Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 04-18-2020, 09:00 AM   #641
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Misery loves company. Nice to hear I'm not the only one who has had difficulty with attaching plastic laminate. I did some homework (knowledge is power) and learned I must to the edges of the counter top first. I learned they sell a "slitter" tool designed specifically for cutting narrow strips for edges. I also learned I can use my "Rotozip" bits, which I call milling bits as they cut on their diameters, and cut narrow pieces that way. I've used the wooden dowel method to keep the laminate out of the glue until I have it positioned. Then I pull the dowels out starting in the center. I learned that using a board and a towel to press the laminate into the glue is better than a J rubber roller that I was using.
I have 4 pieces I must laminate here this next week. I'll probable learn some new cuss word sequences doing it. I might even try flinging a failed piece into the far corner of the shop. Good idea.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 04-18-2020, 09:52 AM   #642
CC
1972 27' Overlander
Heinsburg , AB
Hard to believe your lack of experience, that turned out fabulous!
CC
Camper Crazy is offline   Reply With Quote
Old 04-18-2020, 11:06 AM   #643
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Originally Posted by Bubba L View Post
Good idea Wayne. I need to get me some slats. I have a whole stack of the wood yardsticks they tend to give away periodically at the box stores that I use. I like the slat idea better. Thanks
Also wood dowel rods work good too.
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
Ultraclassic is offline   Reply With Quote
Old 04-19-2020, 07:38 PM   #644
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Originally Posted by TouringDan View Post
Slats
I was zoning in on your beautiful Formica work and see that you installed an Isotherm fridge. That is on my wish list. Is it a compressor fridge? What is the model number?
I too really like the white Formica with the walnut.
Dan
Hi Dan -
It is an Isotherm Cruise 130 Clean Touch Stainless Steel model. It is quite, cools really well and makes nice ice cubes in fairly short order. It also looks cool and compliments the Furrion gas range across the way. I built a platform for it so that it would be more easily accessed. The storage area created under the platform is not the best, but who cares? (At least who cares until who does, as in when we actually get on the road and miss a more efficient storage area.)
Slats is offline   Reply With Quote
Old 04-21-2020, 04:26 PM   #645
Slats's Avatar
1966 24' Tradewind
kitchen countertop coming along
Here's the latest installment in the Formica follies.
Name:	200420 01 kitchen countertop.jpg
ID:	366276   Click image for larger version
Name:	200418 kitchen countertop 3.jpg
Name:	200420 03 kitchen countertop.jpg
Old 04-21-2020, 07:43 PM   #646
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the photos of the formica follies. It is a great looking galley countertop in your Trade Wind. Any troubles applying the plastic to the plywood? I bet you used Slats to to the job. Wait, that's you.
We've got this job coming up real soon.
David
Old 04-21-2020, 09:46 PM   #647
Dwwalker18's Avatar
1967 24' Tradewind
North Pole , Alaska
That looks awesome!
Dwwalker18 is offline   Reply With Quote
Old 04-22-2020, 11:23 AM   #648
Slats's Avatar
1966 24' Tradewind
Thanks, Dan. Of course, you can’t see the shims.
And David, as you might expect, I stayed away from using slats, employing 1/2” wooden dowels, instead. They worked great.
Old 04-22-2020, 11:58 AM   #649
2007 22' International CCD
One really great tool for applying laminate is to use several old mini blind or Venetian blind slats to support the laminate whilst you align it.
Old 05-15-2020, 07:50 AM   #650
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
Dale - the cabinetry and countertops are looking great! Once things settle down with the pandemic us KC area airstream restorers should meet up again. I’d enjoy seeing everyone’s progress in person.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 05-15-2020, 11:26 AM   #651
BURNZEE's Avatar
Riverside , Missouri
I'd also like to meet again. I'm getting close to having my Safari road worthy. Maybe September?
BURNZEE is offline   Reply With Quote
Old 05-15-2020, 04:27 PM   #652
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
Bryan, good to hear from you. Can’t recall, what year is your Safari? Looking forward to seeing it.
Old 05-15-2020, 05:38 PM   #653
BURNZEE's Avatar
It's a 66.
Old 05-15-2020, 06:39 PM   #654
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
Sharp looking trailer, Bryan
Old 05-15-2020, 09:58 PM   #655
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Very nice Safari. Love seeing just the vents on top without an A/C ruining the lines. Of course I am biased.
Dan
Old 05-16-2020, 06:01 AM   #656
Slats's Avatar
1966 24' Tradewind
Brian and Bryan -
Let’s indeed get together this fall, hopefully with no second wave messing up our plans. The Roasterie parking lot gives us plenty of room for social distance and coffee sipping. The same goes for Danny’s new man cave - make that cavern - adjoining the parking lot, where he now parks his company Airstream and Priscilla, his diesel-pusher Airstream.
Old 05-16-2020, 01:08 PM   #657
BURNZEE's Avatar
I also prefer the no AC look, but I'm getting ready to put one up there. . At least till I can wheel to places with milder temps.
Old 05-17-2020, 02:03 PM   #658
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
My 5k AC rides in the bottom of a closet until I need it. It takes about 10 minutes to install. We typically camp in the mountains or northern Michigan so we usually don’t need AC.
I have a thread in the AC section from about 5 years ago.
DanClick image for larger version
ID:	368101Click image for larger version
Old 05-18-2020, 05:53 PM   #659
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Looking nice , good work .
Joyflea is offline   Reply With Quote
Old 12-16-2020, 07:54 PM   #660
Slats's Avatar
1966 24' Tradewind
Been laying low, sort of. We sold our home of 31 years, got rid of that many years worth of accumulated stuff in our attic, basement and garage, bought a condo and moved. The toll it took on my head was a little surprising. Glad we didn't wait any longer to pull the whole thing off. I can't imagine doing it ten years down the road. But I've come back up for air and am getting back into plunking away on the trailer. Finally got that chimney bell mounted as level as could reasonably be expected. Replaced the valves in the propane tanks today and started prepping the tanks for painting. Also ordered a 42 gal. fresh water tank. Good to be back.
Dale "Pee Wee" Schwamborn PeeWee Member Introductions 53 01-02-2011 03:38 PM
Frederik Meijer Gardens & Dale Chihuli Art Pahaska On The Road... 6 07-25-2010 08:58 AM
PeeWee (Dale S): thomwessels Airstream Motorhome Forums 4 01-07-2010 07:33 PM
Dale Earnhardt Jr. 68 Overlander Off Topic Forum 44 08-31-2007 12:54 AM
Dale Earnhart parking wildcat455 Off Topic Forum 2 02-17-2004 10:01 PM
