Originally Posted by Al Uminum
Thank you for the directions to the User CP. More to my point, when I attempt to add "Trailer #3", The pull down only lists trailers from 2021. It doesn't seem like I can use a free text entry, only the pull-down list of options?
Ami I missing something?
Your are correct. The pull down menus are limited to the existing entries and doesn't incorporate a free text field.
Using the 5 step outline above when I checked each of the trailer # drop down menus. I see a difference in the list for Trailer #3. It starts at 2021 and ranges down to 1936. The other 2 drop down menus start at 2024 and range down to 1936. My guess would be that the Trailer #3 menu simply needs to be updated to include the newer models.
I'll advise the tech admin team so that all 3 drop downs display the same complete range.
