11-06-2020, 10:58 AM
Topeka
, Kansas
NT22A Furnace replacement
I have a 1971 25' Tradewind with what appears to be the original NT22A furnace and I believe it needs to be replaced. I would appreciate suggestions as to what to replace it with. I know that the 22000 BTU is no longer available. Can anyone tell me if the NT30 would be a direct replacement, or will I have to modify the ductwork?
11-06-2020, 11:15 AM
1993 34' Excella
Estancia
, New Mexico
You can use a new NT30 but you have to make some modification. You need to build a base to raise the furnace to a level which will line up with the original inlet/ exhaust outlet. If you want to use the original ductwork you need to build a plenum. I used wood for the new base and repurposed the old furnace cabinet to use as a plenum. I believe you can find this info in the archives if you do a search If you need more help let me know.
By the way the NT22 was recalled because of CO leaks.
11-06-2020, 01:40 PM
1972 23' Safari
Middletown
, Rhode Island
I just did this install a few months back....
I used the nt30s for my 1971 replacement furnace, I used the original plenum and had to raise it as well to line up with the furnace exhaust holes. PM me if you need any help.
11-06-2020, 01:56 PM
1976 Argosy 28
Buford
, Georgia
Just recently did this on my 76, it had a NT24 but the idea was the same. All I had to do is raise the furnace up, I think it was about 1.5 inches or so. Everything else lined up. I found the NT-30 online and paid somewhere around $600 shipped. Good luck!
John
12-03-2020, 12:13 PM
Topeka
, Kansas
Thanks all for the replies.
Anyone have some pictures of the modifications used? I have removed the old unit and am ready to rehab the old case/plenum for the new unit.
12-04-2020, 04:20 AM
1976 Argosy 28
Buford
, Georgia
Bill,
I will post some pictures later this morning of what I did and what I would do differently.
John
12-12-2020, 07:00 AM
1976 Argosy 28
Buford
, Georgia
Bill,
Sorry for the delay, here are the pictures of the way I did it, the 2x4's are OVERKILL and I would have scaled it back some (like 2x2) if done again. also I had to raise the front up about 1/2" vs the back(side against the skin) due to the curve in the trailer - Hope this helps..
John
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
More on replacing NT22A with NT30SP
RichHog |
Furnaces, Heaters, Fireplaces & Air Conditioning |
17 |
02-24-2013 08:00 PM |
Refitting NT22A Suburban furnace
oxfletch |
15 |
11-17-2010 01:36 PM |
Replacing NT22A furnace with a NT30SP
vhord |
1 |
02-24-2009 01:00 PM |
Free stuff, Suburban NT22A furnace and more
bmklawt |
14 |
01-21-2009 09:14 PM |
Replacing the NT22a with an SF-20 Anyone done this
Thealt |
5 |
02-03-2008 11:18 PM |
