Originally Posted by PhilouCerise
Hello,
How do you quote a person, do you use Q***E?
Yes, the Blue box in the lower right corner of your post.
Then, often it's only one area I want to address, so I highlight everything else and "delete".
How do you quote a person, do you use Q***e?
In this case I deleted Hello and Thanks and tightened everything up.
(I had to modify the operation [Quote] since it was confusing the software.)
Bonus points: If you'd like to quote two or more posts in a single response, just treat them as separate events.
Do the first section and post it, then select a second thread, follow the operations as above, "copy" it, delete the additional post, then use "Edit" on your saved post, select "Paste" and save again. Now you'll have two responses in one post.
You have about 30 minutes to "edit" before that option goes away.
