06-27-2022, 08:17 AM
Sevierville
, Tennessee
Experimental Ideas
How possible is it to turn the whole aluminum shell into a radio antenna?
06-27-2022, 08:20 AM
Sevierville
, Tennessee
Also, any rain harvesting ideas? One could also run a dehumidifier inside that drains into the fresh water tank.
06-27-2022, 08:22 AM
Sevierville
, Tennessee
Air purification ideas for places with low air quality or just like fresh air while inside.
06-27-2022, 08:57 AM
1994 25' Excella
Waukesha
, Wisconsin
It would make a far better ground plane than an antenna.
Richard
11018
06-27-2022, 10:48 AM
2017 25' Flying Cloud
Celina
Not to mention Faraday Cage
2017 Ford F150 Lariat 3.5L EcoBoost w/Max Tow
FAA Certificated Remote (Drone) Pilot
Amateur Radio Extra Class N5EAS
Journeying America via the "Blue Highways"
-Be Curious, Not Judgemental…Walt Whitman-
06-27-2022, 06:40 PM
2017 25' International
West Lake Hills
This air purifier hangs where the bedroom television used to hang in our 25FB. I fashioned a backing board and reused the wall bolt holes that supported the television. Then attached the purifier bracket to the backing board. Works great. And out of the way. We travel with it stowed in a Blackstone bag and wedged between the bed and the front wall, but I’m considering permanently mounting it.
07-15-2022, 10:09 AM
Sevierville
, Tennessee
Nice
07-15-2022, 10:36 AM
2013 30' Classic
Key West
NASA defines a Radio Antenna as a metallic structure that captures and/or transmits radio electromagnetic waves. So, technically an aluminum Airstream is already a radio antenna, which can be easily verified using a spectrum analyzer. The question then becomes, "Do I have enough money to modify the Airstream aluminum skin to operate efficiently as a working antenna at a given frequency?" Leading me to the next question, Does the Airstream need to retain full usability as camping equipment?
07-15-2022, 10:51 AM
2022 27' Globetrotter
DALLAS
, TX
I believe the Airstream shell is grounded, though it's realistically not physically grounded to the earth because the trailer tires are not electrically conductive.
Anyway, it would not make a great radiator due to it's physical size. I have no idea what wavelengths if any would be able to propagate on the surface of the shell.
2013 30' Classic
Key West
I see some serious boondocking adventures in your future.
Rain water harvesting can be performed through the use of large plastic sheets laid out tight and draining to the center. During the days with no rain, the same configuration will collect moisture evaporating from the ground.
07-15-2022, 11:04 AM
2013 30' Classic
Key West
wavelength = velocity / frequency
07-20-2022, 09:02 AM
Sevierville
, Tennessee
I was thinking more of ways to passively collect it. Those methods work too aside from general preparation involved.
