Old 10-19-2004, 01:35 PM   #1
Question International heater 1525 questions?
Greetings safari owners! I have just joined your ranks and I have many questions. My first project is the furnace, it is the original unit and does work, but not optimally. The pilot lights, but goes out after the main gas feed turns on. There is also a large rust hole that I believe is connecting the trailer to the "combustion chamber" At any rate it looks scary. My question is this. Can I get parts for this unit or find anyone to work on it or should I scrap-it and sleep in comfort knowing I spent 650 bucks on an updated unit? Thanks for your time.
Cheers
Lou Bartell is offline   Reply With Quote
Old 10-19-2004, 01:49 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Lou,
I kept my 1967 Suburban furnace. Check this thread out for things to keep in mind. In the very last post, I discussed a solution to the very same problem you are having with the pilot light blowing out.
Tom
Old 10-20-2004, 12:31 AM   #3
I am making progress
Thanks Tom, the threads were very informative and I have just completed removal of my furnace. The only way I could light it in the first place was by poking the pilot with a safety pin. I think a good cleaning could go a long way!
I see alot of corrosion on the unit but I am trying to stay positive. Best rgrds
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water Heater By-Pass? TroutStream Water Heaters, Filters & Pumps 4 09-01-2004 07:15 PM
Tow vehicle for a 1968 international 28ft gomrac Tow Vehicles 11 04-11-2004 08:40 AM
2004 International CCD 25C Lug Nut 2002 - 2005 International 4 07-16-2003 07:24 AM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2002 - 2005 International 29 11-07-2002 04:11 PM
