Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1960 - 1964 Overlander
Old 01-15-2021, 07:15 PM   #141
Central , Mississippi
Well, since I’m not rebuilding it I will go from memory.
No issues so far with the small dump. It might actually help since the velocity is faster thru the small hole. I will be dumping it this weekend into a blueboy and carting off. I will report any issues.
If I recall, the fridge cabinet top has to come off before the side can be removed. No big deal, just a few screws from the other side of the opposite wall.
All of this is completely subjective to previous owner modifications, rare but possible right?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 02-01-2021, 09:08 PM   #142
1961 16' Bambi
Hot Springs , South Dakota
Confused on what you found? The square box on top or the round light on the bottom?
fander is offline   Reply With Quote
Old 02-02-2021, 12:04 PM   #143
62 Flying Cloud
VooDooLounge's Avatar
1962 22' Flying Cloud
Lakewood Ranch , Florida
Originally Posted by 66Overlander View Post
Back to the beginning with this question. Did you heat and bend the diffuser so that it permanently took the curved shape, or it is just bent and under tension always trying it's hardest to straighten back out?
I am asking because I need a similar diffuser for my 1962 Safari.
VTS now sells the curved diffuser in 48" lengths. I searched and fabricated (poorly) for 11 years. VTS has a great product! 1962 Flying Cloud
VooDooLounge is offline   Reply With Quote
Rebuilding 65 rear end to modify or not to modify? tbrom Repairing/Replacing Floor &/or Frame 4 06-21-2007 08:53 AM
Rebuilding '68 Overlander Toilet Uberlanders Sinks, Showers & Toilets 5 04-17-2005 09:37 PM
Rebuilding Waste valves balrgn Waste Systems, Tanks & Totes 11 12-04-2004 02:31 PM
Top ten things about rebuilding a new trailer campcollector 1997 - 2004 Bambi 2 02-27-2004 04:56 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
