03-29-2014, 06:23 PM
Retired.
, At Large
Originally Posted by tallredboned
Looks like the controller for your converter.
03-29-2014, 07:16 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
That is the charge wizard pendant for your converter/charger. Should have a green light on it.
Steady green-high charge rate
Fast blinking green-normal charge rate
Slow(every 6 secs) maintenance gharge(trickle)
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
03-29-2014, 08:25 PM
1975 25' Tradewind
dallas
what is a converter/charger?
03-29-2014, 08:34 PM
1986 31' Sovereign
Miami
Converts 120volt AC shore power to 12volt DC ships power for the lights, water pump, control boards and to charge your batteries.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
06-02-2014, 02:44 PM
Richardson
, TX
What is this?
I've got another what is this. This has something to do with the electrical panel as it is on the outside right where the electrical panel is on the inside, directly above the water heater access panel.
It looks like it needs to be replaced or is missing some cover.
Thanks in advance for the help.
06-02-2014, 02:49 PM
Richardson
, TX
Tail Light Monitor
Nevermind, upon further review I have discovered that it is the tail light monitor and just needs a new cover.
06-02-2014, 03:24 PM
1976 25' Caravanner
Salt Lake City
, Utah
Can you explain how you figured that out? I've wondered what this same thing is on my AS. How does it monitor the tail lights? I'm drawing blanks here. Have I missed something in the manual? Thanks for your help.
R.H.
06-02-2014, 03:31 PM
Richardson
, TX
Found a part on vintagetrailersupply.com and at inland rv.com that looked like it would cover it and then did a quick search on this forum for tail light monitor. Apparently, there are fiber optic cables that run from the tail lights to that little doohickey and the light reflects through the doohickey so, in theory, you can see from your side view mirror whether your tail lights are operating.
06-02-2014, 04:09 PM
1976 25' Caravanner
Salt Lake City
, Utah
So that's what it is. I was wondering, and will check it out. And also duplicate your research. I appreciate your providing the info very much!
06-03-2014, 10:00 AM
Richardson
, TX
Another What Is It?
Here is a pic of the wall to the right of the refrigerator cabinet showing a wall outlet and then two holes for something. Can anyone tell me what went in those two holes? They look like low voltage switch areas but don't really know.
I am also wondering what the round hole to the left in the picture would have been for. It would have been behind the refrigerator vent scoop.
Any help is greatly appreciated.
06-06-2014, 05:52 AM
1975 25' Tradewind
dallas
I need one of those...do you have a part number from vintage part...can you post a pic of what it looks like completed?
Sent from my SM-N900V using Airstream Forums mobile app
06-06-2014, 08:55 AM
Richardson
, TX
Cover for Fiber Optic Tail Light Monitor
Here is the link:
They say it is a formed aluminum replacement cover for the white plastic cover, which would help explain the white remnants still attached to mine.
I'll post a pic when I get mine in and installed.
