08-30-2011, 09:33 PM
1966 17' Caravel
Metairie
, Louisiana
1966 Caravel - barebones from factory? - restoration
Hi, this is my first post on this really great forum. I've been reading as much as I can fit into an otherwise pretty hectic schedule (I master records and CDs as my day job in New Orleans) but there's so much to absorb (a good thing).
Mainly, I'd like to say thanks to all the amazing contributors. There is a wealth of information and many generous people here.
I just got a '66 Caravel that was represented to me as being special ordered from the factory with little more than a chassis and shell and used in that condition by the original purchaser until the last year or so. The inside is almost completely bare. Guess it's a blessing and a curse. I don't have to remove all the old stuff but of course I don't have anything to use as templates. And I'm not sure what, if any, wiring and/or plumbing has been installed. I suspect not much.
So, I'm trying to decide what to do with it and where to start. I'm open to any and all suggestions.
My inclination is slowly to return it to stock specs with a few exceptions like modern appliances, plumbing, and electrical.
Seems like the best course would be to make it roadworthy first by changing out the axle and brakes, getting towing lights functional and checking frame and flooring. Then removing inner skin to check for structural integrity, insulation (it smell kinda funny), and to see what wiring has been installed.
I suspect I'll end up needing to put together drawings, schematics and/or diagrams of all the electrical and plumbing systems. May be this could be a decent place for an overview of mid-60's Caravel systems.
Sorry for being so long winded. Hello and thanks everyone!
08-30-2011, 09:59 PM
2003 22' International CCD
Kiln
, Mississippi
Well, I have the same model and live just a short distance. Did the axle change out on mine - not to hard - could help out with that if you need. More than welcome to come over and look at the one I have to see one in near original condition (98%). Saw that one on eBay, looks good and straight from the pictures. Good Luck, have fun with it, it's a blank slate.
Mike
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
08-30-2011, 10:14 PM
'65 Caravel 17'
2001 34' Limited
1965 17' Caravel
Lufkin
1966 Caravel
I am in the process of rebuilding a 1966 Caravel. I purchased it 4 years ago. Progress has been slow but steady. I am not trying to restore it. At this point, it has new running gear, new tanks, a reconditioned bath unit, all plumbing, and electrical including 120v and 12v. Lights, battery box, etc completed. I lack the kitchen cabinets, sink, stove, etc. The original gaucho was reworked and lacks cushions. I added a front sofa/bed. I have been idle on it for the past year due to illness in the family. However, I will finish it by springtime. You are welcome to take a look at the unit and view the construction photos. I live in Lufkin,Tx just 55 miles into Texas.
Best of luck on your project. My wife and I have enjoyed working on the project.
08-30-2011, 10:32 PM
1966 17' Caravel
Metairie
, Louisiana
Thanks so much for the generous offers Mike and Jim. It's really great to know there are more AS people around here. I was under the impression most of the action was on the west and east coasts.
Maybe I can return the favors. A few years back I got the furniture making bug and bought a bunch of decent tools. Made a few pieces I was happy with like a cypress pencil post bed and replica of 18th century dresser. Much of the gear has been on semi-permanent loan at a friend's house, mostly cause I've run out of space here. But I'm hoping to find a place to set up a small shop to make the cabinetry for the Caravel. The stock cabinetry looks pretty straightforward. If I can make that happen, I'd be happy to help if anyone needs some woodworking stuff done for theirs.
Bruce
08-30-2011, 11:25 PM
1968 17' Caravel
Battle Ground
Get a look at some stock cabinetry and you'll see it was brilliantly lightweight, yet very sturdy and holds up well over time. I have often thought of re-organizing my interior (but I wouldn't because mine is so original), but ultimately I keep coming to the conclusion that the Caravel was really well done to begin with! The dinette/bed in the front, and the gaucho (couch/fold-out bed) down the side, make the space incredibly flexible. The kitchen is small but functional. The wet-bath gives you both a usable shower, and a surprisingly roomy bathroom the rest of the time. It's darn near perfect just the way they did it!
I would add a bigger black tank (extended into the closet area) because every little bit helps in that department. And a grey tank so you could use your sinks without being hooked up (in original Caravels it drains right out the dump valve).
Please post some pictures of what your Caravel has in it now, I'm curious to see what it looks like. Did you find anything else about the history?
Stephanie
09-18-2011, 07:35 PM
1966 17' Caravel
Metairie
, Louisiana
first photos of 66 caravel
I'm going to try to upload a couple of images. Hope it works.
09-18-2011, 07:46 PM
1966 17' Caravel
Metairie
, Louisiana
Stephanie, here's a couple of shots of the interior. It was already stripped when I received it. The PO installed a complete plywood floor above the original and then put oak flooring about that. I ripped it all out last night and this is what was underneath.
I love the stock layout and I'll try to keep that same theme going when I'm refurbing.
09-18-2011, 08:33 PM
1966 17' Caravel
Bethel Park near Pittsburgh
, Pennsylvania
My 66 Caravel
Here a few photos of my 66 as found back in 2008. I am the second owner and have been enjoying it since the day I got it.
Ace in PA
09-18-2011, 08:45 PM
1966 17' Caravel
, Pennsylvania
My 66 Caravel Now
09-19-2011, 11:59 AM
1968 17' Caravel
Battle Ground
Brusby, you've got a pretty sweet looking Exterior on that thing! That will be a nice project. Finding a replacement for the bathroom insert is going to be tricky though. You may have to do your own thing back there.
Ace, that is a very nice little Caravel! Excellent upgrades to the original interior
Stephanie
09-19-2011, 12:01 PM
1966 17' Caravel
Metairie
, Louisiana
What a great find and such a beautiful Caravel. Thanks for posting. The pics of your nice original condition '66 will be really helpful.
I haven't been able to find any measurements of the original interior furnishings and cabinetry. If anyone has made them or knows where they are posted, please let me know. If would be great if I could get the dimensions on my refurb as close to stock as possible. I just don't have anything to use for templates.
Bruce
09-19-2011, 12:12 PM
1966 17' Caravel
Metairie
, Louisiana
Here's some shots of the underside with belly pan removed. Funny, I didn't expect to see 2x4s bolted to the frame. Is that original construction or aftermarket?
09-19-2011, 12:30 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
That is not original...someone added the 2x4's later, no telling why. The "special order" story sounds a bit odd too - the upper cabinets look like they are original. And it looks like a nice shell...can you tell if the frame is rusted through - maybe that was the reason for an attempted "fix" with the 2x4's...not an appropriate fix...but ???
Was there a belly pan covering the underside of it or was it all exposed? Ohhh....if only these babies could talk!
Shari
09-19-2011, 12:53 PM
1966 17' Caravel
Metairie
, Louisiana
Yep, it all sounded a bit fishy to me too. But I bought it solely for the shell expecting everything else to need replacement.
The frame appears to have mostly surface rust. I don't see any places where it's rusted through but I'll be checking it out more thoroughly. Of course I'm really suspicious why anyone would go to all the trouble to add that wood unless they thought the frame needed support.
And yes, the belly pan had already been removed when I got it. The only thing I've done so far is remove the additional flooring the PO added.
Guess one advantage of not having the original interior is not feeling guilty about destroying nice vintage stuff if I decide to make a few changes.
09-19-2011, 01:26 PM
1956 22' Safari
Conifer/Evergreen
Good attitude!
...the belly pan had already been removed when I got it. The only thing I've done so far is remove the additional flooring the PO added.
Hmmm...do you have the belly pan? If not, you'll porbably want to add one back in otherwise the wood will be exposed to all the road grime & water and just rot away. The belly gives you a way to protect the wood & frame and gives you a cavity for some sort of insultaion.
True, it's a blank canvas...how fun!
Shari
09-19-2011, 01:41 PM
1966 17' Caravel
, Pennsylvania
My 66 Caravel
Thanks for the kind words. I spent 3 years looking for the right AS for us. I didn't want a big project. I have found that it's better to pay for a good one then trying to repair one that wasn't loved. I have had to do very little work on it. I replaced the water heater, sandblasted the frame, New water pump and repaired the belly pan. I still need to replace the axle. She has pretty low miles. Its was not used for 33 year before I got. After looking at others 60's AS I know how lucky I am to have it.
Ace in PA
TAC PA-1
WBCCI 2169
09-19-2011, 03:01 PM
1968 17' Caravel
Battle Ground
I wish I could hear where this one has been. I suspect at some point it had furnishings in it. At least it has a vent stack in the correct place on the rear kitchen side. I don't see one on the other side. Also the water heater door looks like it came off a newer model Airstream. Who knows what has happened in the years since it rolled out of the factory.
Stephanie
09-19-2011, 03:33 PM
1965 17' Caravel
brooklyn park
caravel
Hi from MN, I have a 65; I'll try to upload some inside shots. mine has the original mahogany and veneer mahogany cabinets, happy remodeling. joe q
09-19-2011, 06:15 PM
1966 17' Caravel
Metairie
, Louisiana
@Shari - Yes, I'm dreading having to fabricate and install a belly pan. The rest I'm really looking forward to though.
The pictures are really helpful, thanks!
Does anyone have measurements of the interior handy? I'm trying to gather the basics for the larger items to input them into a 3D drafting program and use that get an idea how everything fits together. The smaller details I'll worry about later. Any of these would be a huge help if you have 'em:
1) the elevation or height of the countertop from the floor to the front corner,
2) the depth of the countertop from the curbside wall to the front corner,
3) width of countertop from front corner (edge closest to door) to the curbside room divider,
4) the depth (or width depending how you look at it) of the streetside room divider at countertop level measured from the inside aluminum skin at countertop level to the vertical edge closest to the center of the trailer..
5) Length of the side Gaucho measured at it's longest part.
6) Width of walkway when Gaucho closed (measured between kitchen cabinet and Gaucho)
7) Width of walkway when Gaucho open.
thanks again for all the imput!
Bruce
p.s. I keep saying to myself it's only one relatively small room to redo . . . no big deal. Ha!
09-19-2011, 06:21 PM
Kiln
, Mississippi
Bruce, you are more than welcome to come measure my Caravel in the yard. PM if you want to check it out. I need to get inside soon and look around some - it's been a few months.
