03-15-2020, 05:06 PM
Weareroadready
2020 25' International
Freeport
LED light covers removal in 2019 international
Hi does anyone know how to remove the lens cover from the sconces / reading lights ? I have some material to cover up the harsh LED lighting however I’m not able to remove the covers on just the reading lights - thanks for any suggestions
Mary Kay
03-15-2020, 08:39 PM
2007 22' International CCD
Corona
On mine a firm hand grip on the body and lens retaining ring to twist it apart worked fine. I don’t remember which way the ring turns.
05-07-2020, 05:54 AM
Weareroadready
Freeport
Thanks so much! You’re absolutely correct; I was afraid to turn so hard. Thanks for the reply now I’m able to enjoy the lights my gosh they were horribly bright white - like in a surgical suite ugh...ty agn! MK
06-15-2020, 07:43 PM
2016 30' International
redondo beach
We had a great time changing our lights!
SO MUCH BETTER!
Thanks you guys!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
06-21-2020, 12:07 PM
redondo beach
This upgrade has the best bang for the buck of all the work we have done on our trailer, and we have done a lot.
Never realized how much we avoided using the lights because they were so horrible.
For the lights that are not on a dimmer we doubled up the orange stuff.
There were over thirty in total and we ran out of orange stuff so we experimented with some other color combos.
Lots of fun!
06-21-2020, 06:35 PM
2019 27' International
Western NC
, North Carolina
Can you give a little more detail what materiel and how you installed it. Pics of light before and after?
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
06-21-2020, 07:12 PM
2018 19' Flying Cloud
Newport
I spent all day trying to remove the lens from the 4 reading lights. One came off really easy. Twisted it CCW about 1/2" and it came right off. No matter what I do I can not seem to budge the other three. Any suggestions?
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
06-21-2020, 09:22 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Put tight rubber gloves on and try again.
Also, cylinders may be a bit out of round, so move your hand grip by 90° and see if it gets easier. Last, add a tiny drop.of silicone lube between the cap and cylinder (good luck cleaning it off after).
06-21-2020, 10:00 PM
redondo beach
Sorry we did not take before and after pics but other people have done so on these forums. for example:
https://www.airforums.com/forums/f24...ion-95117.html
The material is called gel sheet or something.
The covers everywhere but those reading lights just pop off. Look at that link above. Here is another link:
https://www.aluminarium.com/airstrea...eam-led-color/
06-21-2020, 10:05 PM
redondo beach
If you got one off then you see how they work and what you are up against.
They might be a little stuck but don't give up! One of mine was really stuck but it turns out it did not need that CCW turn. It was just stuck on with out any turn at all.
07-24-2020, 10:25 PM
Santa Rosa
If these pics appear, I’ll edit to add some descriptions.
...ok, so this forum is still the most difficult place for me to figure out how to add photos.
We’re you able to view what I tried to download using the “advanced” options, you would see that the light bodies have 3 recessed spots that mate with 3 nubs on the outer lens-retaining ring. Turning the ring counterclockwise a very small amount allows the ring to slide off the light body.
HERES THE CATCH...they put 3 globs of silicone adhesive between the body and the ring. You have to grip and turn hard enough to overcome the silicone adhesion.
I was only able to remove 3 of the 4 before I had to give my hands a rest for awhile.
-Sean-
07-25-2020, 02:34 PM
Santa Rosa
To remove the 4th ring, which was exceptionally well stuck, I used 2 of those wide rubber bands that come with broccoli. One around the light housing and the other around the ring. The increased friction gave me a non-slip grip which did the trick with no damage to the light.
-Sean-
07-26-2020, 11:18 AM
Western NC
, North Carolina
Thank you this was a great quick fix.
