Old 07-28-2003, 06:50 PM   #1
Oceancontainer's Avatar
Curb Side & Front Glass Window & Clips
What is the degree of the curve on this window and who has the clips at the bottom that secure it to the hand crank thingy.
Is this window suppost to be in some type of aluminum frame or is it just tempered glass ?
The front window, is it flat or curved ? Where can I get the clips at the bottom that secure it to the hand crank thingy.
Would anyone know where I could get these original pieces of glass and price ?
Oceancontainer is offline   Reply With Quote
Old 07-28-2003, 06:55 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Looks like you have the Corning glass windows there...the good news is they are beautiful! The bad news is, they are no longer made. That's why you will find a lot of these '66-'68 trailers with Lexan or plastic in the windows. They original Corning glass windows will occaisionally come up on eBay...but get out your checkbook and be prepared for some competition!
Shari
Old 07-28-2003, 07:04 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Oceancontainer!
The 1966 through 1968 coaches had Owens Corning windows that have been obsolete for a number of years. Once in a great while, one might be uncovered in New Old Stock at a dealer; but beyond that new Corning windows are VERY scarce. The earliest of these coaches did not have frames along the perimeter of the glass while the later coaches did - - I am not certain but believe the progression was '66 no frame around perimeter of glass - - '67-'68 perimeter glass frame. Today, an RV salvage yard or E-Bay are the most likely sources of a Corning window to replace a broken or missing window. Many will use Lexan to replace a broken or missing Corning window either as a permanent repair or as a "make-do" until a real Corning unit can be found.
Inland RV has the clips, operators, and frames for some of the Corning windows listed in their on-line catalog that can be found at:
Inland RV On-Line Catalog
Good luck with your search for Corning Windows!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Front curved glass window protectors Lovecraft Rock Guards, Segment & Window Protectors 10 05-12-2006 01:57 PM
Curb side galley window pipsmith22844 Upholstery, Blinds, Walls & Interior Finishes 1 03-16-2004 09:10 AM
Stained Glass on Front Window Gwen Our Community 1 08-03-2003 12:36 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
side front window for '74 Argosy dootsie Windows & Screens 2 10-23-2002 08:28 AM
