Old 03-20-2008, 03:40 PM   #1
1965 22' Safari
DUGWAY , Utah
How much do you think it would cost to repair bellypan?
I picked this 1965 Airstream Safari up last week for about $2K and on the way home some of the belly pan came off. How much do you think it would be to repair and does anybody recommend anywhere good preferably on the west coast. I've attached some pics tell me what ya'll think.
James Moore
Dugway Proving Grounds,Utah
ID:	56589   Click image for larger version
ID:	56591   Click image for larger version
ID:	56593   Click image for larger version
ID:	56595   Click image for larger version
bnhilfiger is offline   Reply With Quote
Old 03-20-2008, 03:45 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums!
There are several places on the left coast, depending on where you are with it.
You can contact Inland Andy (www.inlandrv.com). Even if he's too far away from you, he may be able to point you in the direction of someone that can help you.
Old 03-20-2008, 03:56 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Or you could do it yourself...a rivet gun & the rivets would be less than $75 ~ if you need to replace the aluminum it'll cost about $200 for a sheet 4'x12'
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 03-20-2008, 04:50 PM   #4
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Exclamation It looks like you have a bit of work ahead of you!
You got a pretty good deal on that Safari. However, it's going to take a bit of work. But there are lots of us that have been down that path!
First, it really appears like you probably have a bad axle. The axles used at the era of your trailer used rubber to absorb road forces. As it gets older, the rubber stiffens and stops providing a cushion. As a result, the trailer rides very bouncy, it causes twists (stressing rivets) and the bottom can things with the kind of results you photographed. This is a significant repair. Up from that, you could mail order one (there are a number of manufacturers of trailer axles with equivalent products). Depending on your skills, you could either install it yourself or hire a local mechanic to install it (they can also measure for ordering it).
The second thing I see is that you do have a bit of surface rust on your chasis. I'd suggest treating it before it gets worse. It is a fairly easy DIY project to treat the exposed metal (there are spray-on auto body treatments for rust conversion and paint that work effectively in situations like this).
There also seem to be a dark spot on the underside of the decking that might indicate rotted wood. Since your belly pan is open, take the opportunity to probe it aggressively. If it is compromised--you're going to have to replace it. You also need to check other places for similar damage.
Finally, there is the belly pan. I can't tell, but it looks like it was patched once before. On all the early 60s trailers I've seen, the belly pan is constructed from two long sheets of 4' wide aluminum sheet goods running the length of the trailer, joined at the center. With the monocoque design, the belly pan is an integral part of the stability of the whole upper body and is attached with buck rivets up in the walls. Consequently, you shouldn't see any lateral line of pop rivets underneath and you should see a center line seam where the two sheets of aluminum are overlapped and riveted together.
You may be able to simply re-patch or you may find you will need to get into more structural concerns. Replacement aluminum is not horribly expensive. However, installing a belly pan is very fiddly, tough to reach and complicated to install, since a full replacement requires removing the furniture and the inner wall panels of the trailer. That is time consuming, at the very least.
You are going to have to have someone experienced in this make an on-site analysis of whether the old patch is problematic or not in order to fully guage the scope of the repair. I don't know how the vintage community is in your area, but it's a good idea to find an experienced restorer (with structural experience with early 60s/late 50s trailers) to help you guage your situation. Checking the Vintage Airstream Club or members of this forum to find someone reasonably local. The advice you would get would be most impartial and probably will save you considerable money.
However, this opening does open opportunities--to identify if there are other concerns you need to attend to and for possibly installing a grey water system.
We've faced these problems ourselves, so don't feel you are alone. Hang in there--the result will be worth it!
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 03-20-2008, 04:52 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Do it yourself. Then you can inspect the frame, rustproof the frame, replace the insulation and other items that may warrent repair the right way.
Contact
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
for the large headed rivets used on the underbelly.
2004 Excursion 4x4
Old 03-20-2008, 07:44 PM   #6
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
C&G in Bellflower works as well.
Michelle TAC MT-0
Sarah, Snowball
Frame rust, POR15, bellypan repair davidz71 Repairing/Replacing Floor &/or Frame 2 09-04-2007 04:50 AM
Bellypan Woes Uncle Jack Belly Pans & Banana Wraps 2 07-02-2007 03:10 PM
Bellypan Rivet Repair 66Overlander Belly Pans & Banana Wraps 19 09-15-2004 02:58 PM
