If you are looking to repaint with something that looks like Zolatone, they still make it, so you can paint over Zolatone with Zolatone. If you don't want to repaint with it, you can use a household semigloss, the Vintage People will probably hang you in effigy, tho.
The insulation under the floor can be regular fiberglass insulation, that's pretty much what was used when it was built. At least, that's what is in the belly pan area of our 63 Overlander.
