RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-21-2020, 05:25 PM   #1
2012 16' Sport
Northville , Michigan
Master flush toilets. 8120 macerator
Lost my water supply coming into my toilet. Water worked everywhere else in my 2018 26ft RB FC. Found the water valve in the area behind the toilet switch which was accessed through a panel door in our storage cabinet.
Water valve was jammed and would not function. Even though itís kind of hard to get to, it can be easily removed by uncoupling both the water intake and output along with two spade wire attachments.
The bottom portion of the valve assembly is listed on the Dometic parts list as ďwater valve kit # 385311882Ē, but as I found out, they changed the part number recently to 88074.
If you canít get a replacement part right away, I made a manual water valve that can work temporarily.
If you need to order the valve assembly, I strongly suggest contacting Ardemco Inc in California (authorized Dometic parts supplier) at 9497227672. They had a great customer service dept and excellent service.
Hope this helps.
NMSUMIKE is offline   Reply With Quote
Old 02-22-2020, 04:43 AM   #2
Kensington , Maryland
Excellent work.
I am also looking for a spare relay.
I think this works : https://www.environmentalmarine.com/...-relay-311579/
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Trailer Toilets Tin Hut Sinks, Showers & Toilets 4 01-31-2004 07:28 PM
Cats and toilets SilverStreaker The Pet Forum 17 11-09-2003 05:36 PM
Toilets! spinolio Sinks, Showers & Toilets 11 07-07-2003 11:23 AM
toilets and accesories xtrm69 Sinks, Showers & Toilets 1 02-26-2003 10:14 PM
New a/s owner question on furnace/toilets baddog Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-23-2003 12:24 PM
