Old 02-18-2012, 05:50 PM   #361
Lothlorian's Avatar
Loganville , Georgia
Sure, we would enjoy having you over again. Let me know when and I will have Adrienne cook up some Jumbalya before you come. The trailer is not going anywhere for awhile. My next big thing is to get it over to the trailer repair place by our house and have the running gear checked out. I still have to get under the belly pan and check out the dump valve.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-18-2012, 06:12 PM   #362
Remember, Safety Third
Jim & Susan's Avatar
Possum Trot , Georgia
You have a deal, brother. Better yet, try and make the Stone Mountain rally in April. That way many others can experience the new remodel AND Adrienne's jambalaya. Just a short trip for you guys.
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 02-18-2012, 06:20 PM   #363
Lothlorian's Avatar
It is a family members birthday that weekend. It won't happen this year. Maybe next. I am thinking the fall rally in the N. GA mountains. I have not taken any work off for three years and I plan on taking a couple of days in the fall.
Brian
Brian & Adrienne
Old 02-20-2012, 04:45 PM   #364
Lothlorian's Avatar
Today we finished the Goucho and put down the plywood on top. I used the old as a template and made an exact copy. I have plywood cut for the other twin and it is in place. My wife is making exact copies of the old accordian doors. She has tape marking where the metal rods will go. The doors will be the same material as front of the goucho.
Brian
ID:	151607   Click image for larger version
Brian & Adrienne
Old 02-20-2012, 05:45 PM   #365
Lothlorian's Avatar
I made sure all the vents for the furnace were tight and secure. It was a bit nippy so I went out to the trailer and cranked up the furnace. It was quiet and worked like a dream. air flowed evenly through the trailer.
Brian
Brian & Adrienne
Old 02-28-2012, 04:58 PM   #366
Lothlorian's Avatar
My wife Adrienne made and exact copy of the old folding door by using parts from the old door and Parts HIHO sent us (Thanks a bunch HiHO).
She will start on the next folding door tomorrow.
Brian
Brian & Adrienne
Old 02-28-2012, 09:32 PM   #367
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
That door looks great!
~Lynnetta
my restoration & travel blog:
https://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 02-29-2012, 03:58 AM   #368
Lothlorian's Avatar
Thanks!! My wife really knows her stuff when it comes to making things using cloth and materials like Vinyl. One door to go and I am sure she will start on it today.
Brian
Brian & Adrienne
Old 02-29-2012, 07:17 AM   #369
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I concur. That door looks fantabulous!!
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 02-29-2012, 04:34 PM   #370
Lothlorian's Avatar
Thanks again. I had to go outside to check it out after work today. It looks like it is from the factory
Brian
Brian & Adrienne
Old 03-04-2012, 03:37 PM   #371
Lothlorian's Avatar
I did not do much this weekend because I have a nasty cold I am fighting. I did get one thing done and that is a panel that fits under the stove which has installed switches for the water pump, hot water heater and a hidden light for the street side of the trailer.
Brian
Brian & Adrienne
Old 03-04-2012, 03:45 PM   #372
Brian, where did you get the switches?
www.nesa.org
Air No. 6427
Old 03-04-2012, 03:52 PM   #373
Lothlorian's Avatar
I got the switches from Pecos in Stone Mountain. Mountain Industrial and Hwy 78. Great people to do business with. That is where I get most of my parts now.
Brian
Brian & Adrienne
Old 03-04-2012, 03:58 PM   #374
Know them well. That's where I got the 35 year old replacement hardware to restore the TV antenna. REALLY good people to deal with. Lots of knowledge and parts there. Plus, I work down the street from them from time-to-time. Easy access. Thanks for the info.
www.nesa.org
Air No. 6427
Old 03-06-2012, 11:42 AM   #375
1967 17' Caravel
Pocatello , Idaho
Vinyl door/curtain
Brian
Hi, I am going to be making replacement doors for 2-3 of our trailers, too. Does your wife use a heavy-duty sewing machine on the vinyl or a regular machine? What brand machine (if i may be personal enough to ask)? And does she use a heavy-duty/special needle or special thread?
Is the vinyl backed with anything, either from the factory or by her?
Can she give me any tips?
Feel free to move this posting if I am too off-topic. Thanks for any help!
Vivian
Landshark is offline   Reply With Quote
Old 03-07-2012, 07:56 AM   #376
Lothlorian's Avatar
Vivian:
She uses a brand new Brothers sewing machine. Her present from me last year. All I can tell you is she bought the vinyl from Joanne's and it seems to be marine vinyl that looks like leather. I will tell you that is heavier then the orginal. That might be from 52 years of drying out. The orginal got lighter with age.
As far as making it I will pass this message to her, because I am clueless when it comes to sewing. She did go out and buy a heavy duty needle and heavy duty thread.
She used all the orginal parts and she had to order very thin metal rods for the second one because the orginal one had those rods in it. Each pleet has a metal rod in it. I will find that information out for you when I get home tonight.
She took the orginal apart and constantly made measurements and wrote everything down.
Brian
Brian & Adrienne
Old 03-07-2012, 06:01 PM   #377
Lothlorian's Avatar
Vivian:
It is a pretty heavy vinyl with a felt like backing. She used two pieces sewn together. We had to order 1/8" {A} Rd Cold Finished 1018-1/8 rd 1018 cold finished 6' long. My wife made two seams with 1" channel between, which she put the rods in. Each of the two inch seams were spaced 4 inches apart. In the 4 inch areas, she put a 3/1/2"wide and 72" long piece of clear plastic carpet protector. On the ends were:
the end that fastens to the wall with screws - a 6 foot long 1/4 inch by 3/4 inch piece of wood.
the end that latches with magnets to the wall - a 6 foot long curtain rod
Any questions, Send a private message to Adrienne
Brian & Adrienne
Old 03-09-2012, 05:17 PM   #378
Central , Mississippi
That interior is stunning!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-10-2012, 02:53 AM   #379
Lothlorian's Avatar
Thanks HIHO!
This is a big push weekend to get things finished. I have a three day weekend and I plan on hitting all three days. I really need to get this thing finished.
Brian
Brian & Adrienne
Old 03-10-2012, 06:12 AM   #380
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Wow! great job, Brian. It looks fantastic. Posting this thread provides an inspiration for the rest of us. Thank you.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
1960, 1960 overlander, restoration
restoration of 1960 Pacer Lucki General Interior Topics 0 09-19-2010 05:15 PM
1960 Pacer restoration Lucki General Repair Forum 0 09-18-2010 03:26 PM
Donate an old Car license Plate for Son's School Project biggoofball Off Topic Forum 61 01-04-2010 05:20 PM
1960 Overlander/ International JTBengal 1960 - 1964 Overlander 0 10-25-2007 10:55 AM
1960 Overlander 66TradeWind 1960 - 1964 Overlander 2 10-23-2002 09:27 PM
