Old 05-11-2008, 11:04 PM   #1
1964 26' Overlander
Reno , Nevada
Wink manual crank for 1964 electric tongue jack
Hello All. I have been busy restoring my 64' Overlander's exterior and found the tongue jack does not work. I opened the top and noticed there is a notch where possibly a manual crank can be attached to raise and lower the tongue. Is this true or do I have to get a battery to run the electronic jack? Any help is appreciated since next week I am driving to LA to hitch up to it. Thanks.
Croverlander is offline   Reply With Quote
Old 05-11-2008, 11:25 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Yes, that is a provision for a manual crank. You can make one out of some bar stock and a rollpin if you cant find the original.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-12-2008, 01:25 PM   #3
1960 22' Safari
in the wilderness , The great Mojave Desert
What he said and...
Before you use the electric jack again make sure to sync everything. So the leg and motor's switchs all agree on where the leg actually is.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 05-12-2008, 01:29 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
what they said and..........
once in a great while you see a used hand crank on ebay for a lot of bucks. If you make your own it would be pretty easy to make it so it fits in an electric drill.
I'm not sure if the battery needs to be in the coach but it is a 12 volt motor. so some how you need some juice. Check your fuses, jack switch, and that the wire to the jack is hot.
Old 05-12-2008, 01:46 PM   #5
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Boy I would love to have a manual emergency crank but I dont know what Dia. of bar stock or roll pin to buy. Also how far from the end is the roll pin placed. Robert
bertro is offline   Reply With Quote
Old 05-12-2008, 03:42 PM   #6
NevadaGeo's Avatar
Genoa , Nevada
Mine thinks it's at the stop place unless the battery is pretty well charged.
NevadaGeo is offline   Reply With Quote
Old 05-12-2008, 03:51 PM   #7
Excella CM's Avatar
Venice , California
If you make a crank, the rod diameter is what just fits inside the motor socket and the roll pin size and location are such that it will fit in the slots in said socket.
Old 05-12-2008, 04:31 PM   #8
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Sorry I was being lazy and really didn't want to pull the head of the jack off. Any Dim. would be great. Robert
Old 05-12-2008, 05:58 PM   #9
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Hand Crank
Here is a photo of the emergency standby hand crank that came with my Airstream from the factory. I have had to use it on several occasions and it was effortless. As a matter of fact I am not sure why the motor sounds like it is laboring so hard when I use it.
This is a piece of 1/2" aluminum tubing with a 3/16" roll pin located 1/2" to center.
I have seen several people make a straight piece about 3" long and place in a cordless drill and not use the motor at all.
Best of Luck
fltlevel510 is offline   Reply With Quote
Old 05-19-2008, 08:47 PM   #10
1964 26' Overlander
Reno , Nevada
Thank you all. Luckily, when I arrived to pick it up, the crank was inside the cabin. Looks just like the one above. She has some bad wiring so I will have to investigate before the motor will be running.
Old 05-19-2008, 08:56 PM   #11
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
there is a crank for sale on ebay right now.
goransons is offline   Reply With Quote
Old 12-24-2009, 06:05 PM   #12
Dwight's Avatar
1999 34' Excella
Joshua , Texas
How do you sync everything?
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 12-24-2009, 07:06 PM   #13
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
Google this site: http://www.barkermfg.com/superjackpg4.pdf for complete details.
Or follow these instructions from the manual (below):
INSTALL POWERHEAD OR RE-TIMING
• Use the crank to fully retract post.
• Crank jackpost one turn in opposite direction
• Ground powerhead to jackpost or trailer frame.
• Push switch away from jackpost housing (as if retracting post). Hold switch until motor stops running(as if jackpost is retracted all the way).
• Install powerhead and tighten set screws.
Its important to do it right, then test it so it will not jam. Good luck
JStanley is offline   Reply With Quote
Old 04-09-2014, 09:53 AM   #14
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Electric jack kept shorting out yesterday so I could not lower the jack. ( I think I found the problem) Anyway I was trying to figure out how to lower it manually. I read the manual and still could not see what to attach what to where to lower the jack. This is on a 2013 Flying Cloud. Any suggestions?
TinCan
graysailor is offline   Reply With Quote
Old 04-09-2014, 11:08 AM   #15
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
You have to remove the powerhead to access the receptacle for the manual crank. Be sure to follow the timing procedure in JStanley's post above when you re-install the power head.
Old 04-09-2014, 11:10 AM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
You have to remove the jack head by taking out the four allen screws that hold it to the post.
Manual and electric tongue jack streamnhurt Hitches, Couplers & Balls 11 12-22-2011 05:37 PM
Tongue Jack..Electric vs Manual TankerIP Jacks, Stabilizers, Lifting and Leveling 9 05-29-2010 09:11 PM
Electric Tongue Jack Manual Override overlander64 Jacks, Stabilizers, Lifting and Leveling 10 05-07-2009 09:22 AM
replacing manual tongue jack with electric Lumatic Jacks, Stabilizers, Lifting and Leveling 5 11-25-2008 07:04 AM
Tongue jack crank problems TDOW Jacks, Stabilizers, Lifting and Leveling 3 06-10-2005 06:21 AM
