RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-14-2020, 06:25 PM   #1
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
Subfloor Measuments NEEDED PLEASE
Iíve got a 64(well Iím pretty sure 63 but itís titled 64) that I will be starting to work on soon. Itís gutted, frame is in really great condition, better than others Iíve seen/worked on. The subfloor had been removed and so Iím needing exact give or take measurements of side to side. That would be greatly appreciated if someone remembers off the top of their head!
Zach
Zcashio is offline   Reply With Quote
Old 11-14-2020, 07:30 PM   #2
2002 19' Bambi
Lafayette , California
If nobody can give you the figures, you can get very exact measurements using two sticks that are about 2/3 of the total width of the trailer. Slide them next to each other so that one end of each touches a side of the width to be measured. You can clamp them together and then measure the total length or simply mark across both sticks and measure to the mark on each stick and add the lengths. It is a common method and there is some discussion here: https://www.finehomebuilding.com/for...d-of-measuring.
Getting a precise measurement with a tape measure can be very difficult partly because of the tape's flexibility.
Tim
Tim A. is offline   Reply With Quote
Mouse prevention - subfloor openings = needed? Harrysheets Repairing/Replacing Floor &/or Frame 14 09-24-2017 07:13 AM
Please help - subfloor mmich21 Repairing/Replacing Floor &/or Frame 2 05-16-2016 02:27 PM
Subfloor Repair Advice please for a newbie Mary Burris Repairing/Replacing Floor &/or Frame 6 10-28-2013 09:23 PM
New subfloor pics, needed desperately Stupidnoob Repairing/Replacing Floor &/or Frame 2 01-24-2013 05:44 AM
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 04:15 PM
