Old 01-06-2025, 10:01 AM   #1
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
Garage Door for 25FB
We are building a new home and have an opportunity to add a garage bay for the Airstream. We currently own a 25FB. I am curious to hear peoples experience with garage size and in particular what would be considered a good garage door opening size. Our current plan is 10' wide x 12' tall door.
OrangeCrush is offline   Reply With Quote
Old 01-06-2025, 12:57 PM   #2
2023 28' International
Mercer County , New Jersey
I would go 12 x 14 in the event you move on from an AS or to appeal to someone with a larger/taller RV when reselling.
Also, a 10' door is going to be a little narrower on the usable opening so you'll have max of about 8" - 9" on each side but it will probably be less due to the awing arms, bumper sticking out beyond the edge of the trailer, etc...
jeffb831 is online now   Reply With Quote
Old 01-06-2025, 01:02 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
I once rented a storage space with a 10 x 12 door. It was too tight and too easy to make a mistake...I eventually moved it to outside storage. Go bigger.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-06-2025, 01:11 PM   #4
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
:I pull through my 11 ft. wide gate regularly. While it's doable I would be much happier with 12 ft. I have a more or less straight shot approach on both sides still I have to be careful. With all the extra things hanging out the AS is over 9 ft. That's tight pulling through backing in would be less fun If you do decide to put in a narrow door installed a front hitch on the TV it's much more maneuverable and you can see better.
Keys Dave is offline   Reply With Quote
Old 01-06-2025, 02:02 PM   #5
Genebuilder's Avatar
Celina , Texas
If I were you, Orange Crush, I would flip the dimensions. My RV garage door, now complete, measures 12Wx10H. You need a minimum of 12 wide for maneuverability.
2017 Ford F150 Lariat 3.5L EcoBoost w/Max Tow
FAA Certificated Remote (Drone) Pilot
Amateur Radio Extra Class N5EAS
Journeying America via the "Blue Highways"
-Be Curious, Not Judgemental…Walt Whitman-
Genebuilder is offline   Reply With Quote
Old 01-06-2025, 02:39 PM   #6
1968 24' Tradewind
Dallas , Texas
We did 12x12, but would agree that if we ever move to non-airstream 5th wheel the 12 foot height will be an issue. Our 28 ft usable depth will likely limit the likelihood of that, though.
KeithT is offline   Reply With Quote
Old 01-06-2025, 04:43 PM   #7
nelsonh's Avatar
2023 23' Flying Cloud
Carroll , Iowa
I would consider 12x12 the minimum door size
My 23' FC is 8' x 9.75'. My storage unit has a door that's 12' wide x 14' high, and after a season of going in and out of this size door, I personally wouldn't want to have to back into an opening less than 12' wide. I've found this size gives me enough wiggle room to not feel worried when backing the rig in. Could I get it into a 10' wide opening? With enough clear runway and time, yes...but I wouldn't want to have to on a regular basis.
My current 14' high door is of course way more than enough for the Airstream, a 12' high door would also be totally comfortable and worry-free. A 10' high door...not so much.
So if I were building my own storage spot, I would use a 12x12' door.
2023 Flying Cloud 23FBT ~ 2024 Ford F150 XLT PowerBoost 7.2 kw ~ 2010 Border Terrier
nelsonh is offline   Reply With Quote
Old 01-06-2025, 11:14 PM   #8
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I've been storing my 1994 Excella in our barn for years now. The door we use is about 4" wider than the total width of the trailer with the awnings and all other components.
There is no feasible way to back the trailer into the barn using my Suburban, and we use instead our small compact diesel tractor. Every time I pull the trailer in/out of the barn it is nerve wracking and a real nail biter. I use a spotter who has to run back and forth from side to side since I can't clearly see the edge of the door opening once the trailer starts to go through.
We make it work, but I wouldn't recommend it to anyone. We're currently trying to figure out how to retrofit a wider door on a 180-year-old barn.
Get the largest door you can for the space you're building. If 12-ft is possible do that. If wider is possible, then go wider. You'll never complain that the door is too wide, but you'll surely regret getting a door which is too narrow. It's just not worth the trouble for the few bucks you'll be saving.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 01-07-2025, 10:10 AM   #9
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There is an "interesting gotcha" in this:
There is the size of the "hole in the wall" for the garage.
There is what's left after the garage door goes into that hole in the wall.
As noted above, the door hardware sticks out a bit on the sides. The other issue is that the door itself may or may not stick down into the opening as well. That part depends a bit on how high the ceiling is *inside* the garage. It also depends on how much unobstructed space there is. If you just happen to have this great big beam running across the ceiling .... that can be an issue. I have empirical data on this ....
What I would want is at least 12' x 12' completely clear going into the garage. I would also want at least 3' on each side past that once you got into the garage.
Old 01-07-2025, 10:55 AM   #10
2019 27' Globetrotter
McKinney , Texas
Garage Door
10’ X 12’ is what my Shop bay has which gives my AS plenty of clearance.
D-Rod is offline   Reply With Quote
Old 01-07-2025, 11:17 AM   #11
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
We have a 2014 FCFB with 16" wheels. Its garage door is 10x10. There is about 3" of clearance in height and about 9" on each side. It works but I have a corded trailer mover to get it placed so that the trailer door can swing open.
I do back it in with the tow vehicle but maneuvering it in the garage with the truck would be hard and risky.
A 10x10 is the absolute minimum. Bigger is better.
BillfromWI is offline   Reply With Quote
Old 01-07-2025, 11:45 AM   #12
2007 25' Classic
San Luis Obispo , California
Garage door size
I concur with Jeff B831. Since you have the opportunity while building, make the garage big enough to appeal to a new buyer if that comes to pass. My RV port is 12' wide and I feel is it the bare minimum required. I have to come in on an arc as I do not have enough room to back in a straight line. Once the trailer is in, there is not enough room on the sides to do any sort of cleaning or work at all. I would concur with uncle bob that you need at least 3' on each side of the trailer, preferably more if you plan to do any sort of work on the trailer while it is parked in the garage. Good luck!
slofoks is offline   Reply With Quote
Old 01-07-2025, 11:45 AM   #13
MMCMRET's Avatar
Fredericktown , Ohio
No more winterizing!!!!
You will not regret the heated storage! Our door is 10' high and 10'2" wide. We have a 25' FC FBT without a lift kit. My ceiling is 11' high so I do not have a lot of room to get on the roof when she is inside. In fact, we cannot lift off the AC cover without a 2nd person. If we had it to do over again we would go with 13' ceilings and the door would be 12' wide and 12' high. This would allow us to install a lift kit and leave plenty of room to remove the AC for maintenance (if needed).
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 01-07-2025, 03:23 PM   #14
fwjumper's Avatar
1998 34' Limited
Alto , Georgia
Ours is 14 wide x 12 high. It's great. I could live with 12x12, but 14 is better width. Sorry photo rotated.
fwjumper is offline   Reply With Quote
Old 01-07-2025, 05:30 PM   #15
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
What he says…
Our 25FB lives is an industrial garage we own. She likes it! It’s got a 12W x14H door. I wouldn’t want less.
I’d add two considerations… 1. the path to place or remove the trailer 2. the tool you plan to use to move the trailer in and out.
Given other obstructions, I have to place or remove the trailer while turning. For me, 12’ wide feels tight. I sometimes use my tow vehicle. I also have and use a Trailer Valet. If you have a long, straight run to align the trailer you would have a better chance to be happy with a narrower door. I don’t have that option.
Ask yourself this… what would I do with the two feet of wall I gained by using a 10’ door vs 12’?
Silver Cliche’
Follow us at...
silvercliche.blogspot.com
GammaDog is offline   Reply With Quote
Old 01-07-2025, 07:25 PM   #16
2022 25' Flying Cloud
Northern , Ontario
I have a Quonset hut with a 14’ x 14’ door at each end. It is great for easily angling the 25FB so that it only takes one side of the Quonset. For simply backing up the trailer straight, I would not go less than 12’ wide.
Aluminium Falcon is offline   Reply With Quote
Old 01-08-2025, 12:41 AM   #17
1997 28' Excella
, Kentucky
I built in 2019 and put in a 16’ wide by 12’ tall door for our 28’ Classic Widebody.
I really would hate backing into a narrower opening.
MJEdlin is offline   Reply With Quote
Old 01-08-2025, 06:07 AM   #18
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
We recently built a new home with an RV garage attached. The garage itself is 18' X 35' with a door that is 14' wide and 12' tall with a 14' ceiling height. This works really well for us. I back in with the driver's side tight to the door frame and that leaves room to get down that side and plenty of room on the passenger side to load things in and out.
Could we get by with only 12' wide? Sure, but for a few hundred more, we like the convenience of the wider door. The extra height is just for resale value. If someone had a boat or bigger RV to store.
Mikebrady62 is offline   Reply With Quote
Old 01-08-2025, 07:30 PM   #19
2025 30' Classic
2018 30' Classic
2018 33' Classic
Weatherford , Texas
12W X 14T and 50’ deep and wired for 50A. While your current unit is smaller, consider every residence is for sale at some point. This size allows for growth, 5th wheels are 12’10” tall and upwards to 40’ lengths; Class As are similar but up 45’ lengths. A garage of this consideration becomes a major attracting selling point (RV or workshop) and allows flexibility for now. Your 10’ W doors gives you 12” clearance on each side, give yourself a bit of breathing room, someone will be spotting for you as you back in.
smmckean is offline   Reply With Quote
Old 01-12-2025, 10:26 AM   #20
2016 30' International
redondo beach , California
Door on each end!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Garage and door minimum dimensions Fredjacob Sprinter and B-van Forum 23 06-12-2023 09:55 AM
Garage door opener (Outside) NoResults Winterizing, Storage, Carports & Covers 0 10-26-2019 11:59 AM
Minimum garage door opening Gypsydoc81 Winterizing, Storage, Carports & Covers 21 10-05-2017 07:16 AM
Garage Door Size for Airstream Julison Off Topic Forum 19 04-30-2012 05:53 PM
Turning radius and garage door walls RankAm Towing, Tow Vehicles & Hitches 12 05-27-2009 10:46 PM
