05-19-2021, 02:40 AM
#1981
2017 25' Flying Cloud
Fayetteville
, Arkansas
Interested in the approach.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
05-19-2021, 06:56 AM
#1982
2022 20' Basecamp
Missoula
, Montana
I’d love an easier way. We’re on our way home tomorrow and it’s on my list for when we get there. Thanks.
05-19-2021, 11:27 AM
#1983
2018 23' International
Seattle
The cabinet above the dinette in our 2018 23FB International has completely broken loose from the ceiling, being held up by wood screws set into the adjacent forward wardrobe and probably the electrical cables feeding the Clarion and DVD player at the aft end. I found holes for five sheet metal screws and two blind rivets inside the cabinet, right above the sliding doors. On the inside bottom of the cabinet, I found the remains of one rivet and two screws (we purchased this Airstream used when it was less than one year old, so I don't know its complete history).
When this happened, we were on the road, but in a position to build a support structure held in place by duct tape so we could continue our trip.
One week ago, I called Jackson Center to get some assistance on this, but haven't heard back.
Curious if this has happened to anyone else? Any suggestions on how to fix the problem? While we have owned this trailer, there has been no trauma that would explain why this would happen (I usually drive under the speed limit and am very careful).
Prior to returning home, we put one of our cell phones inside the trailer and called the other one up front with us. While underway at freeway speeds, we could not hear any sounds indicative of vibration.
05-19-2021, 10:34 PM
#1984
Seattle
Originally Posted by cajohnson
We are about a month into a six week road trip and the step on our 2018 23FB isn't staying completely up in the retracted position when we're on the highway. It comes partway down.
Anyway it looks like the shoulder bolt on the right side has backed out so it's not riding on the shoulder of the bolt but on the threads. Since its installed from the outside of the steps (inside the belly pan) I want to make sure I need to remove those rivets to remove that small black tin piece to get in there and add a little Loctite and cinch that bolt back down.
Anyone know for sure?
CJ
Our shoulder bolt eventually came completely out. While it was unthreading, the steps weren't anchoring well when extended. With the bolt completely out, the steps did not hang down when in the retracted position. However, with the steps extended, the side of the steps with the missing shoulder bolt hung down considerably, rendering the steps useless. I was able to verify the bolt was resting on the inside of the bottom aluminum panel by hitting it with my palm (I could hear the bolt bounce on the bottom of the panel).
The first time this happened, I had the repair done. After picking up the trailer, we went on a one week trip. When returning to our house, the shoulder bolt on the opposite side of the first repair fell out as we lowered the steps in our driveway. The receipt for the previous repair indicated new rivets were installed on the bottom panel on the repaired side. However, these rivets simply didn't look new, as they had an appearance very similar to those on the side that just failed. I concluded there must be a way to reinstall the shoulder bolt without removing the panel.
I have an 18" flexible magnet pickup tool. I inserted it into the space enclosing the shoulder bolt at the point where the shoulder bolt sets when the steps are extended (it is a bit wider there). Within minutes, I had fished it out. Keep in mind you can move the bolt by strategically hitting the bottom of the lower panel with your palm.
The next task was to take apart the side of the steps with the missing shoulder bolt (that side required support as I disassembled it). The step segment to which the shoulder bolt attaches also anchors the top step. Removing the step bolts required a hex socket, but I was able to remove the other bolts with Allen wrenches. Once this segment was detached from the steps, I attached to it the same shoulder bolt I had fished out using blue Loctite (didn't want to make it permanent, as I might need to disassemble the steps at a later date). Then, holding this segment at an angle, I was able to slip the shoulder bolt through the slot at the same point where I fished it out. The steps were then reassembled.
I decided not to use Loctite on the other step assembly bolts, as some of these bolts are removed by relatively small Allen wrenches. I will monitor them periodically and just might reinstall them at a later date using blue Loctite.
If you obtain a schematic of the steps, it shows a nut should be on the end of the shoulder bolts. As there isn't a significant amount of thread available for a nut, it would need to be one that isn't too deep, ideally self locking. Not certain why they aren't used.
Your situation sounds a bit different, but you should be able to disassemble the steps as I described, slip out the aforementioned segment with the shoulder bolt attached to it, then finish the repair. It actually would be a bit easier, as there would be no need to fish out the bolt.
Note the threads of the shoulder bolt were not damaged while it was unthreading. Between the shoulder part of the bolt and the threaded part, there is a an area that has no threads. I suspect that part of the bolt essentially became the shoulder until the bolt completely fell out.
05-20-2021, 06:26 PM
#1985
Wolfwhistle
Margaritaville
, Banana Republic
So, here's a FYI on my 23FB (twin DIY conversion) about tongue weight.
A near complete list of mods: twin bed conversion, jackknife sofa, elongated toilet, vessel porcelain sink, 5 Renogy Eclipse panels, Trimetric, a single 170Ah Renogy Li battery, 3000w inverter -
Without WDH hardware of any kind, TW was 575 - 580# (full fresh, propane, empty holding tanks)
Empty the fresh tank (39 gallons - 323#) and TW is 510... so 65 lighter on the tongue and about 258 lighter on the tires without cool clear water.
Hensley Cub weighed 160#
I reluctantly put up with a RVSA tech almost all day, whom I had to lead by the hand when it came to my cutoff switches and 50 amp panel converted to 30A main and sub... really all things 12 volt, confused him. In the process my Sony radio is no longer working. I shared this with him and he said he has liability insurance but might not cover since the cutoff switches were not installed by RV certified tech... I am biting my tongue for the time being. An amateur installation kept the radio working for 3 years, while 6 hours with a certified tech left it Inop.
FE
Is taking it all with you, really getting away from it all?
05-21-2021, 07:29 AM
#1986
1975 29' Ambassador
2019 23' Flying Cloud
Beach Park
Wiring/water pump switch
Every year I winterize the water system with air pressure. Including the 12vdc water pump. I made a cheater hose I connect to the input side and run the pump with 20# pressure. Works well.
Well I break out the trailer to prep for a trip and always pressurize the city water system to check for any leaks. All's well over night. I then run city water through the system and half fill the fresh water tank. I let the city pressure drain to zero and switch on the pump.
Nothing running. Checked fuse OK, check wiring OK, What's left the switch? I pull the panel out and find that one of the wires to the switch had fallen off.
Figured out why, there is a bundle of wires in that wall and the weight of them hanging and bouncing was to much for the connector to hold. So after reconnecting and having power I took a small loop bracket and a short (1/2") screw and attached it to the wall behind the switch panel. Then cable tied the bundle up to remove the weight hanging problem.
AIRSTREAM are you listening simple $.50 fix.
05-22-2021, 10:43 AM
#1987
2013 23' Flying Cloud
Naples
Glad you started this. My 2012 23D FC has a broken burner on my stove. The wiring just snapped off. Has anyone had this occur and, if so, how did you repair? Thanks.
05-22-2021, 02:36 PM
#1988
2014 23' International
Hurst
Hi, Barretta2... are you aware that there is a dedicated 23D thread? Here 'tis: https://www.airforums.com/forums/f14...ad-166085.html
05-23-2021, 10:38 AM
#1989
2022 20' Basecamp
Missoula
, Montana
Steps
Chrisnancy...
Thanks for your detailed instructions on the step repair. Very much appreciated. Just got home to Montana after a month on the road and as soon as the rain stops I’ll dig into the job. Thanks again.
cj
05-28-2021, 07:12 AM
#1990
2008 23' Safari SE
Oklahoma City
, Oklahoma
Equalizer Hitch Setup
I need help with up the hitch setup. Truck is F150. Trailer is 23FB that has been modified to twin beds and 250 watts of solar on the roof. I weighed the truck first pretty well loaded for camping. Trailer is loaded for camping, but no fresh water and tanks empty
Steer Axle- 3280
Drive Axle- 2980
Total WT 6260
W/O WDH
Steer Axle- 2980
Drive Axle- 3860
Trailer Axle- 4960
Total WT 11800
W/WDH
Steer Axle- 3180
Drive Axle- 3600
Trailer Axle- 5040
Total WT - 11820
Does this setup look OK? Should I add more weight to the steer axle? Thoughts please.
Mike
05-28-2021, 07:27 AM
#1991
2023 27' Globetrotter
Centennial
It seems each year when I winterize I am doing so as a snow storm is moving in - hurrying home to blow out the lines in freezing cold weather. For 2020 I forgot to open the shower line and now here I am at Lake MacConaughy in NE with a shower leaking all over the place. Ideas? There is an Ace Hardware not to far from here. I have the panel open and there was/is water leaking. Never fails!
Janice
2023 Globetrotter 27’
2024 GMC 3500 Denali Ultimate
#9430
05-28-2021, 12:55 PM
#1992
Seattle
Steer Axle- 3280
Drive Axle- 2980
Total WT 6260
W/O WDH
Steer Axle- 2980
Drive Axle- 3860
Trailer Axle- 4960
Total WT 11800
W/WDH
Steer Axle- 3180
Drive Axle- 3600
Trailer Axle- 5040
Total WT - 11820
Mike
We use a Blue Ox load redistribution hitch, which transfers weight from the rear truck axle to the front truck axle at the expense of putting more load on the trailer axle. It also provides sway protection. Another benefit: with the trailer and our F-150 aligned, I can usually open the tail gate all the way.
05-28-2021, 04:30 PM
#1993
Seattle
Sorry, just realized what WDH means. Not certain about the change in weight distribution before and after the WDH, but I would expect more of a change. We were told to adjust the WDH so the trailer was the same height above the ground at the front and the back. With this adjustment, the angle between the truck and the trailer at the hitch is near zero.
06-01-2021, 08:32 PM
#1994
Wolfwhistle
Margaritaville
, Banana Republic
Well friends, my 23FB has been sold to a nice Army Captain who plans to full time in it as she serves our country. I salute her and I salute all my friends and acquaintances on this group. I have learned alot and hopefully have helped someone along the way.
Fair well.
06-02-2021, 10:37 AM
#1995
SR
2014 23' FB International
DFW
Originally Posted by Fair_Enough
Well friends, my 23FB has been sold to a nice Army Captain...
Hoping you stick around on the forum with your wealth of information.
06-02-2021, 07:33 PM
#1996
2013 23' FB Flying Cloud
Burien
Experience with rear hitch bike rack on 23FB
We’ve read through many threads on bike rack options. The Fama racks we’ve seen don’t impress. Notwithstanding the often noted objections to rear hitch mounted configurations, this seems like the best option. If anyone has *experience* with a rear hitch setup on a 23FB we would appreciate any info on what you did and how it has worked for you. Thanks!
06-02-2021, 09:23 PM
#1997
2014 23' FB Flying Cloud
Anchorage
, AK
Electrical problems. Need help. 2014 FC 23FB
CoVid weirdness kept me away for months! Plug in shore power and can’t get refr or microwave to work. Dig into the distribution panel beneath the fridge. With batteries in storage, in use, or with shore power plugged in, the 30 A fuse blows immediately.
I hoped to begin troubleshooting and removed all of the 15A fuses, hoping to isolate one circuit. The 30A blows right away. I turn off all of the circuit breakers to the left and the 30A blows right away. Dang!
We are on a quick 2 week trip with no extra time to schedule a diagnosis, so I’m hoping that turning to this may help. TIA. BTW in South Tahoe for a few days, then to Kings Canyon, then Morro Bay befiore heading back to Vegas for storage.
Any idea as? TIA
06-03-2021, 04:22 AM
#1998
Wolfwhistle
Margaritaville
, Banana Republic
Any idea as? TIA
I assume you are saying the main 30 amp breaker trips. Breakers protect like fuses but are not fuses. Removing fuses (to the right) has nothing to do with a breaker tripping.
Battery in "use" or "store", then has precious little to do with breakers. Other than, the converter will draw more power (120vac) while charging when in "use" mode.
Are you saying while plugged in to shore power, you turned off all breakers, other than the 30 amp main and the main trips?
My next step would be to actually remove all the other breakers and see if the main trips.
If it does that would point to a bad 30 amp breaker. Either that or there is something in the load center grounding out the feed rails to the other breakers, which is very unlikely. Assuming no rodent nest in there.
Unplug from shore power while hands are in the distribution or load center. Do your thing, then plug back in for testing.
Let us know what you find.
FE
06-06-2021, 10:24 PM
#1999
Anchorage
, AK
Fuse blowing
No, This a 30A fuse, not a breaker.
Wiring diagram on page 8-19 in lower LH corner shows the Parallax 7355 controller. In the top row, the fuse on the right. M8 controls the 12 V system. No idea where to begin looking. All worked fine before it was stored pre-Covid., Lights and roof fans work fine on battery charge. Battery pack charges fine from the tow vehicle. I would REALLY like to have the fridge work, but even on propane, I get nothing. Weird.
06-08-2021, 04:15 AM
#2000
Wolfwhistle
Margaritaville
, Banana Republic
Microwave only uses 120vac, no DC required (my confusion when you said MW doesn't work). No shore power, no MW.
Fridge does requires 12vdc even when running on propane.
From memory, since I replaced Parallax and entire load center... there are 2 30amp fuses. They are there to prevent damage if battery positive and negative are reversed. Where batteries disconnected and reconnected... did you reverse the leads? That would immediately blow one or both 30 amp fuses.
The other possibility is the crappy Parallax has bit the dust
FE
