Old 03-10-2007, 09:57 AM   #1
1964 26' Overlander
Kearney , Missouri
New Wheels
I need to replace the wheels on my 64 Overlander. Any thoughts regarding steel wheels vs. aluminum wheels?? Also does anyone know the speces for the wheels including bore size, lug nut specs, bolt hole pattern, load capacity etc..? The tires in the owners manual indicate a size of 7:00x15. What is the actual size of the wheel? Also any thoughts on radial tires and if so any particular brand??
Thanks!
64Overlander is offline   Reply With Quote
Old 03-10-2007, 01:05 PM   #2
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Wheels
Thanks!
Why not take a old wheel with you and have tire shop mach it up. The radial tires are the only way to go. When I swiched from bias tires to radial I picked up 2 miles per gallon on my tow vehicle.
Aluminum vs steel , depends on how much money you want spend.
Regards Russell in sunny and warm Tucson Az.
RUSSELL is offline   Reply With Quote
Airstream Wheels JAG Wheels, Hubs & Bearings 10 06-01-2006 08:54 PM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Airstream steel wheels davidz71 Wheels, Hubs & Bearings 0 05-21-2002 05:18 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
