Old 05-09-2023, 04:57 PM   #4561
weirdstuff's Avatar
2018 23' International
SANTA BARBARA , CA
Originally Posted by Genebuilder View Post
I’m looking to downsize to a 23 but cannot decide which model. I like the bed set up in the FB but not the dinette. I like the seating arrangement of the D (CB) but not sure about the bed.
Would like to hear comments about the ease and feasibility (or not) of two older adults navigating the 48” wide, narrow entry bed.
Thanx in advance!
The corner bed sucks. We (two adults, age 60+) put up with it for almost 5 years. Now one of us sleeps up front in the lounge area, and we're happy again. We love our 23D, and have done trips as long as 6 months in it. The ability to lounge in the lounge or at the dining table, make it 100% better for us than the 23FB would have been. Also, our dog has more space and options for lounging in the 23D.
weirdstuff is offline   Reply With Quote
Old 05-09-2023, 11:03 PM   #4562
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
The 23D thread
Agree with weirdstuff. I can give you real world because I had a 23FB and sold it and switched to a 23d. I’m single. Even so, I hated the FB. Loved the bed and bath, could not live with the dinette. The only place to sit, not comfortable and a view of the kitchen sink. And nowhere for the pup to be out of the way and not underfoot.
The switch to the 23d was massive in terms of livability. With the lounge, it was so much more comfortable. If I were a couple, I’d do what weirdstuff and RFP (rob) do—one person sleep on the lounge. No need to even pull it out—just remove the back bolster cushion at night and it’s plenty big enough to sleep on. And plenty of room for a pup under the dinette.
Or For best of both worlds, get a 25’ that gives the lounge, bigger bath/shower setup, queen or twin bedroom, and a half foot wider.
pcskier is offline   Reply With Quote
Old 05-10-2023, 01:30 PM   #4563
weirdstuff's Avatar
SANTA BARBARA , CA
Originally Posted by pcskier View Post
......one person sleep on the lounge. No need to even pull it out—just remove the back bolster cushion at night and it’s plenty big enough to sleep on. And plenty of room for a pup under the dinette.
thanks...I forgot to mention, that we actually removed the back bolsters from our trailer and we store them at home. So, as pcskier said, the lounge is plenty wide enough to sleep on without even pulling out the pull out. And this gives us more space during the day to put stuff, or for the dog to spread out on, etc..
And, oh yes... maybe just get the 25' trailer!! We got the 23 because that's the biggest we could fit in our driveway at the time. Otherwise, would have gotten the 25. But, now that we have the 23, we have no intention of upgrading.
Old 05-12-2023, 07:17 AM   #4564
Rdavenp3's Avatar
2019 23' Flying Cloud
South Lyon , Michigan
My SeeLevel II fresh water sensor is randomly showing “Opn”, and I believe it may be a loose connection at the sensor. Has anyone opened the belly pan and can give me some pointers or share photos on the best way to get at the sensor?
Rdavenp3 is offline   Reply With Quote
Old 05-12-2023, 12:53 PM   #4565
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
I had the same issue on my classic last year I had a water pump leak. The reason I share that is I never had a water leak on the water pump that was not in use. There is a check valve that fails in the pump. The water was leaking around the bypass dripping down on the sensor, giving me a false reading, that was my case. I know you case may be different however I would call Garnet and visit with them before I did anything. They are really great at helping you track down issues.
Garnet US Inc.
5360 Old Granbury Road
Granbury, TX 76049
Toll Free: 1-800-617-7384
Fax: 817-573-0005
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 05-12-2023, 06:18 PM   #4566
Rdavenp3's Avatar
Garnet US Inc.
Granbury, TX 76049
Fax: 817-573-0005
Thanks. No leaks at the pump and the check valve is good. I’ve bounced my 23D down some rough roads and would be surprised if there wasn’t a loose wire.
Old 05-18-2023, 01:48 PM   #4567
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Well friends, we've done it. Placed a "for sale" ad for Fortune Cookie. I've got to go be sad for a while.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is online now   Reply With Quote
Old 05-18-2023, 04:22 PM   #4568
2008 23' International
Berkeley , California
Strange Fan Sound below Fridge/Fuse Panel
hi All
i have an 08. i've had it almost 3 years. just this week there is a fan type sound emanating from under the fuse panel... is this fridge cooling? i have not had this issue before. it comes on approx every 30 mins and for about 20 seconds... then off! annoying. especially at night while trying to sleep. thoughts? i have not changed the fridge settings or anything...
RedwoodDrmz is offline   Reply With Quote
Old 05-18-2023, 05:09 PM   #4569
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by RedwoodDrmz View Post
hi All
Yep, it's the cooling fan in your converter. Very likely just a nuisance-noise. The fan will eventually croak, you can deal with it then.
Or now (!) You can remove the screws holding the converter cover on and thenremove the screws holding the converter chassis to the wood cabinet front (it's a lot easier than it sounds). Then you can pull the converter out far enough to see the fan. Clean it thoroughly and see if it helps. That's about all you can do short of replacing the fan (or the entire converter).
And some stuff
Old 05-18-2023, 05:16 PM   #4570
2014 27' FB International
Lewisville , Texas
Rob
This is indeed a sad day, for more reasons than one. Sounds like it is time for a strong drink!
If you can not have one, I will have several in your homage. On second thought, hearing this news, I will have several one way or another .................
NO NOIZE is offline   Reply With Quote
Old 05-19-2023, 06:48 AM   #4571
centennialman's Avatar
2016 23' International
Centennial , Colorado
Rob...you have been on my mind. I am sad, along with you and am grateful to you for the inspiration to purchase my own 23d International Serenity. Every time I come in the door I look around and am further inspired by your posts, ideas and advice. Please keep in touch here and let us hear from you.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 05-19-2023, 12:28 PM   #4572
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
I would first remove the SeeLevel II from the wall ( there are four screws) and see if it starts reading correctly. Mine did. When I screwed it back to the wall it went wonky again, so I lined the back side with electrical tape the. Reattached it to wall and fixed the bad readings. Good luck
FloydCoVa is offline   Reply With Quote
Old 05-19-2023, 12:44 PM   #4573
FloydCoVa's Avatar
Rob, me too. I have been thinking a lot about you and Linda selling your Fortune Cookie. You have inspired me not only to perform my own repairs but also make it better. As you know I have followed you and taken your advice along he way. I want to thank you as every trip we taken Maine , UP Michigan, Grand Tetons/Yellowstone and now sitting in Dead Horse Point Utah have been flawless except for a couple of minor things. As you know I’m not the best wordsmith but I trying lo let you know I wish you and Linda the very best. Thanks Scott and Natalie aka floydcova.
Old 05-19-2023, 03:18 PM   #4574
2007 16' International CCD
Somewhere , Colorado
Rob — so sorry to hear that you are selling your perfected Airstream. Our first Airstream was a 23’ and I have been following this thread for years. I have always appreciated and enjoyed your positive attitude and creative solutions. I will continue to to think of you every time I open and close our curtains with your brilliant magnet fasteners!
Very best wishes……..
field & stream is offline   Reply With Quote
Old 05-20-2023, 01:50 PM   #4575
Josephine517's Avatar
2017 23' Flying Cloud
Beavercreek , Ohio
Before opening the belly pan you may want to replace the display unit first. I had a similar problem start last year on our 2017. I got Opn error codes at times, erratic levels displayed sometimes, and at times seemed to work correctly. I tried cleaning the display contacts on the back of the unit with no success. I took a shot and replaced the display since that would be easier than removing the belly pan. The new display corrected the issue.
Josephine517 is offline   Reply With Quote
Old 05-20-2023, 01:56 PM   #4576
RFP
RFP's Avatar
Hurst , Texas
Thank you SO much to all my Forum friends!
I am so grateful for the kindness, thoughtfulness, and encouragement from all of my great Forum friends... you are the best!
It looks like sweet "Fortune Cookie" will be going to a wonderful new home in Colorado! Steve ("Centenialman") put a couple of his friends in touch with me and the rest is history! Thanks, Steve!!
I suppose it says something about this 23D in that it sold in roughly 22 hours!
Knowing that it is going to a great new home does go a long way in making this easier for Linda and me!
And some stuff
Old 05-20-2023, 05:34 PM   #4577
Nelson428's Avatar
2015 30' Classic
Rob, it’s more like just turning the pace and reveals new chapter. I’m quite sure your adventures will continue …… just different. I wish y’all the best in the new chapter and adventures. I have been an avid reader and adaptor of your ideas.
Thanks for all the contributions and keep in touch.
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Old 05-25-2023, 07:58 PM   #4578
Rdavenp3's Avatar
Thanks! I’ll take a look into that since I really wasn’t looking forward to opening up the belly pan.
Old 05-27-2023, 02:24 PM   #4579
Beavercreek , Ohio
After the new display worked great for several trips, today after filling my fresh water tank for our next trip I got the OPn error code. I watched the display as I was filling. After the fresh tank read 100% I turned off the water and put my hoses way. Went back into the trailer and got the dreaded OPn on the fresh tank. Battery voltage readout is good, Grey and Black tanks read zero. I’ve tried to clear the error by disconnecting everything and reconnecting but no luck. Perhaps the new monitor isn’t the fix I was hoping it was.
Old 05-27-2023, 03:26 PM   #4580
Beavercreek , Ohio
Well… I decided to try a couple recommendations I read here in the forums with holding down the tank button and battery button at the same time to force the unit into DIA mode. No luck for me. I then decided to empty my fresh tank to try the DIA mode again but with an empty tank. Right after the tank went off full the monitor started to provide correct readings. So for now… it’s working. I hate dumb luck. I have no idea why a full tank would give a OPn error.
23d
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests)
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
