RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-09-2017, 08:54 PM   #41
Central , Mississippi
Dunno what to think of this...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 10-10-2017, 06:55 AM   #42
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 35
Originally Posted by HiHoAgRV View Post
The bathroom vanity has been slowly disappearing into splinters of delaminated wood. Today I backed out the 8 -10 screws and removed it. I lifted off the top and much to my surprise, this trailer is an International Signature Series! (Now if I could just read the signature...)
The floor is good and solid, good thing because I really am not planning on rebuilding this trailer
Very cool finding that signature!! Since you're NOT rebuilding this trailer you can go ahead and NOT repair the toilet bowl sprayer where the copper water line froze one year, while you're there in that area! Just helping from afar!!
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 10-10-2017, 08:40 AM   #43
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Looks like "IDC" or "IDG" and part of the serial number "261-#860" which is appropriate for a 1961 26" Overlander built in Ohio
Joe
WBCCI/VAC #6768
66Overlander is online now   Reply With Quote
Old 10-10-2017, 09:57 AM   #44
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Be worried .... be *very* worried !!!!
Actually, if I was there in 61, I was installing some pretty high grade plywood. The fact that Granddaddy sold it to AS in no way colors my opinion .... The thing to be worried about is having a grade schooler loose in your trailer with tools ....
Old 10-10-2017, 06:23 PM   #45
Yeah, there is a bit of spliced copper still there that I couldn't get out when I ran pex. The darn sprayer leaks when you use it. That causes some unpleasant sensations and reactions when I exit the bathroom with dripping wet hands. I guess I should re(place)pair. It.
Old 10-10-2017, 06:25 PM   #46
Hi
Do you recall a field trip to Jackson Center as a youngster? Mischievous kids sneaking away from the tour and writing their names on stuff?
LOL!
Old 10-10-2017, 06:36 PM   #47
Yup, like the other trailers I dealt with, the s/n matches the trailer. My first thought was IDC was International, double, C? But it's a twin trailer.
Some marks look like "Older" and "R..T."
Just another unsolvable Airstream mystery!
Old 10-11-2017, 06:46 AM   #48
Mrs HiHo's Avatar
Ummmm, I agree
Mrs HiHo is offline   Reply With Quote
Old 10-11-2017, 08:13 AM   #49
Half a Rivet Short
LOL!
Hi
Well keep in mind that there was one and only one criteria for the quality of a trailer when I was very young. The ones with more plywood were better trailers. There was no debating this point. You *could* bring up the aircraft analogy. That would be a bit of a mistake. Granddad was a aviation carpenter in the Navy before he started selling plywood ....
Old 10-15-2017, 09:10 AM   #50
I'm surprised at some folks who are lucky enough to be able to save the original veneer. This trailer, no way. One more 4x8 sheet of oak ply and a couple of hours results in a reskinned bath cabinet. The frame is in great shape, only one 1x2 needed replacing. I am spraying poly on the interior to help contain any remains of 'vintage aromas'. A couple more coats and it goes back in.
ID:	297036   Click image for larger version
Old 10-16-2017, 07:31 AM   #51
Half a Rivet Short
Hi
Plywood *can* last a very long time. I have pieces that are at least 70 years old and never have been used. Glue matters and there are multiple formulas that can be used. Back in the "good old days" you might find a range of glues used by a single outfit. As long as the glue holds up, the plywood should stay intact.
Yes, the wood also matters. On older plywood, it rarely was an issue. I wonder about the stuff I see in modern sheets.
Sounds like you got unlucky on the glue batch used on your trailer
Old 10-17-2017, 06:05 PM   #52
Bad glue actually has helped. Not only did the 'A' side veneer come loose from the core, the 'B' side did also. Now the glue that Airstream used, it's not coming loose so I have been able to attach new ply to the old inner side of the 'B' veneer.
Reinstalled the cabinet. The color difference and crooked top are a visual effect of my iPhone camera.
It's a lot of work not rebuilding a trailer!
Old 10-17-2017, 07:36 PM   #53
Half a Rivet Short
Hi
Ok, I guess I never looked at bad glue as a virtue before
Old 10-17-2017, 10:16 PM   #54
Hi
This plywood has none of the vices I admire and all of the virtues I dislike
Old 10-17-2017, 10:27 PM   #55
Bourbonshot's Avatar
1961 24' Tradewind
1975 31' Sovereign
Louisville , Kentucky
With HiHoAgRV’s encouragement, here’s another autographed 1961 OH trailer; photo is from the rear closet in our Trade Wind. Would love to know more about Pete!
Bourbonshot is offline   Reply With Quote
Old 10-18-2017, 06:19 PM   #56
It doesn't look like Pete built my cabinets, he musta had the day off.
Old 10-19-2017, 09:28 AM   #57
Half a Rivet Short
Hi
When you start finding the notes carved in Roman numerals .... give Time Team a call ...
Old 10-19-2017, 02:36 PM   #58
Images: 35
Wink
The bathroom cabinet turned out very nice! Original counter top, original hardware, original sink, but I can't quite see the original bathroom faucet.....
Did you not rebuild it or did you not replace it??!!! haha
Old 10-19-2017, 05:26 PM   #59
I've been busted...it's a replacement.
Old 10-19-2017, 08:15 PM   #60
Vintage Kin
Fort Worth , Texas
But you purchased it from the table at the RV supply house of marked-down returns, scratch & dent, or discontinued. Maybe from a salvage yard. Thus:
No technical foul.
Rebuilding 65 rear end to modify or not to modify? tbrom Repairing/Replacing Floor &/or Frame 4 06-21-2007 09:53 AM
Rebuilding '68 Overlander Toilet Uberlanders Sinks, Showers & Toilets 5 04-17-2005 10:37 PM
Rebuilding Waste valves balrgn Waste Systems, Tanks & Totes 11 12-04-2004 03:31 PM
Top ten things about rebuilding a new trailer campcollector 1997 - 2004 Bambi 2 02-27-2004 05:56 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
