Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1960 - 1964 Overlander
Old 10-18-2015, 05:27 PM   #1
The Rambler's Avatar
1964 26' Overlander
Ingleside , Texas
Tricky Antenna Crank Handle Removal - 1964
Any suggestions on how to remove the antenna crank from the inside wall? Found set screw at end of handle but it frozen in place.
The Rambler is offline   Reply With Quote
Old 10-18-2015, 08:30 PM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Mine fell off by accident one day. The handle is secured to the shaft by a tiny set screw. The handle also secures a spring that presses the antenna twist locking grip used for rotating the antenna. Removing the set screw and the handle, spring, and twist grip all slide down off the shaft.
kscherzi is offline   Reply With Quote
Old 10-19-2015, 08:00 AM   #3
1964 26' Overlander
Ingleside , Texas
Thanks Kscherzi, but there lies in the problem, small set screw is frozen,rusted,seized, to the body of handle. Can't get enough torque using correct size screw driver up against the skin to break it loose. Also not enough room to get drill up against skin at proper angle to try and drill out set screw, Trying not to destroy handle in the process of removal. Thanks for additional breakdown of assembly.
Old 10-19-2015, 01:46 PM   #4
1964 26' Overlander
Ingleside , Texas
Was able to push back skin and drill old set screw out without ruining handle. Will have to drill and tap handle to re-use, thanks everyone for viewing this and trying to help.
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Help for specs on manual crank handle RLS Jacks, Stabilizers, Lifting and Leveling 7 01-28-2014 03:05 PM
Need a super jack crank handle deauxrite Jacks, Stabilizers, Lifting and Leveling 2 10-12-2012 10:45 PM
Ceiling vent crank handle Sneakinup Roof Vents, Skylights & Fans 4 12-02-2003 07:09 PM
