06-30-2020, 07:11 AM
#221
1966 22' Safari
Fredericksburg
Originally Posted by islandtrader
I remember seeing that on your build page...If you don't mind repost some pictures and the track mfg. here. I know when I looked at it I liked it, but could not figure out the track set up.
Kent, l’ll get you the information. Take care
07-10-2020, 07:47 PM
#222
1956 22' Caravanner
Don Pedro Island
Not Good
07-10-2020, 08:41 PM
#223
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Have not heard of f channel before. I'm sure that letter refers to the profile. Where is F predominantly used? Or is that the word you were using while trying to work with it :-)
Hittenstiehl
07-11-2020, 06:04 AM
#224
1956 22' Caravanner
Don Pedro Island
I guess you would call it a bulk head wall moulding. Used to fasten the 1/4 inch plywood to the inside skin of the trailer...YES I DID use the F word..only once!
Called F channel because it looks like it...same as C or U channel.
07-11-2020, 06:47 AM
#225
1966 22' Safari
Fredericksburg
Dan, that F channel seems about half tempered. I had a heck of a time, not only bending it but keeping it on the template while bending. I see you used stop blocks which sure makes it a bit easier. On the edge toward the inside of the cabinet, I drilled a few holes in the channel and placed a 3/8” pan head screw just to hold things until against the wall. May not be able to do that with 1/4” ply. I used 3/8” that I ran a dado along the edge to get the channel to fit.
Also, don’t know if I sent you the type of barn door hardware I used for the rolling bath door. We bought the hardware from The Hardware Hut. It’s adjustable. Take care
07-18-2020, 03:19 PM
#226
1956 22' Caravanner
Don Pedro Island
What I learned!
On my previous post I went through the agony of trying to bend a F channel. And stated 75% success.
What I learned on the second try is to use the big radius buck and start from the middle to get a gentle curve. After that I then cut a smaller radius curve and started doing very small increment bends. After each one a trip to the trailer and then marked the area that showed a flat spot and heated that up and did a small bend. I think I must of made 30 little tweaks before I said good enough. I was shooting for 90% and I feel like I got there. Now the wall comes out and gets white washed. Then all the Curb side wood is done and gets clear coated soon.
07-23-2020, 03:09 PM
#227
1956 22' Caravanner
Don Pedro Island
Counter Tops
We picked a formica heavy duty non glare for our counter tops.
Just used weld bond contact cement and a couple of scrap boards and done. My trim router took a dive, so I thought I would give Rigids new cordless trim router a try. Most of my battery tools are rigid so I have plenty of spares. The router worked very well. I don't think you would want to use it on anything but trim ...not enough horse power.
Ordered up some aluminum trim from VTS. It bent nicely using a dead blow hammer. The screws supplied are kind of funky, so I ordered up some S/S ones from Amazon.
Still need to clear coat the bathroom panels. Just waiting for a non windy day.
07-31-2020, 06:13 AM
#228
1956 22' Caravanner
Don Pedro Island
Wiring
Such a Fun Job...terminating DC wires...
08-19-2020, 07:10 AM
#229
1956 22' Caravanner
Don Pedro Island
Power Center
Finally got my power center mostly done. I used an old cigar box to house my DC switches and battery monitor. I have had that box for a long time...thinking that I could use it for something. Never had any idea that it would be perfect for this type of application.
The power center houses the main AC panel,DC panel, surge protector, and a 4 stage-converter.
Sliding, 1/4 inch plexi doors to cover it, but not hide it.
There was a lot of things going on here...but I think I got it nailed down. The battery on off switch will be installed after the batteries are installed. Batteries will be installed directly below the power center.
All of the walls are done, just need to install them...easier to work inside without them so they will most likely be the last thing to get attached. Water heater and propane lines are most likely the next thing to attend too.
08-19-2020, 08:57 PM
#230
1966 24' Tradewind
1987 34' Excella
Olathe
, Kansas
Very nice
Looks really clean and tidy! Nice work.
08-21-2020, 02:37 PM
#231
1956 22' Caravanner
Don Pedro Island
More Wiring
Today I decided in case I need to move the Airstream in a hurry (think hurricane) I should really tidy up my trailer wire connections. I choose a junction box type connection, to my way of thinking this works a lot better than having a direct or quick connects. I suppose it is a matter of choice.
Seven pin terminal box.
After I attach the propane tanks I will make sure the wiring is clamped down and stays out of the way.
08-21-2020, 02:46 PM
#232
1960 33' Custom
Athens
, Georgia
That all looks really tidy. Have you found a decent break away switch? (I used a VTS one and it looks bad already).
08-27-2020, 07:14 AM
#233
1956 22' Caravanner
Don Pedro Island
No need for one since it is built in to the new brake system that is installed.
08-31-2020, 06:22 AM
#234
1960 33' Custom
Athens
, Georgia
That sound neat, how does it work?
08-31-2020, 07:58 AM
#235
Perpetually Perplexed
Mobile Rail Bunkhouse
Farmington
, MO
Very impressive work!
I’m very early in my bunkhouse project and keep getting “vapor locked” mentally trying to figure everything out... am I correct that you worked out the layout, plumbing and wiring as you progressed through the build?
08-31-2020, 03:27 PM
#236
1956 22' Caravanner
Don Pedro Island
Plan your work...work your plan
If you go back to post #20 on my thread you will see that I made of rough sketch of what my wife and I thought would work for us...
So very early on we kept this floor plan in mind. You have to know where tanks are placed for the grey water and black water. This sets the plan in motion and is hard to change after the shell was put back on. we drew out sketches on the floor and kept honing in on the exact amount of space each area would use up.
After insulation was put in, we then decided where the outlets, lights and would go. Wired the trailer and then re-skinned the inside .
The build out of the inside was pretty much the way we thought it would be. I started from the back and worked my way forward making small adjustments.
There were days when I would just sit in the trailer measure and re measure to make sure things would fit. Tape the floor and do it all over again. Planning is paramount...there is no changing once you commit to the plumbing and that is very early in the build out.
Hope this helps.
09-09-2020, 07:17 PM
#237
1956 22' Caravanner
Don Pedro Island
LP Plumbing
Finally got my stuff together and now I am in the learning curve of cooper tube bending and layout. The hot water heater just arrived so stay tuned for that adventure...
Tools of the trade
Nice flare
09-09-2020, 08:49 PM
#238
1966 22' Safari
Fredericksburg
Hey Kent, while your having fun with your flaring tool, have you considered double flares? I found doubles more fun to make and I think they make a longer lasting seal. Just a thought. Take care
09-10-2020, 03:56 AM
#239
1956 22' Safari
1962 28' Ambassador
Williston
, Vermont
Now is a good time to add a quick connect, if you haven't already.
I added mine at the last minute and we use it every time we camp with a little Weber grill I modified for low pressure. The connector and hose came from Amazon. More gas flows through it than any of the other lines. - Mark
09-10-2020, 05:47 AM
#240
1984 27' Airstream 270
West Chester
, Ohio
We are using a SCRUM board. Post it notes color coded for each system and then moving each post it from “to do”, “in progress”, and “complete.”
The first board was for the deconstruction and water damage/leak repair. Once that was done, re-wrote the board and Second version was for system rebuild including plumbing, electrical 12v/120v, propane, cable/network. Now on the third version of the board which includes cabinetry, appliance, system check, and chassis (motorhome)
It’s too much to keep in your head, and moving post it notes is rewarding even when the work feels overwhelming and discouraging
It really helps us, hope it helps somebody else too!
