Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 03-04-2005, 12:12 PM   #41
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
pictures!
These are various pictures of our floor tearout so far. Yes, we did chop off the lower few inches of the inner panels because we're either going to replace them or put in a baseboard of some kind. For now we left them in for structural reasons and for less work!
The floor is bad all the way around on the edges. Makes it a little easier to get it out! The picture of the step is to show the pitted damaged area, and the welder is going to make a new doorframe for us too. Half of it is missing as you can see.
Does anyone know if POR15 takes a weld after it's on? I'll have to remove some if not. Not very much though.
ID:	10698   Click image for larger version
ID:	10700   Click image for larger version
ID:	10703   Click image for larger version
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 03-25-2005, 01:30 PM   #42
1967 24' Tradewind
Images: 38
bought a window!!
I bought a piece of Lexan at the local glass shop, it was $100.25 total. It came the next day! So I have it in my possession, I've read over the window replacement information at the www.airstreamdreams.com site, and I'm ready to give it a try. It's good that I can do the first one on Lexan to see how it goes, for practice.
Time to get glue and gasket, and I'm on my way! Wish me courage! I'm already very lucky.
i.
~ Hurley
ingrid
Old 03-25-2005, 03:49 PM   #43
ingrid.
Lexan also has an AR-2 version.
The AR-2 means it is abrasion resistant on both sides.
You can actually scrub it with steel wool, without scratching it.
That is the only type we offer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-25-2005, 05:37 PM   #44
1967 24' Tradewind
Images: 38
Thanks Andy,
I checked and this one is not the abrasion resistant one. I'll look into the other kind if this one turns out to be a problem! For now we're trying to get it not leaking so we can finish the floor. The guy at the glass shop has offered me 20% off of future purchases so I may go back and get another one, if it's not too much more expensive.
i.
~ Hurley
ingrid
Old 04-05-2005, 10:43 PM   #45
1967 24' Tradewind
Images: 38
gasket in
We installed the gasket on the front window today.
~ Hurley
ingrid
Old 04-06-2005, 04:50 AM   #46
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
What? No pictures???
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 04-06-2005, 06:05 AM   #47
till's Avatar
Lisle , Illinois
Images: 108
Did ya wear rubber gloves to keep the "swamp snot" off your hands??
I have to say that the 39" windows are a bear to install gaskets on. A two person job to say the least. Keep going!!!!
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 04-06-2005, 10:36 AM   #48
1967 24' Tradewind
Images: 38
ok ok
I'm glad someone's actually reading my thread! I'll post a picture here in a while. Husband had to do it. He tore up three or four latex gloves, till.. We've decided I'll remove the old gasket and he'll put on the new. I put the old one on upside down (blonde moment for sure).
~ Hurley
ingrid
Old 04-06-2005, 10:41 AM   #49
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I'm still reading the thread too, Ingrid! Great to see you continuing to plug along. How's the frame work going? Had the welder out yet? As far as I know, welders need to get to bare metal to make a weld, so you WILL be re-applying the POR-15 over the welds when he's done. That's why I waited until after welding to paint. You'd do a little of that anyway, because you don't want the new welds to rust.
Keep at it!
Stephanie
Old 04-06-2005, 10:48 AM   #50
1967 24' Tradewind
Images: 38
Thanks! Good to know people care...it helps me stay motivated, to post progress and look back.
The frame needs no welding in the exposed area. I don't know what to weld and what doesn't need welding, so finally Jeff and the welder got together, talked about it, and told me to go ahead and paint over the front of the frame under where we removed the floor so far. I did that. Next the window goes in, front floor goes back in, and more floor comes out in the middle of the trailer. (I didn't paint any further back underneath the trailer, I decided it wasn't worth it until the floor came out and welding was done). Then I think some welding needs done in the middle of the frame, but very little. I can finally comfortably say that our frame is in pretty good shape. We continue like this until the frame is all welded, painted, and floor is all in.
Then, they say, the fun begins. Interior!!
~ Hurley
ingrid
Old 04-06-2005, 11:32 AM   #51
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Sounds like your frame was in better shape than mine! That's good news.
I'm elbow deep in finishing up the interior myself now. Lots of detail work. Goes slow when you don't know much about woodworking.
Stephanie
Old 04-06-2005, 05:37 PM   #52
till's Avatar
Lisle , Illinois
Images: 108
Keep going!!! I just did another window gasket.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 04-06-2005, 08:33 PM   #53
moogie32's Avatar
1967 22' Safari
Branford , Connecticut
Images: 11
you go girl!
Hey Ingrid! Keep up the good work! I'll be doing my windows soon enough when they come in and I'll be drawing on your expertise (yours too, Tedd!). Have you guys tried Nitrile gloves? We use them with chemicals at work - I'm pretty sure they're available commercially....I don't even dare think about the frame.....
moogie32 is offline   Reply With Quote
Old 04-08-2005, 05:47 AM   #54
1967 24' Tradewind
Images: 38
we put the gasket on upside down. turns out I had it on correctly, but I had cut it on the corners. jeff made a beautiful fit, and...it's completely wrong.
Time to step back and take a break. At least I haven't messed up the painting!
~ Hurley
ingrid
Old 04-08-2005, 07:03 AM   #55
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Did you happen to get pics of how it went in? Anything to watch for to make sure you have the correct orientation? Keep up the good work and you know we're allways looking for updates!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-08-2005, 01:20 PM   #56
1967 24' Tradewind
Images: 38
Thanks!
I didn't know that my husband didn't see the picture I had of how it goes in and he just did it the way he used to do when he put in windows into cars as a teen.
Dumb mistake...the rain will keep us away from it for a few days!!
~ Hurley
ingrid
Old 04-08-2005, 08:59 PM   #57
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Talking Hang in there!
"the sun'll come out tomorrow.....". At least you're able to work on your baby. Moby's still on blocks in the barn. Hubby still working on electrical problem concerning the brakes. Can't wait to put on new tires and drag him out (Moby, not husband) into the sun. I can see inside so much better with natural light. Took some pictures of what the missing parts are supposed to look like when I visited with eubank in Angel Fire.
I'm starting to get antsy......
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 05-07-2005, 12:46 AM   #58
1967 24' Tradewind
Images: 38
I'm a lucky mom.
I got this Mother's Day book from my daughter today. Here is page 1:
"My Mom can fix an airstream"
~ Hurley
ingrid
Old 05-07-2005, 12:55 AM   #59
eljay's Avatar
1968 24' Tradewind
That is absolutely priceless!
Eljay
Old 05-07-2005, 06:50 PM   #60
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
What fine Airstream art! Lucky Mom
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
62 tradewind - tires/wheels needed..... p.dow Tires 1 02-27-2004 08:24 PM
New Tradewind owner Tin Hut 1959-69 Tradewind 5 08-18-2003 06:24 PM
Odd VIN Number for Tradewind cherring Title, VIN & Registration 8 08-14-2003 12:03 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
