Old 09-08-2004, 11:05 AM   #1
'66 Tradewind Basics
I have recently started restoring my 66 Tradewind. Is there a manual (Airstream 101) that covers electrical, plumbing, LP schematics? Due to wood rot, I have started to replace the bathroom floor. All appliances seem to be the original, however I have not tested any to see if they work. Any suggestions? While I have you attention, I have noticed on the curbside exterior there is place where an electrical outlet used to be. The outlet is missing and the wires are exposed. The wire insulation has been melted (possible small fire). The porch light cover has melted. Could these two be related? What is the outlet for? Your thoughts for both of these problems and any other advice is much appreciated? The forum has been a great resource for me and I look forward to using it daily.
Bill Thomas
Tallahassee, Florida
66 Tradewind is offline   Reply With Quote
Old 09-08-2004, 12:31 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
66 Tradewind Basics
Greetings Bill!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by 66 Tradewind
I have recently started restoring my 66 Tradewind. Is there a manual (Airstream 101) that covers electrical, plumbing, LP schematics? Due to wood rot, I have started to replace the bathroom floor. All appliances seem to be the original, however I have not tested any to see if they work. Any suggestions? While I have you attention, I have noticed on the curbside exterior there is place where an electrical outlet used to be. The outlet is missing and the wires are exposed. The wire insulation has been melted (possible small fire). The porch light cover has melted. Could these two be related? What is the outlet for? Your thoughts for both of these problems and any other advice is much appreciated? The forum has been a great resource for me and I look forward to using it daily. Tallahassee, Florida
In regard to a "restoration manual" for our Vintage coaches, none exists. What we do have is the minimal owners' manuals that began with the 1964 models - - not always greatly infomrative, but at least a source of information. If you don't have an owners' manual for your coach, you can get a copy of one using the infomration from the Vintage Airstream Club website that is quoted below:
Manuals
Q: I need an owners and service manual for my Airstream. Where can I get one?
A: The first owners manuals were published in 1964. Prior to that, the owner received a brown envelope containing parts lists and other helpful information on the accessories in his trailer. The VAC has started making these available in the Members Archive section. A service manual with instructions for performing service operations did not exist until 1972.
You can get photocopies of owners manual (1964+) and service manuals (1972-1986) from:
Helen Davis Secretarial Services
PO Box 484 Sidney, OH 45365
(937)492-8885
Prices are about $33 and $70 respectively. After 1986 the Owners Manuals included available service information.
A general reference guide such as Bob Lifingston's RV Maintenance and Repair Manual has often been suggested as a resource for restoration.
In regard to testing the LP operated appliances, I would urge you to have a qualified RV LP technician inspect and evaluate those appliances. The charge is usually modest, but it will give you a baseline condition analysis of the LP system - - it is one of the first things that I had done after purchasing both of my coaches.
In regard to the electrical outlet on the side of the coach, its function relates to its actual position. If it is on the lower body, it was a weatherproof outlet for use as a power source for electric devices when camped with hookups. If it is on the upper body, it may have been a single-outlet porch light fixture - - it was an option during at least part of the 1960s as my Overlander still has its porch light - - the outlet and the fixture are in the photos below:
In regard to the "porch light" that is often referred to as a "scare light", the bulbs are known to run hot and it is not uncommon to find a lense that is deformed or partially melted. Andy of Inland RV has posted to a thread here on the Forums regarding the most compatible bulb for this particular fixture. The lenses as well as the entire fixture are readily available from Airstream dealers as well as some truck supply outlets.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 09-08-2004, 08:30 PM   #3
Kevin,
Thanks for the advice and the welcome. I have many more questions to come.
Bill
