Measurement between twin beds
I had to replace some of the flooring in the rear of our 93 Excella Classic, which necessitated removing the twin beds. I desperately wanted to reuse the floating floor which I carefully removed and was able to reinstall. Nothing was square before I started and the same when I finished. Also made new beds with piston lifts. So, I remembered that when the nightstand was in, I had EXACTLY enough room to store four 12 packs of soda between the nightstand and the end table. That is how I put it together and if its off now, its off inside a compartment and not the living area. (Can store two 12 packs on each side and they do not move from there.) Maybe a little unorthodox bit it worked well.
