Old 12-29-2011, 11:08 AM   #321
Lothlorian's Avatar
Loganville , Georgia
I have a question before I get to much more involved in putting the Front Goucho back in. I have another water storage tank which is about 3.5 " higher then the old one. I raised the orginal bed frame to fit the new water storage tank. My bed sits 4" higher then it orginally did. I am also about 3 inches farther away from the wall. I have to cut new slats that tie into the wall. It looks great but I have stopped because I don't want to screw everything in and say oops didn't plan on that happening. I have to cut a new bed board and I will be cutting new bed foam. It should work. Anybody have any comments?
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-30-2011, 03:10 PM   #322
Lothlorian's Avatar
I read on another post how a member took a dremel and ground down their olympic rivets. I was at Lowes and notice they sell a grinding wheel that has a concave center. I bought it and tried it out on my olympic rivets. It worked really well and I ground all the rivets that are around my hot water heater. I used a very fine sand paper to to eliminate any marks. It worked great. It did not take long. I will finish the ones that are where my new furnace is located. Trailer is moving along
Brian
Brian & Adrienne
Old 12-31-2011, 09:34 AM   #323
Lothlorian's Avatar
Olympic rivets snipped, ground down, and sanded with fine paper. I did not take long at all. Probably 1 hour and 45 minutes.
Brian
ID:	147891   Click image for larger version
ID:	147893   Click image for larger version
Brian & Adrienne
Old 12-31-2011, 09:35 AM   #324
Lothlorian's Avatar
The water heater area. Olympic rivets ground down
Brian
Brian & Adrienne
Old 12-31-2011, 01:24 PM   #325
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Good idea on the olympic rivets. I have a few to do and may go that same route.I do have a dremel I can try too.
Not sure about your Gaucho, when I put mine in the 80 that was in my 78, I measured 3 times before I mounted the wall parts. Worked out well. I had to be sure it would slide down and open correctly before I drilled or screwed anything.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-31-2011, 01:43 PM   #326
Lothlorian's Avatar
My wife and son did not want the old vanity in the bathroom. They felt it was to low and not enough room to work. We bought a prefab one on sale at homedepot. I cut a few inches off the bottom and put it in place. It will work and they will have more room and a nicer faucet. We bought the faucet at a pawn shop. It was still in the box. It all looks great, but I have mixed feelings about it all. Everything is original and that will be the only thing that will have significant change. The vanity, refrigerator and stove will be different. I will hold on to the old vanity. Who knows I may change it out down the road.
Inside pics coming as soon as I get the other twin bolted down and another bedroom light put back together.
Brian
Brian & Adrienne
Old 01-07-2012, 08:55 AM   #327
Lothlorian's Avatar
I built the case for the new Suburban Furnace and I am heading to Lowes to buy a metal grill. I will stain and put the grill in. I should have pics hopefully tomorrow. I did miter cuts for the sides to make every thing look flush.
Brian
Brian & Adrienne
Old 01-07-2012, 07:53 PM   #328
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Brian
Your welcome to use my rivet shaver. :-)
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-08-2012, 03:47 AM   #329
Lothlorian's Avatar
Myrtle Lynn:
Good to hear from you. I have been meaning to make a trip to Athens and visit. I was planning on borrowing your shaver. What happened was I saw a concaved dremel grinder at Lowes when I got an idea, bought it and tried it on one rivet. It worked great. I just kept going and got them finished.
Making progress with the interior. We are pretty close to finishing the inside. I now need to finish the outside. I am looking to use a sand blaster (Sodium bicarb instead of sand) to do the underbelly. Sodium Bicarb will not hurt the underside.
I saw a 1955 Airstream for sale recently. The price was decent for it. I would have loved to buy it but the 1960 has been a long project and my daughter is getting married. Big expenses coming my way soon.
I will try to make a trip up to the carwash. I want to get the truck washed and the interior cleaned. See ya soon. Stay in touch
Brian
Brian & Adrienne
Old 01-08-2012, 09:20 PM   #330
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Myrtle Lynn:
Brian
I have been busy. This is the busy time of year for the car wash. Well it he shaver is here if you ever decide. I am heading down to Key West this Friday with the 345 Moho. So wait till after this coming weekend to get the truck washed. :-) your sons as is looking great. Good luck and come visit. I only have 5 Airstreams on my lot. Sold a lot and hard to find more. Oh well. Take care.
Athens GA
Old 01-09-2012, 04:23 PM   #331
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Key West in the MOHO sounds great. We did a loop around most of Fla when we had ours.
AIR #005
retired!
Old 01-09-2012, 08:00 PM   #332
Central , Mississippi
Brian
That is some great work!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 01-10-2012, 05:24 PM   #333
Lothlorian's Avatar
HiHo:
I have been following your work and find what you have accomplished to be amazing. Thanks for the compliment.
Brian
Brian & Adrienne
Old 01-15-2012, 01:55 PM   #334
Lothlorian's Avatar
Suburban Furnace cover is completed and in place. You can see a sliver of the channel to the right. My wife is making the cushion for the top as I type.
I wired the second bedroom light to DC. I am running AC tomorrow.
Brian
Name:	Heater cover1.jpg
Brian & Adrienne
Old 01-15-2012, 02:33 PM   #335
Lothlorian's Avatar
The seat is finished and in place.
Brian
Name:	heater cover2.jpg
Brian & Adrienne
Old 01-16-2012, 03:41 AM   #336
Lothlorian's Avatar
I have a heating duct that goes under the kitchen and into the back bedroom. I have two more 4" holes to run heating ducts. The Suburban nt-30 directions state that you should you run no less then three heating ducts. I orginally planned on only two so here is my question.
Can I run a second heating duct exiting out of the right side of the box and leave the third one open so it can vent out the perforated grill in the front?
Brian
Brian & Adrienne
Old 01-16-2012, 05:21 AM   #337
x
XXXX , XXXX
Brian you will need to duct the hot air from the furnace away from the enclosure otherwise it will be picked up by the return air. That would have the return air too hot and the high limit switch will start tripping.
wasagachris is offline   Reply With Quote
Old 01-21-2012, 04:47 PM   #338
Lothlorian's Avatar
I started to dismantle the counter top on the galley cabinets. We made a decision to put a new counter top on the kitchen cabinets. I should have it out tomorrow and will get a new one cut and laminated. The more we work on the trailer and get the interior restored the more things we decide to work on that we were happy with earlier.
Brian
Brian & Adrienne
Old 01-22-2012, 09:17 AM   #339
Lothlorian's Avatar
Counter top is out and we will have a new top next week. I am really excited about this because it is going to make the interior really pop when it is re-installed.
Brian
Brian & Adrienne
Old 01-22-2012, 09:36 AM   #340
nmbosa's Avatar
Nowhere , Washington
Brian,
Make sure you save all the little clips and wood spacers that are used to attach the sink to the counter top. You will need those if you are going to reuse the sink.
On your furnace, the cover looks great. That is the same grill material I used. Chris is right though, you will have to run the heat ducts away from the furnace. The grill in front is your cold air return and the heat exit must be at least a few feet away from that area (the instructions tell you how many feet). I ran one duct to the bedroom, one to the kitchen cabinet under the drawers, and one up to the front under the dinette framing. There should be enough room on the left (while facing the sink) side of the kitchen cabinet under the drawers to install a 4" round duct. For the third duct, if you don't have a dinette, you may need to fabricate something to cover a short duct run towards the front.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
1960, 1960 overlander, restoration
restoration of 1960 Pacer Lucki General Interior Topics 0 09-19-2010 05:15 PM
1960 Pacer restoration Lucki General Repair Forum 0 09-18-2010 03:26 PM
Donate an old Car license Plate for Son's School Project biggoofball Off Topic Forum 61 01-04-2010 05:20 PM
1960 Overlander/ International JTBengal 1960 - 1964 Overlander 0 10-25-2007 10:55 AM
1960 Overlander 66TradeWind 1960 - 1964 Overlander 2 10-23-2002 09:27 PM
