Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Tradewind > 1959-69 Tradewind
Old 04-29-2019, 05:51 AM   #1
1968 24' Tradewind
parker , Colorado
1968 Tradewind Shower Valve and Faucet Recommendation Needed
Has anyone replaced the shower valve and faucet on the original 1968 bathtub? I would like to use the original holes but have not found a faucet that I am convinced will work.
Also, any toilets that have been verified to fit the original nook?
Thank you.
1968 International Tradewind Restoration Thread
https://www.airforums.com/forums/f11...on-178655.html
Venturewest is offline   Reply With Quote
Old 04-29-2019, 06:11 AM   #2
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence , Kansas
I have not replaced mine on my 64 but the guy before me did. I know it is not the same as your 68 but it looks like the tub faucet was modified. I am going to have to go back into it and find a way to make it look better. I am thinking an aluminum back plate to cover where he cut up the fiberglass or some kind of trim. It appears without taking it out that the faucet trim was the problem not the water intake holes.
ttbikes is offline   Reply With Quote
Old 04-29-2019, 06:15 AM   #3
1964 24' Tradewind
Lawrence , Kansas
You should post a picture of your toilet set up.
Old 04-29-2019, 07:21 AM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
The original 1968 SeaLand Traveler is very rebuildable, and about the best you can find. Dometic now owns SeaLand, and sells comparable models. If you wish the originality and convenience of the 1968 “dressing seat”, the toilet cannot be higher than the tub and rearmost shelf.
If the dressing seat isn't incorporated into the bath's design, consider the LoggerHead, by SeaTurdal (I'm not giving up that joke yet).
It appears that the International trim level has different bath fixtures than LandYacht. If you haven't originals to rebuild, then a large escutcheon plate and modern valve may be the only way.
http://www.rvrepairmanual.com/manuals/Sealand.pdf
ID:	339359   Click image for larger version
Name:	loggerhead by sea turdal.jpg
ID:	339361   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 04-29-2019, 01:36 PM   #5
1967 26' Overlander
Spartanburg , South Carolina
Thank you.
I replaced the bathtub faucet on my '67 Overlander Land Yacht with a new Alsons Handshower Mix Valve. It was a direct swap, exact fit to the tub, shower wand and original copper piping. The outward appearance is identical to the original and the valves are newest modern design without washers. I can not find the packing slip but the bar code label on the box reads 1050 BX at the top of the label and the bar code number is 80776 00507. They are Alsons Corporation located in Hillsdale Michigan 49242. Their customer service was excellent.
Jacob D is offline   Reply With Quote
Old 04-30-2019, 07:02 AM   #6
1968 24' Tradewind
parker , Colorado
Thanks for the responses. I didn't realize I hadn't attached the photo of the tub, where the original faucet would have been.
It sounds like that Alsons will work. Thanks for the tip! I am going to google those components right now and cross my fingers that they are still available.
Old 04-30-2019, 07:08 AM   #7
1968 24' Tradewind
parker , Colorado
Thanks, I have been looking at the Dometic models. I will just use the measurements on the diagram to ensure they fit.
Old 04-30-2019, 07:13 AM   #8
1968 24' Tradewind
parker , Colorado
That’s the hole configuration. Delta now owns Alsons, so I will see if I can still get those parts.
Old 04-30-2019, 08:06 AM   #9
NO HUMBLE OPINION
That'd be great if you can find original fit. It's often a game of search and wait to find just the right part.
My '68GT came with a 1967 Alsons brochure. Evidently, a touted feature is that you can bathe without getting big hair wet.
There's also a brochure showing big-hair wifey in high heels, serving a Butterball (Beatrice Foods) Turkey, on a table set with china, crystal and silver, in a 1968 Sovereign International.
There's an image of her putting on lipstick at the light-up swing-out-tip-down movie star make-up mirror in the bathroom.
Name:	Alsons bathing beauty 1967.jpg
ID:	339444   Click image for larger version
Galley Faucet Recommendation ShinyChurch Sinks, Showers & Toilets 5 06-06-2023 02:42 PM
Interstate Shower Head / Faucet / Mixing Valve nvestysly Sprinter and B-van Forum 15 10-23-2017 05:37 PM
Very low water pressure to galley and shower. Toilet and bath faucet work as usual lanewoodwork Sinks, Showers & Toilets 6 08-21-2017 02:24 PM
Shower Faucet part needed dlowrey Sinks, Showers & Toilets 2 03-18-2010 01:01 PM
Shower Dribbles ... Faucet and Toilet flow great Killo1 Fresh Water Systems 3 03-18-2007 08:54 PM
