Old 05-11-2020, 11:56 AM   #1
Maumelle , AR
Exterior Cleaning Problems Handprints
After cleaning my new* 1971 Tradewind with warm soapy water, it looks no different if not worse. I have problems with handprints down the side I am unable to remove and black scum at the front. And tips on cleaning the old number residue?
Help me choose a product to clean these. Having heard many a cautionary tale I am fearful of damaging the original finish.
Thanks in advance!
ID:	367705Click image for larger version
ID:	367706Click image for larger version
ID:	367707Click image for larger version
David Plate is offline   Reply With Quote
Old 05-11-2020, 12:11 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
Try Griot's One Step.
Old 05-11-2020, 03:53 PM   #3
2018 25' International
Slidell , Louisiana
If some of the number discoloring is remaining adhesive, try WD40 and also try butter.
Old 05-11-2020, 06:13 PM   #4
Maumelle , AR
Thank you! It is adhesive residue on the front.
I will do it and post back my results!
Old 05-11-2020, 06:20 PM   #5
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
Paint thinner is a good solvent, that is not at all corrosive...
Some of what you are seeing is likely the result of the clearcoat breaking down, and the subsequent oxidation, etc.....
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 05-12-2020, 12:30 PM   #6
1996 25' Excella
Tillsonburg , Ontario
Yes! Paint thinner (Varsol) is not corrosive and will need a little elbow grease. BTW the main ingredient in WD 40 is Stoddard solvent; AKA Varsol along with some light penetrating oils.
The hand prints are probably etched into the plastic finish from some inadvertent contaminated hands. You can try some light polishing but try it in a less obvious location first.
JCW
JCWDCW is offline   Reply With Quote
Old 05-12-2020, 01:14 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
In a not so noticeable place, wash the area with lacquer thinner, then spray on some new clear coat. The older clear coats were lacquer based. Volatility is why EPA made Airstream stop using lacquer.
guskmg
Cleaning Agent (Aluminum Exterior) Cat Cleaning, Stripping & Polishing 21 07-24-2020 08:44 PM
How do I remove handprints? Marlin4622 Cleaning, Stripping & Polishing 2 04-30-2019 07:49 AM
Basic exterior cleaning of a neglected trailer Andy R Cleaning, Stripping & Polishing 12 05-10-2013 11:03 AM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
What do you use for exterior cleaning? RedSHED Cleaning, Stripping & Polishing 11 05-11-2006 06:15 PM
