01-09-2021, 06:58 PM
#1901
Walnut Creek
Originally Posted by missaviatrix
-- snip -- reputable facilities set-up for this type of custom work.
Switz has a Texas vendor that has done custom work for him. Either PM him or search the 23 threads. He has a D, but posts here too. I think he posted the name of the company, but it was in or around the beginning of this thread.
01-09-2021, 08:14 PM
#1902
2017 23' Flying Cloud
Bartlett
, Tennessee
Originally Posted by Rntennis
Poopouri toilet spray works great for bathroom smells, if you have not tried it, it may increase your comfort level with the bathroom.
One Christmas, I was given a bottle of Poopouri as a gag gift. (I don't know why.) It actually did work as advertised.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
01-10-2021, 05:27 AM
#1903
Wolfwhistle
Margaritaville
, Banana Republic
My thoughts on a bathroom vent.
If you add a small vent, you still need to provide a way for outside air to enter. This is not your sticks and bricks home that leaks air in from gaps and cracks.
I think it would be better, if using the rear window for that purpose, that there is a way to "lock" it in a barely open position. Never looked at that but I will.
I noticed that newer models the bathroom door has no gap at the top like mine does. I am sure that is for bathroom exhaust and I am sure AS knew you have to have the rear window open. Did they consider what that would be like in Winter, probably not.
Keep in mind our trailers are not close to being 4 season "comfortable".
FE
Is taking it all with you, really getting away from it all?
01-10-2021, 07:43 AM
#1904
2021 23' International
P
Originally Posted by Dennis C
It wasn't possible for Airstream to put another exhaust fan in the bathroom because of the curvature in the ceiling of the end cap. This wasn't an oversight, and again, it works very well if you understand how to use it.
Maybe they could have fit a fan near the toilet vent?
01-10-2021, 07:48 AM
#1905
Evergreen
Doesn’t seem like it would have been that difficult, but they made the decision to skip the vent fan. So we’re stuck with the Fantastic Fan just outside the door.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
01-11-2021, 06:28 AM
#1906
Wolfwhistle
Margaritaville
, Banana Republic
New subject and seeking help / advice. I need to replace the seal around the screen door. I know what it there, what there is of it, is not original. What is the correct way to seal the screen door to the jam / surround?
I tried searching for it, but I get a zillion hits because of "door", apparently the search here is for every word, not specific combinations of words or phrases.
FE
01-11-2021, 08:06 AM
#1907
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Check the online parts catalog at Airstream for your year and model trailer. Or call Airstream and ask them. The information will be from the horse's mouth.
01-17-2021, 10:05 AM
#1908
Evergreen
I recently purchased a LevelMate Pro for my 23FB. I’ll install it before the spring camping season begins. For those of you who have installed one in a 23FB, where did you mount the transmitter unit? It needs to be mounted on a flat surface that is parallel to the long axis of the trailer. I am considering mounting it inside the bathroom cabinet, or inside the small cabinet under the street side wardrobe. My concern with mounting it in the bathroom is that the transmitter will be too far away from the truck to provide a reliable signal.
Dennis
Past:
Newmar Ventana 3715
01-18-2021, 05:40 AM
#1909
2013 23' FB Flying Cloud
Lakewood
Mounted the transmitter inside the driver side overhead cabinet above the bed, outside cabinet wall. No signal issues
01-18-2021, 05:55 AM
#1910
New Hyde Park
, New York
Dennis,
We mounted our below the bank of switches as you open the entry door. Easy to switch on/off. Distance not a problem.
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
01-18-2021, 06:42 PM
#1911
Dania
Mattress in FB // new owners
Hi all!
My fiancé and I are new owners of a 2015 23FB. We are loving reading through the threads and learning new things.
I’m sure I will have more questions coming up.. but for now I’m curious about bed/mattress modifications. I’ve searched this/other threads a lot but haven’t come up with much.
Has anyone put a regular sized Queen foam mattress in the 23FB? I understand the width should be almost the same but that the length might be a little long. We are contemplating cutting our foam mattress so that it fits on the bed base that is there. We just are not fans of the spring mattress (or at least it feels like springs) in the 2015 stock mattress.
Thanks!
01-18-2021, 06:51 PM
#1912
Dania
May be a silly question but I’m a newbie.. poo pouri is ok to use in the AS toilet correct? Guessing it’s safe and won’t break down plastic in the tanks?
01-18-2021, 08:01 PM
#1913
Evergreen
Originally Posted by eagletoo
Dennis,
Am I wrong in thinking that the transmitter needs to be mounted on the long axis of the trailer? It sounds like yours is perpendicular to the long axis.
Dennis
Past:
Newmar Ventana 3715
01-19-2021, 03:32 AM
#1914
New Hyde Park
, New York
You can mount the transmitter in any direction that works for you. It just needs to be somewhat level. You must select the direction of the unit when you originally set it up.
Bruce
01-24-2021, 05:09 PM
#1915
Evergreen
I installed the LevelMate PRO today, and I put it on the wall by the switches, as you suggested. Thanks for the tip. I'm looking forward to using it on my first trip in 2021.
I used my long level on the floor to level my trailer and set the zero values for the transmitter. I don't know if that's the best place to level the 23FB, but it seemed to be good. I've noticed that the level readings on the floor are different from those taken on the counter top, or the back of the dinette.
Dennis
Past:
Newmar Ventana 3715
01-25-2021, 06:14 AM
#1916
New Hyde Park
, New York
Under the various switches works well since you can easily reach the Pro on/off switch from just inside the entry door. I also use a 2’ level at the door. When the bathroom door and refrigerator door stay open/closed, mama is happy. Enjoy!
Bruce
01-30-2021, 06:52 AM
#1917
Wolfwhistle
Margaritaville
, Banana Republic
Originally Posted by C.Carlson
Hi all!
Thanks!
I had a full length queen in my 23FB before I converted to twins. The mattress had to be ordered custom made by the previous owner, with the curve at the head of the bed like the shorter original had. An off the shelf regular queen would be an issue in that without the curve at the head, it would stick out even further at the foot and not fit well. Also, the platform foot (the plywood) should be remade to support the mattress at its foot; mine was not.
FE
01-30-2021, 10:24 AM
#1918
2014 23' International
Hurst
The place is A & P Vintage Trailer Works in Paradise, Texas, just north of Fort Worth. Ann and Paul do superb work.
https://www.apvintagetrailerworks.com/
01-31-2021, 02:12 AM
#1919
2020 23' Flying Cloud
Reno
Black spots on vinyl floor!
Has anyone else had or seen this happening to the vinyl floor. This discoloration is slowly spreading to the entire floor. I saw another thread about glue and filler used by AS causing this. However, this was noted to be yellowish stains.
02-01-2021, 06:46 AM
#1920
Toronto
, Ontario
I had a similar thing happen on my 2020 23FB... I wish I had better news for you but it it was because of a leak(s) in my plumbing. I assume you the new composite floor? The discolouration is because the water is trapped between the impermeable subfloor and flooring. The good news is that my dealership replaced the entire vinyl floor, not a quick process because the entire interior needed to be removed and replaced. They claim Airstream was still not clear if they would pay for the work or the dealership. Regardless I would bring that in right away to your dealership.
Good luck!!!
