
Thank you kindly
rambler1970 is offline   Reply With Quote
Old 05-31-2023, 07:01 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
RE: Hot hot hot
While I can't be of direct help in locating a qualified installer to assist with installing a regular RV air conditioner, I would add a precaution. Unlike a typical trailer/RV of today, the air conditioner in a Vintage Airstream wasn't typically installed in an existing vent opening, rather it was installed in an opening cut a specific number of inches behind the number one roof bow. It was at this location that you would find the 120-Volt AC power cable as well as the condesate drain tube coiled up ready for the install. The existence of this pre-wire can usually be identified by the presence of a wire that isn't connected to the breaker box. The photo below contains the data for locating the opeining for an air conditioner in a 1965 Caravel.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 05-31-2023, 10:47 PM   #3
1965 17' Caravel
Thank you
Appreciate your reply.
My Caravel is 17inches.
So I see where it is 60" from the #1 rib.
Perhaps this is why a rooftop was not installed rather than the existing set up.
I have seen 65's for sale or online with a rooftop AC.
Have a good evening.
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
How hot is hot? tn2 General Motorhome Topics 10 05-21-2007 04:01 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
