RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-27-2019, 08:30 PM   #1
2007 31' Classic
Gulf Breeze , Florida
Easy Start
When re installing my ES on a different trailer I am
Having an issue in that the compressor wonít come on. The fan starts and about a minute later all three error lights come on. I have checked the wiring, even checked continuity back to the compressor and all is good.
Has anyone else experienced a similar problem. ES tech support doesnít have an answer.
trumpetguy is offline   Reply With Quote
Old 12-27-2019, 09:35 PM   #2
2016 16' Sport
Miami , Florida
Isn’t there a rest that needs to be performed when reinstalling an easy start?
Shiny16 is offline   Reply With Quote
Old 12-27-2019, 09:58 PM   #3
2007 22' International CCD
Originally Posted by Shiny16 View Post
Isnít there a rest that needs to be performed when reinstalling an easy start?
Bingo!
Look up the reset procedure in the EasyStart documentation and do it so it will re-learn the new compressor.
I think it involves moving a jumper on the board or something like that.
rmkrum is online now   Reply With Quote
Old 12-27-2019, 10:07 PM   #4
2007 31' Classic
Originally Posted by rmkrum View Post
Bingo!
Thatís correct. Move the jumper from 34 to 46 to re learn. Did that but get the error lights.
Old 12-28-2019, 08:16 AM   #5
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
Easy start
talked to tech who was installing new easy start next door at Alumalina last October. He mentioned the A/C had to be cycled 5-7 times to complete learning setup procedure. Hope this helps.
Steve
heslinhotel is offline   Reply With Quote
Old 12-28-2019, 08:26 AM   #6
2007 31' Classic
Steve
My unit wonít cycle even once. Throwing errors lights.
Old 12-28-2019, 08:45 AM   #7
1976 Argosy 28
Warrenton , Virginia
If the unit was working prior to the install then one of two things exist...either it's installed incorrectly or it was damaged in the process or the AC unit itself has problems.
(Also I don't know but some AC systems won't start if the outside temperature is to low)
Don't know if "Easy Start" has a repair system in place you might check?
Remove the device and see if the AC system functions correctly without it.
Hopefully nothing is permanently damaged....good luck.
captainkirk is offline   Reply With Quote
Old 12-29-2019, 08:15 AM   #8
2007 31' Classic
Thanks for your input. My AC and Heat pump work without ES. Live in NW FL so have need for both in Winter.
I am shipping the ES to the factory for testing and will report back here when they give me some guidance.
Old 01-08-2020, 11:52 AM   #9
2007 31' Classic
Once again the micro Aire folks have proven that they are a quality company that stands behind their product. I sent them my five year old easy start 364 for factory testing and after only one day they responded that my unit was not repairable and even though it was out of warranty they were sending me a brand new easy start 364 which I received today. This company exhibits the very best in American technology and customer service. I recommend them to anyone who needs this type of technology.
Old 01-08-2020, 12:09 PM   #10
2016 16' Sport
Miami , Florida
Awesome!
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 09:12 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 08:36 AM
Easy-Start Install kit Bob662 General Repair Forum 10 04-30-2017 08:44 PM
