Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 12-28-2020, 12:50 PM   #1
2019 30' International
Midlothian , Virginia
Propane furnace air intake
Hi, I have a 2019 airstream intl signature 30 ft with a rear queen bed. My furnace was just repaired and they said they cleared debris from the air intake under the stove or
Somewhere near there. After operating a few days, the same problem arose. Where is the actual air intake located, how do I get to it, and any suggestions in clearing it out? I am able to see a flexible hose below the stove and the cabinet between stove and sink.
Thank you.
Fortj1114 is offline   Reply With Quote
Old 12-28-2020, 12:58 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Access depends on location of furnace. This is the location of intake on furnace in general.
Viewed from outside of furnace open the access inspection doors.
See the control panel on the left side, now look behind it and farther in, see louvers? Vent may also be on top but it’s close to the outside.
If unit is under sink for example remove drawers and look behind hoses. Or maybe remove a shelf under sink. As I don’t know where or what your trailer layout is can’t point just describe possibles.
If you see any pics of furnace hot air comes out thru round holes cold air return is thru louvers.
Curious what was symptom of problem?
Gary
I was just checking mine last week for stuff.
GCinSC2 is offline   Reply With Quote
Old 12-28-2020, 02:41 PM   #3
2018 25' International
Slidell , Louisiana
I'm with Gary, since the problem is back, what are the symtoms? Are you getting a Sail switch fault code?
Cold air intake and air filter Jim Keaty General Motorhome Topics 16 02-10-2021 11:18 AM
Furnace Air Intake DaveP Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-02-2017 03:07 PM
Missing Panel for Furnace air Intake Caltech Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-12-2010 06:34 AM
Where is the internal air intake of Suburban furnace? Astroboy Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-16-2009 06:45 AM
Sealant for furnace intake/exhaust plate lbf78SvgnInt31 Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-08-2004 09:55 AM
