08-11-2020, 09:09 AM
1965 17' Caravel
Fairview Heights
65 Caravel missing black tank cap and hose connector
Our 65 Caravel doesnt have any cap on the sewer drain outlet pipe. Can someone steer me towards a replacement as well as what I need as far as a hose connector. Looking to purchase a blueboy and need some way to connect to it.
08-11-2020, 09:16 AM
2018 25' International
Slidell
, Louisiana
Not quite following what you're trying to describe. Are you saying the sewer outlet is a plain pipe with no sewer connect flange fixed to it? If so, what is the diameter? If it has a flange, please describe it.
08-11-2020, 10:44 AM
1974 Argosy 26
Morrill
, Nebraska
Pictures
08-11-2020, 11:20 AM
2002 25' Safari
Dewey
Your sewer connections are thetford unless someone has changed them. The pipe would be white, while more modern pipes would be black and they are valterra. The two sizes are close but not interchangeable.
You could put an adapter on the pipe to convert thetford to valterra and then finding sewer components would be much easier.
https://www.amazon.com/Valterra-T05-.../dp/B0006N5S6C
Richard
08-12-2020, 11:33 AM
1964 22' Safari
1993 25' Excella
Flagler Beach
I have a 1964.....please show pic
08-12-2020, 01:41 PM
1965 17' Caravel
Fairview Heights
It is indeed white. So I will look for a Valterra cap and connector.
08-12-2020, 01:47 PM
1965 17' Caravel
Fairview Heights
Pictures:
08-13-2020, 05:42 AM
1964 22' Safari
1993 25' Excella
Flagler Beach
You need a end cap....I would get the one with hose connection in
the center, very easy purchase.
08-13-2020, 06:40 AM
1974 Argosy 26
Morrill
, Nebraska
If you buy the Thetford to Valterra adaptor. Buy at least 2. The ears break of very easily.
I would recommend installing it with some sealant like Lexell. Then put a couple of pop rivets thru the flange to prevent movement while you are connecting the waste hose.
08-13-2020, 09:34 AM
NO HUMBLE OPINION
1968 20' Globetrotter
ANN ARBOR
, THE GREAT LAKES
tgtwinkie's advise is the convention and correct.
This might work for you…
You can reconfigure the Thetford ears to accept Valterra hooks.
detailed here...
https://www.airforums.com/forums/f48...re-159949.html
Ten minutes on your back with a saw and file =
No need for adapter, spares, rivets, screws, glue. There’s not much room under a Caravel. Another couple inches of clearance aids discharge kinetics
I did this, works great, no leaks, and I can configure everything with Valterra
08-13-2020, 06:51 PM
1974 Argosy 26
Morrill
, Nebraska
Excellent idea!
08-23-2020, 09:20 AM
1965 17' Caravel
Fairview Heights
Ptoblem solved
Thanks everyone for your help. Have the adaptor installed and new hose ordered!!
