RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-24-2020, 04:43 PM   #1
2016 25' Flying Cloud
corpus Christi , Texas
Dometic thermostat has no power
Thermostat will not come on. Appears no power going to it. Checked breakers and fuses. Appears to be ok. Electricity ok to rest of trailer. Tried a reset on thermostat nothing happened. Any advise?
Mbstrustee is offline   Reply With Quote
Old 03-24-2020, 08:05 PM   #2
2018 25' International
Slidell , Louisiana
I presume it is the CCC2 thermostat controller. It is powered through the RJ-14 (4 wire phone like) communications cable. Two of the wires are 12V +/- the other pair is for communication. The roof unit uses 12V power for the control circuits and 120VAC for the compressor and fans.
So the 12V fuse could be the issue, or a problem with the batteries or 12V system or the Store/Use switch and solenoid or the Heat Pump controller board in the roof unit, or the previously mentioned communication cable or the CCC2 unit itself.
Check the 12V system first and recheck the 12V fuses. If you're handy with a multimeter let me know and we can go from there.
Old 03-24-2020, 08:07 PM   #3
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Try messing with the telephone connector that is located under the interior access to the air conditioner. The cowl is removed by taking out 6 screws. Once removed, the connector is exposed and you may see that the cables that are plugged into the connector are not secure in their place. The cables connect the thermostat with the AC unit controller. That is my only experience with the issue. Good luck. Jim
Jim Flower is offline   Reply With Quote
Old 03-24-2020, 08:14 PM   #4
Slidell , Louisiana
His is a ducted system so the phone connectors are in the air intake plenum behind the intake filter screens, also easy to access. If he has a single Heat pump there will be a spare one for daisy chaining to other devices plus the one connected to the CCC2.
Old 03-25-2020, 07:51 AM   #5
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Better than the old system in mine. Jim
Old 03-25-2020, 07:58 AM   #6
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
It could also just be the connection on the back of the CCC2 is loose. Jim
Old 03-25-2020, 10:56 AM   #7
Dark thermostat
Thanks to all. It is ccc2 thermostat. AC is duel air. I checked our batteries and they are fully charged. I checked the fuses and breakers. I’ve checked the telephone like connections on the thermostat and up in the air intake. Thermostat still dark. Everything else electrical is working except the fantastic fan.
Old 03-25-2020, 11:04 AM   #8
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Nasty! Way beyond me. I usually “ fix” electrical stuff by giving it a slap on the side. Jim
Old 03-25-2020, 02:24 PM   #9
BradT
2007 27' Safari FB SE
Milton , Georgia
I think the Fantastic Fan also not working is a clue.
It could be the Fan and the control board in the A/C unit get their 12vdc thru the same wiring in a daisy chain fashion.
Since all the basic checks on the A/C haven't resolved the problem, shift gears and trouble shoot the Fantastic Fan.
Also, since more than 1 item is affected, check fuses again, just in case you could have missed it there.
Good luck!
bradt is offline   Reply With Quote
Old 03-25-2020, 02:39 PM   #10
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Have you tried the old tried method and unplug the trailer from shore power then switch battery to "Store" .Then fire up again in effect rebooting
Laurence
LAWBC is offline   Reply With Quote
Old 03-25-2020, 05:22 PM   #11
Problem solved
Problem solved. The power connection on the battery for the thermostat was loose. Cleaned and snugged it up and it came on and the AC is now running fine. Fantastic fan still not working though. Thanks for all you suggestions.
Old 03-25-2020, 05:34 PM   #12
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
On my 12V circuit breakers a trip was not obvious. Further, pushing the reset with a finger didn't work. I had to get a small pointed object (stylus, toothpick, ballpoint pin, etc) to push the reset button far enough for it to work.
Al
Old 03-25-2020, 08:28 PM   #13
Slidell , Louisiana
Good to hear you resolved the thermostat and heap pump power issue. The fan has a separate low amp fuse in the fan body to protect it from a rain caused short, it is easy for it to blow. The fan is generally on the same circuit as the Heat pump control power so a loose connection could cause low voltage to the fan inducing high current an the blown fuse. Also the 12V power feed wires are easy to access and check for power by removing the trim.
Old 03-25-2020, 09:30 PM   #14
Anahuac , Texas
I just replaced mine. The jack on the back of the board had pulled loose and broke one of the contact prongs on the board itself. No way to fix it had to replace. Hope this helps.
Thanks Steve
shb2777 is offline   Reply With Quote
Old 03-28-2020, 06:29 PM   #15
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Mbstrustee
Is this the connection that you are referring to that resolved the non operating issue or is there some other battery connection?
Old 03-29-2020, 08:33 AM   #16
No picture attached. It was the single wire connected on top of the positive post on one of the 12 v batteries
Old 03-29-2020, 03:14 PM   #17
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Thank you for that. Another place to look when stuff goes wrong. Jim
Old 04-01-2020, 12:10 PM   #18
Had the same problem and found the JK wire connection is intermittent, Best to put new phone type connection phone cord Or JK to the first point which is the wiring which supplies the Voltage". Mine was the A/C Heat Pump'. I cleaned my connection on the roof and though it now works I suspect this is slightly corroded and will reoccur. A new thermostat did not help.
RonJudi is offline   Reply With Quote
Dometic thermostat power Camr General Repair Forum 0 09-16-2018 08:26 PM
Dometic thermostat Tino643 Electrical - Systems, Generators, Batteries & Solar 4 05-25-2013 10:42 PM
Dometic Briskair thermostat not working on heat perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-23-2012 08:07 PM
Dometic CCC 2 Thermostat (12 button style) Terratravels 2009-2015 Flying Cloud 12 10-22-2012 07:53 AM
Dometic RM100 electric thermostat problem blickcd Refrigerators 0 08-31-2009 11:32 AM
