10-07-2018, 06:52 PM
#861
Walnut Creek
New subject - the denser foam on the seat cushion makes them more rigid. That squares them up. Consequently, the drag of the frig door on the front cushion is not present unless the cushion is not positioned correctly on the seat base. Being able to open the frig door when seated in the dinette helps a lot.
Also found a temp solution to additional storage. We are using a Costco clear plastic box on it's side behind the table. Sitting on the cushion it provides storage for paper goods.
Found the table is much more stable if the lock pin is rotated into it's locked position. Convinced I knew it locked, but got out of the habit and forgot about the feature.
It helps to travel in your rig. Lots of little things show up to improve it's use.
You all stay safe out there. . Pat
10-08-2018, 04:43 AM
#862
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Where did you get the denser foam? If you wouldn’t mind.. Sorry if you’ve already posted it.
Also, your statement about travel “in” your rig, are you saying you’ve spent some time in the trailer as someone else puts it down the highway? I’ve thought about doing that, but just haven’t taken the time. I’m sure there’s a few here that will point out the safety or legal issues, but I’ll take the chance. I’m just curious what you noticed?
Thx
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
10-08-2018, 08:55 AM
#863
2014 23' International
Hurst
< snip >
Thx
Well, I'm not the person that you asked but I have some very recent experience with this...
Here is the foam I bought: https://www.foambymail.com/LHQ/lux-h...lity-foam.html
And here's where I posted my experience to the 23D thread: http://www.airforums.com/forums/f142...ml#post2163864
We absolutely could not be happier!
Rob
10-09-2018, 06:28 AM
#864
Wildwood
, Missouri
Thanks Rob. We have just the two bench seats with seat backs. I think the seat backs are ok, but the seats are too soft. Even though we’ve been using them for 8 years. This might change the comfort of the bed when we convert the dinette, but that’s been twice in 8 years, and our guest was happy to get a place to sleep.
2020 25GT FBT
10-12-2018, 06:46 PM
#865
Walnut Creek
We just replaced the seat cushions. Cheated. We had our local upholstery shop replace the foam with high density material. Very happy with result.
Search for other posts to get more info. Several folks have made the upgrade. It is not just a 23 model change.
Ride inside. No,the Lacy ride was enough to deter that thought. The comment was about getting out and using the rig. The more you use, the more you learn.
We also are experimenting with alternate storage, shifting the table top for easier seating, and considering alternate back cushions to provide lumbar or just a thinner surface for more table clearance. Also found that sitting in the car on a rainy afternoon was reasonably comfortable seating for a couple of hours. Never would have considered the option under normal circumstances.
Stay safe on the road. We want to see lots of smiles. Pat
10-15-2018, 03:59 PM
#866
2022 20' Basecamp
Missoula
, Montana
Inline water filter on 23FB
I'm just winterizing our 2018 Flying Cloud 23FB for the first time. On our old 19' FC there was an under-sink water filter you took out and replaced with a hose for winterization. I can't find one on this model. Is there one and if so where is it.
Thanks.
10-15-2018, 05:48 PM
#867
2015 23' FB Flying Cloud
Omaha
, Nebraska
Our 2015 has a filter under the galley sink upper right hand cupboard. Also has a replacement pipe.
10-16-2018, 05:44 PM
#868
Walnut Creek
My understanding was that the late model coaches do not have the internal filter. As above, our 2015 was fitted to accept one under the sink. We never installed it and use an external filter. Adding extra fittings increases the number of potential failure/leak points, so the elimination of an internal filter sounds like a good decision. Pat
10-17-2018, 10:03 AM
#869
2018 23' International
Austin
I have a 2018 and it doesn't have the filter anymore.
10-17-2018, 10:20 AM
#870
2019 25' Flying Cloud
2018 23' Flying Cloud
Ocala
, FL
Same here.
10-18-2018, 06:27 AM
#871
2022 20' Basecamp
Missoula
, Montana
Battery life?
That's what I thought. And assumed - which is why I went ahead and winterized.
Last trip out was last weekend (three hours north to Glacier National Park). Plumbing has been winterized and after a good inside/outside cleaning this weekend it'll be buttoned up for the winter.
So far I've had time to read through the first eight pages of the 23FB forum. I'll get it wrapped up next week since I'm having rotator cuff surgery. That'll force me to slow down, smell the roses and read the forum.
Anyway, I mention that because I don't know if this has been covered or not. Is anyone else having trouble with battery life?
On our 2015 19 foot Flying Cloud Bambi it was pretty easy to keep the batteries up above 12 volts while boondocking. We almost never needed to supplement the charging with our generator when out for the weekend. That's not the case with the 23FB.
Did Airstream put in cheaper batteries? I can't believe we're using substantially more power. I know the fridge is bigger and there's more to heat etc. but it seems like a dramatic loss of battery life.
cj
10-19-2018, 06:29 PM
#872
Jackson
, Oh
Winterizing our 2018 23FB Flying Cloud. Previously had Casita so have experience winterizing that. On the 2018 23FB I drained fresh water tank, opened low point valves coming out of fresh water housing. There are also two black low point drain knobs inside the compartment under the pantry. Can't get those to turn. Don't want to force them and break something. Any ideas? Thanks!
10-19-2018, 07:14 PM
#873
2017 23' Flying Cloud
Bartlett
, Tennessee
Turn harder. They are stiff.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
10-19-2018, 07:44 PM
#874
Walnut Creek
Think the low point valves are under the coach. Suggest a call to your local service department and a review of your manual to clarify the location of the low point valves.
It is likely that those valves under the pantry are isolation valves which are open to allow normal flow. That would make it hard to open them any more, so do not try.
Since the 2015 we have may be different than your newer model, take care in how you proceed.
Let us know what you find. Should add to the collective knowledge.
Pat
Edit - since we have a conflict in information - take care. It is possible that since our unit was winterized when we got it, maybe our valves were open from day one. Interested to hear what you find.
10-20-2018, 05:30 AM
#875
Wildwood
, Missouri
I have a 2011, and the same two valves in the compartment below the pantry. Mine open and close without much effort. I always drain them when winterizing, along with the two that are beneath the fresh water tank. Don’t forget the bypass for the hot water tank. I have the line added in by the pump. It draws the antifreeze right out of the jugs. Really makes it pretty easy. I blow the lines out first. It seems like belt and suspenders, but it’s peace of mind for me.
2020 25GT FBT
10-20-2018, 09:12 AM
#876
2022 20' Basecamp
Missoula
, Montana
I found the shut offs under the pantry hard to open but they did and they did drain a little additional water. I however have been known to screw things up in the past so please don’t confuse me with a guy who knows what he’s doing.
10-21-2018, 06:38 AM
#877
Wildwood
, Missouri
Ha! I should add your disclaimer on all my posts.. I’ve been known to take a project or two into a shop for completion.
2020 25GT FBT
10-22-2018, 12:30 PM
#878
Walnut Creek
All you 23 owners with 2017 and newer units. Are the wheels 5 or 6 lug?
Considering an upgrade on the brakes and looking for a path forward. Disk brake kits exist, but it should be easier to install 12" drum assemblies to replace the 10" units on our 2015. A half loaf solution, but would fit or current needs. Unfortunately, I'm not finding the solution I thought would exist.
Your help is appreciated if you have any information. Pat
10-22-2018, 12:50 PM
#879
Ocala
, FL
6 lug
10-22-2018, 02:15 PM
#880
Walnut Creek
Thank you very much. Not happy with the answer, but it's what I suspected.
Pat
