08-05-2007, 10:15 PM
#121
1975 Argosy 26
1963 24' Tradewind
Seattle
OUCH!!! What happened? Any stitches?
Be safe out there!
Marc
08-05-2007, 10:29 PM
#122
Colville
Be safe out there!
Marc
Thanks Marc -
I was installing the new breakaway switch, and forgot the window was slightly open to allow some airflow. I found the exact corner of the window
Nobody else was home. I skipped the hospital as I opted for a high deductible (lower monthly payments). Emergency room costs an extra $1,000 just to walk thru the doors. Still has fresh blood a couple hours later, I'll see how it is in the morning.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
08-05-2007, 10:56 PM
#123
1975 Argosy 26
1963 24' Tradewind
Seattle
OW! MY head hurts just thinking about that! Yikes! Probably too late now, but there is a glue out there for skin lacerations... I'm just not sure if it's available over the counter or not.
Don't use Vulkum! : >
On the serious side... have you had a recent tetnus shot? If not, I'd call your doc in the morning and get one. Make sure it's clean. Any temps/fever.. or reddness at the site, get thee to the doc pronto!
Ok, enough of the overprotective nurse.
Take care!
Marc
08-06-2007, 07:15 AM
#124
1963 16' Bambi
Yreka
There is no greater dedication than giving blood to an Airstream project. Hope you are healing.
Don
08-07-2007, 10:13 AM
#125
Colville
Happy Dance time
Searched long and hard to find just the right fabric - it had to match the GreatPumpkin and be vintage style. It measures out at 9' x 15'. I had a family friend with a heavyduty machine sew it for us. She did a great job. (Shameless plug for them - see their website: Cuddlemewarm)
Here's the results:
Rope tightners started as scraps of oak:
Finished product:
Did a lot of research here on the forums, saw a lot of good ideas. Shari's ( InsideOut) thread was probably the most inspiring. http://www.airforums.com/forums/148244-post119.html
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
08-07-2007, 10:34 AM
#126
1951 21' Flying Cloud
1960 24' Tradewind
West Coast
, BC
Love the look of the awning. It sure suits the trailer.
Barry
08-07-2007, 10:49 AM
#127
1975 Argosy 26
1963 24' Tradewind
Seattle
looks great! Can't wait to see it at BB!
Marc
08-07-2007, 11:07 AM
#128
Colville
Barry
Marc
Thanks Barry and Marc
We're really happy with the way it looks. I was going to keep it as a suprise at BB, but couldn't wait to share
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
08-24-2007, 12:03 AM
#129
Colville
Adjustments added.
I wasn't able to pull it taut enough to keep the door from scraping it.
Solution was to add two horizontal support poles that slide over the tip of each vertical pole. I used two pieces of 1/2 conduit, flattened each end. I then rounded off the corners and drilled holes into each end. (Measure twice, cut once - they fit perfectly ) I had our friend attach 6 loops of industrial velcro to hold the awning to the support poles and allow me to pull it tighter. The door now doesn't touch the awning, and it should shed rain better.
Crude drawing below, but should be able to get some in-use photos this weekend - we're going camping!
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
08-24-2007, 11:10 AM
#130
1960 24' Tradewind
West Coast
, BC
We have the pipe sewn into our awning but it can be removed if necessary without much effort. I like the fact that I can leave the awning on the trailer while hauling and it's easy to set up. Mine does not have the stripes and scallops of yours though and I've got to have that. Time to make a change on mine I guess. I just love the look of yours.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
09-10-2007, 11:44 PM
#131
Colville
AS promised, here's another photo with the new horizontal bars installed. (sorry about how dark it is, I almost forgot to take one). This was taken on our camping trip the weekend before Labor day. The horizontal bars allow me to pull it tighter, keeping the sag out, and allowing the door to clear without any drag!
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:43 AM
#132
1960 24' Tradewind
West Coast
, BC
It sure does look good GP. I've got to update mine with the scallops, no doubt about it. A great winter project.
Thanks for sharing the info.
Barry
Barry & Donna
09-11-2007, 09:07 PM
#133
Colville
Axle Replacement
A few photos of my axle replacement project.
1) Unbolt the old ones
2) Bolt in the new ones
Wake up and start the process for real
I should have gotten more shots throughout the process, but I was to grimy, so what you see is what you get. I backed it into the driveway, placing the rear wheels on 1 2x6 to get a little more clearance. I then jacked up the front axle (on the mounting plate only!) and removed the front wheels. Next step was to remove the brakes and clean off the grease so I didn't get it all over.
Brakes and backing plates removed, sheck out the angle of my torsion arm - solidly frozen in place. Now simply remove the mounting bolts that I had been dousing semi-regularly with WD-40. Did I say simply? Check out the bolt behind the torsion arm - how do I get to that?
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:10 PM
#134
Colville
Forgot to mention the nice suprise when I pulled off the front streetside brakes. Backing it into the driveway after our last trip, I thought it sounded funny - I didn't pull the hub because my replacement axles were already ordered so I wasn't to concerned. The brake screw adjuster was broken and rolling around freely
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:17 PM
#135
Colville
My solution to the bolts is pictured below - had to cut them off. No-one in town had a nut splitter, the impact wrench wouldn't budge them, couldn't even get a socket on the one behind the torsion arm.
I used a die grinder fitted with a cutoff wheel. Took a little while, because my compressor is only a 3-1/2HP (Honey weren't you just asking what I wanted for Christmas. Hint. Hint.)
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:33 PM
#136
Colville
Once the bolts were out, a little persuading and the old axle dropped clear. Positioning the new axle was pretty easy. I have a four wheeled cart? that I rested the new axle on, with a 2x4 to keep it properly balanced and aligned. I then just had to wheel it in place and jack each end up into place - that would go quicker with a helper, but was still pretty easy.
Once in place I marked the location of the bolt holes and dropped it back down to drill. Here's where a mistake in ordering caused me a little more grief. I ordered my Dexters with the Low Profile Side Mount Bracket with reverse orientation. Another member had mentioned it was unnecessary, but I didn't quite understand. The bracket is in addition to the piece welded to the axle body  . That means two pieces of 1/4" steel to drill through instead of one. But, even worse, is the fact that bracket caused the predrilled holes to sit just slightly too low to use  . So using my new $30 5/8" drill bit. I drill some holes. I was able to use one of the original mounting holes on the airstream, so that hole was just thru two layers of steel. The other hole had to go thru all three layers.
I managed to get most of the holes drilled before snapping the bit clean in half. Time for a lemonade break while I send my wife out for another bit.
I get the rest of the holes drilled and lift the axle back into position. Bolt it in place, use the impact to tighten it up and I'm almost done.
Recycled the rubber grommets from the old axles and feed the brake wires back thru. Connect them up and go pull the breakaway. Brakes work! Success.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:38 PM
#137
Colville
Now I'm an expert right?  . Time to start on the rear axle. Basically a repeat of the front axle without the snapping of the drill bit. It went a little quicker/smoother. Forgot to mention, I did take a drill and wire brush to the mounting plates. I then used the same rust encapsulater I used on the tongue. Once the axle was in place, I then sprayed some rubberized undercoating over all the exposed metal.
Here's a couple pics of the rear axle and the shocks - no they aren't leaking, that's just alot of WD-40. The shock buts came off pretty easy.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:41 PM
#138
Colville
Here's a pic of the new axle in place and the rubberized undercoating sprayed.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
09-11-2007, 09:45 PM
#139
Corona
Originally Posted by GreatPumpkin
Need a source for the Bargman 99 cakelight gasket. My lenses are fine, but gaskets are shot allowing water into the housing. I looked at Inland RV and Vintage Trailer Supply, but no luck.
Visit most any NAPA store and get some bulk gasket material.
With that, you can cut what ever size gasket you may need.
09-11-2007, 09:51 PM
#140
Colville
Now remember I ordered the "airstream Top shock bracket option (E_1501)"? I wasn't sure if it would work or not, but I took a gamble and it will work! Kinda. See the pic below. My main concern was that it would be in the way of the torsion arm "stop" that is welded in place. It clears without a problem. It will work as is, but it would put the shock at a slight off-angle. The bracket is welded in place to the top outside of the torsion arm. If it were requested to be welded to the top inside of the torsion arm, it would be perfect! The other simple option is to slightly bend out the mounting arm that is pre-existing on the trailer.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
